goes_like_hell
Dauer-User
- 176
- Themenstarter
- #101
Gratulation !
Hast Du Zoll bezahlen müssen ?
Anmerkung: Diese Funktion erfordert derzeit den Zugriff auf die Seite über den integrierten Safari-Browser.
After installing the firmware, install from market Terminal Emulator and type the following commands:
su [enter]
/system/bin/restorecon -R -v /data/media/0 [enter]
!!! [enter]= Enter-Taste drücken !!!
oder in anderen Worten
Das whatsapp thema müsste dann auch gelöst sein.
I can't receive a picture in whatsapp as when it tries downloading it seems to fail to save.
Problem: the apps are not being able to access the memory !
Solution:
1. download "Terminal Emulator" app form play store
2. TYPE:
su (press enter and confirm SU dialog)
/system/bin/restorecon -R -v /data/media/0 (press enter)
3. some text should appear and apps should be able to access memory again.
