Donald_2k11
Dauer-User
- 516
Sehr geil... funktioniert auch mit Spotify.
Ausprobiert und kann bestätigen, das der Stock-Player und Google Music einwandfrei laufen. Bei V4A ist der Normal-Mode eingestellt.THX to Bradl79@XDA
POSSIBLE FIX for V4A, i am on a Galaxy S4 and was having issues playing off of the device and i think i may have had a fluke but i think i fixed it, i edited the build.prop and edited lines
#system prop for the LPA/TUNNEL
lpa.decode=false
tunnel.decode=true ---> changed to false
lpa.use-stagefright=true ----> changed to false
save and reboot, make sure the permissions are correct -rw r-- r--
and now stock player and google music plays music on my device... i hope it continues. let me know if anyone else has luck with this fix
Ghostwalker schrieb:Habe gerade einen sehr interessanten Tip für das S4 aus dem XDA-Thread geangelt.
Will man das denn?Redbull320 schrieb:Um den mod zu deinstallieren...
V4A FX version mainly for rendering audio effects, by controlling various parameters to achieve the purpose of audio effect adjustment.
V4A XHiFi version mainly for restoring audio quality and details.
