gALEXy
Oha
langweilig? ^^
tobiasth schrieb:Probiere ich gleich mal aus, bin sowieso gerade am rumflashen ....![]()
The current build does not install the correct libv4a_fx_xx.so into /system/lib/soundfx/ during the driver installations. I was having the same problem with my note 3 so I checked and only the libv4a_fx_ics.so was being installed and the libv4a_fx_jb.so (which I'm assuming is what we need for viper to run correctly on android 4.3) was not. I simply unzipped the viper apk file and found the appropriate libv4a_fx_xx.so file, renamed it to "libv4a_fx_jb.so", copied it to /system/lib/soundfx/ on my phone with es file explorer, and made sure the permissions were correct (important). After a reboot, viper worked fine with play music, pandora, and pretty much everything, even all of the effects are working, and in normal mode, not compatibility
