Bootloop, Brick und andere Gründe für ein nicht startendes Gerät
  • 535 Antworten
Ja, kann ich, ist bisschen mehr deshalb hab ich es hier:
Entry Count: 28
Unknown 1: 1598902083
Unknown 2: 844251476
Unknown 3: 21325
Unknown 4: 14413
Unknown 5: 13113
Unknown 6: 48
Unknown 7: 0
Unknown 8: 0
--- Entry #0 ---
Binary Type: 0 (AP)
Device Type: 2 (MMC)
Identifier: 1
Attributes: 5 (Read/Write)
Update Attributes: 1 (FOTA)
Partition Block Size/Offset: 8192
Partition Block Count: 122880
File Offset (Obsolete): 0
File Size (Obsolete): 0
Partition Name: MODEM
Flash Filename: NON-HLOS.bin
FOTA Filename:
--- Entry #1 ---
Binary Type: 0 (AP)
Identifier: 2
Partition Block Size/Offset: 131072
Partition Block Count: 256
Partition Name: SBL1
Flash Filename: sbl1.mbn
FOTA Filename:
--- Entry #2 ---
Binary Type: 0 (AP)
Identifier: 3
Partition Block Size/Offset: 131328
Partition Block Count: 512
Partition Name: SBL2
Flash Filename: sbl2.mbn
FOTA Filename:
--- Entry #3 ---
Binary Type: 0 (AP)
Identifier: 4
Partition Block Size/Offset: 131840
Partition Block Count: 1024
Partition Name: SBL3
Flash Filename: sbl3.mbn
FOTA Filename:
--- Entry #4 ---
Binary Type: 0 (AP)
Identifier: 5
Partition Block Size/Offset: 132864
Partition Block Count: 4096
Partition Name: ABOOT
Flash Filename: aboot.mbn
FOTA Filename:
--- Entry #5 ---
Binary Type: 0 (AP)
Identifier: 6
Partition Block Size/Offset: 136960
Partition Name: RPM
Flash Filename: rpm.mbn
FOTA Filename:
--- Entry #6 ---
Binary Type: 0 (AP)
Identifier: 7
Partition Block Size/Offset: 137984
Partition Name: TZ
Flash Filename: tz.mbn
FOTA Filename:
--- Entry #7 ---
Binary Type: 0 (AP)
Identifier: 8
Partition Block Size/Offset: 139008
Partition Block Count: 25600
Partition Name: PAD
Flash Filename:
FOTA Filename:
--- Entry #8 ---
Binary Type: 0 (AP)
Identifier: 9
Partition Block Size/Offset: 164608
Partition Block Count: 16384
Partition Name: PARAM
Flash Filename:
FOTA Filename:
--- Entry #9 ---
Binary Type: 0 (AP)
Identifier: 10
Update Attributes: 5 (FOTA)
Partition Block Size/Offset: 180992
Partition Block Count: 27904
Partition Name: EFS
Flash Filename: efs.img.ext4
FOTA Filename:
--- Entry #10 ---
Binary Type: 0 (AP)
Identifier: 11
Partition Block Size/Offset: 208896
Partition Block Count: 6144
Partition Name: MODEMST1
Flash Filename: nvrebuild1.bin
FOTA Filename:
--- Entry #11 ---
Binary Type: 0 (AP)
Identifier: 12
Partition Block Size/Offset: 215040
Partition Name: MODEMST2
Flash Filename: nvrebuild2.bin
FOTA Filename:
--- Entry #12 ---
Binary Type: 0 (AP)
Identifier: 13
Partition Block Size/Offset: 221184
Partition Block Count: 20480
Partition Name: BOOT
Flash Filename: boot.img
FOTA Filename:
--- Entry #13 ---
Binary Type: 0 (AP)
Identifier: 14
Partition Block Size/Offset: 241664
Partition Name: RECOVERY
Flash Filename: recovery.img
FOTA Filename:
--- Entry #14 ---
Binary Type: 0 (AP)
Identifier: 15
Partition Block Size/Offset: 262144
Partition Name: FOTA
Flash Filename:
FOTA Filename:
--- Entry #15 ---
Binary Type: 0 (AP)
Identifier: 16
Partition Block Size/Offset: 282624
Partition Block Count: 14320
Partition Name: BACKUP
Flash Filename:
FOTA Filename:
--- Entry #16 ---
Binary Type: 0 (AP)
Identifier: 17
Partition Block Size/Offset: 296944
Partition Name: FSG
Flash Filename:
FOTA Filename:
--- Entry #17 ---
Binary Type: 0 (AP)
Identifier: 18
Partition Block Size/Offset: 303088
Partition Name: SSD
Flash Filename:
FOTA Filename:
--- Entry #18 ---
Binary Type: 0 (AP)
Identifier: 19
Partition Block Size/Offset: 303104
Partition Name: PERSIST
Flash Filename: persist.img.ext4
FOTA Filename:
--- Entry #19 ---
Binary Type: 0 (AP)
Identifier: 20
Partition Block Size/Offset: 319488
Partition Block Count: 24576
Partition Name: PERSDATA
Flash Filename: persdata.img.ext4
FOTA Filename:
--- Entry #20 ---
Binary Type: 0 (AP)
Identifier: 21
Partition Block Size/Offset: 344064
Partition Block Count: 3072000
Partition Name: SYSTEM
Flash Filename: system.img.ext4
FOTA Filename:
--- Entry #21 ---
Binary Type: 0 (AP)
Identifier: 22
Partition Block Size/Offset: 3416064
Partition Block Count: 409600
Partition Name: CACHE
Flash Filename: cache.img.ext4
FOTA Filename:
--- Entry #22 ---
Binary Type: 0 (AP)
Identifier: 23
Partition Block Size/Offset: 3825664
Partition Block Count: 73728
Partition Name: HIDDEN
Flash Filename: hidden.img.ext4
FOTA Filename:
--- Entry #23 ---
Binary Type: 0 (AP)
Identifier: 24
Partition Block Size/Offset: 3899392
Partition Block Count: 0
Partition Name: USERDATA
Flash Filename: userdata.img.ext4
FOTA Filename: remained
--- Entry #24 ---
Binary Type: 0 (AP)
Identifier: 70
Partition Block Size/Offset: 0
Partition Block Count: 34
Partition Name: PGPT
Flash Filename: pgpt.img
FOTA Filename:
--- Entry #25 ---
Binary Type: 0 (AP)
Identifier: 71
Partition Name: PIT
Flash Filename: MSM8930.pit
FOTA Filename:
--- Entry #26 ---
Binary Type: 0 (AP)
Identifier: 72
Partition Block Size/Offset: 50
Partition Block Count: 32
Partition Name: MD5
Flash Filename: md5.img
FOTA Filename:
--- Entry #27 ---
Binary Type: 0 (AP)
Identifier: 73
Partition Block Size/Offset: 15269855
Partition Block Count: 33
Partition Name: SGPT
Flash Filename: sgpt.img
FOTA Filename:
Was ich überings noch nicht probiert hab, ist eine mehreteilige Firmware mit Partitionstabelle zu flashen, das aber nur, weil ich keine für das GT-I9195 gefunden hab, die schon Bootloader Revision 2 hat..
bin völlig verzweifelt. Habe heute morgen mit Dr. Fone aus versehen gelöschte SMS eines Freundes versucht wiederherzustellen, aber mein Handy ist nun dauerhaft im Recovery Modus. Das Logo von Dr. Fone steht auf dem Bildschirm und geht nicht mehr weg. Und da steht Recovering....
Was soll ich tun ?
Danke für Unterstützung!
Isabel
habe probiert mein Galaxy S4 Mini mit der Stock Firmware zu bespielen. Leider bricht odin immer ab, mit der Meldung "<ID:0/004> Complete(Write) operation failed." und auf dem Handy steht "Secure Check failed: aboot"
Habe das Handy von einem Freund geschenkt bekommen, er hat wohl probiert cyanogenmod drauf zu spielen allerdings startet sich das Handy einfach immer neu. Ich möchte einfach nur das es funktioniert. Woher kommt dieser Fehler Secure Check Failed: aboot?
Vielen Dank!!
/E: Ich habe gerade mal ne andere ROM probiert, jetzt kriege ich ' Secure Check failed: SBL2
Was mache ich falsch :(
Bearbeitet von: hanspampel - Grund: In entsprechenden Thread verfrachtet - "hanspampel"
@Isabelk80
Schon mal versucht mit der länger gedrückten Powertaste das Phone auszuschalten ?
Evtl Battery raus nehmen.
Sollte danach dein Phone wieder nur bis dahin starten ist dein Phone gebrickt, und dann hilft evtl. ein Custom oder Stockrecovery einspielen.
Bearbeitet von: hanspampel - Grund: Bezug zum Post wegen Thread-Merging hergestellt. - "hanspampel"
Hi @Awebb
Habe dich mal in entsprechenden Thread verfrachtet. Was genau haste denn geflasht? Sprich welche FW, wie der Vorgang etc.
Hi @hanspampel,
habe wohl eine falsche FW benutzt. Geht jetzt. Trotzdem danke!
10.2013 wurde mein S4mini in Betrieb genommen.
Akku bei 30%, Ladekabel ran, nach 1 Stunde wollte ich das Gerät wieder abstecken, Bildschirm schwarz - keinerlei Reaktion. Anderen original Akku eingelegt - nichts passiert. Nach paar Stunden bootete es wieder, aber blieb hängen.
Schriftzug Samsung S4Mini I9195 erscheint, dann bricht der Boot wieder zusammen.
Odin hat das Handy erkannt. Kies nicht.
Hab jetzt 3 verschiedene firmware geflasht. Odin zeigt 100% i.O. Erfolg an.
rebooten: alles wie vorher - bootloop
Muss ich evtl. eine 3-teilige Software aufspielen?
alle Firmware waren 1-teilig
Mir ist es im Grunde egal welches Android ich aufspiele. Hauptsache das Teil startet wieder. Hab ohnehin ein 5Smini als Ersatz gekauft.
Danke für eure Hilfe.
Gruß,
Sepp
etwas mehr Infos wären schon gut...
Was hast du für Software aufgespielt?
Ist dein Phone gerootet?
Hast du vor dem flashen einen System-/Cache-Wipe durchgeführt?
Welches Recovery hast du auf deinem Phone?
Hast du wie in den Anleitungen vorgeschrieben, Odin benutzt?
Hallo submain, anbei die Beantwortung Deiner Fragen. Ich spiele nochmal eine firmware auf, dann noch die Bildschirmfotos dazu
diese 3 Original Firmware hatte ich probiert. Fehler war immer der gleiche
I9195XXUCOE3_I9195VIACOF1_I9195XXUCOE3_Home.tar.md5
I9195XXUCOE4_I9195OXACOE1_I9195XXUCOE4_HOME.tar.md5
I9195XXUCOI4_I9195DRECOI1_I9195XXUCOI4_HOME.tar.md5
Nein
war bisher alles auf Originalstand
Ja
Hab auch probiert dass ich die firmware über SD Karte installiere. auch ergebnislos
Ja
Odin 3.10.7
Ich spiele nochmal eine firmware auf, dann noch die Bildschirmfotos dazu.
Zum Schluß wenn ich rebooten aktivieren, kommt das Android Symbol "Fehler". Danach startet der bootloop.
[doublepost=1453626899,1453623300][/doublepost]
SunSide schrieb:
Hallo, wegen dem Downloadlink schau mal hier:
Download I9195XXUBMJ7 I9195OXABMJ7 DBT zip
Und eine Anleitung für Odin findest Du hier:
[Anleitung] Flashen einer Firmware per Odin
Hallo SunSide,
der downloadlink ist aber eine .exe datei. bin etwas am zögern diese am Laptop auszuführen.... Dachte dies ist eine firmware welche ich über ODIN flashen kann?
der umgekippte Android-Kobold bedeutet, dass mit der Firmware was nicht funktioniert. Steht leider nich da, was der Fehler ist. Alle anderen Bilder sind korrekt... Odin zeigt keine Fehlermeldung. Probier mal die Firmware mit Kies3 zu flashen. Das ist die Samsung Software...
Wenn das auch nicht hilft, dann ist es die falsche Firmware. Musst ma schauen ob du noch andere Versionen runterladen kannst. Bei Sammobile zum Beispiel. Aber nich vergessen, vor jedem flash, ein komplettes Systemwipe durchzuführen.
Ansonsten gibt es noch die Möglichkeit die Firmware über ADB-Sideload zu übertragen...
ADB Sideload: Was ist das und wie funktioniert es?
Ich bin mir nicht sicher ob Kies3 mein Phone erkennt. Odin erkennt es nur wenn ich das Custom bestätigte.
Ich probier dies morgen Abend gleich aus. Danke
Kies3 und Kies2 probiert
"Das Gerät unterstützt keine Initialisierung"
und nun??? reif für die Tonne oder geht da doch noch was? Aber was.....?
Hatte schon nach einer mehrteiligen gesucht, jedoch nur immer einteilige gefunden. Hast Du einen Link?
Im Link ist ein Link zum SamFirm HighSpeed Downloader.
Damit bekommst Du eine mehrteilige, wenn Du Dich an die Anleitung hältst und auch den Haken bei "Binary Nature" nicht vergisst ;)
Reaktionen: seppi99
Probier ich heute Abend dann aus. Danke
habs probiert, und leider nicht geholfen. Hab den im anderen Thread geantwortet. Danke aber für diesen super link. Die Anleitung dort ist super hilfreich.
Hallo liebe Android Hilfe Gemeinde,
Leider ist durch das Flashen durch Odin auf dem s4 mini was schiefgelaufen. Das Handy startet garnichtmehr ,es kann nichtmehr in den Download Modus oder in den Recovery Modus booten. Es wird jedoch vom Pc als ,,RELINK HS-USB QDLoader 9008 (COM6) erkannt und ich vermute sogar ,dass das Handy lädt. Mein Ziel wäre es ,wieder in den Download Modus booten zu können. Habe einen USB Jig bestellt,jedoch bezweifle ich dass es gehen wird. Wäre für alles sehr dankbar ,für alle Links die mir helfen könnten!
Dann kann ich mir das Geld für eine Jtag Reparatur sparen :)!
Freundlicher Gruß ,
Androide141
Hallo und schönen guten Tag zusammen,
ich bin neu hier und hab eigentlich keine Ahnung von Handy´s und deren "Innenleben".
Mein Mann hat ein S4 mini und "spielt" andauernd daran herum - wie Männer halt so sind ;-)
Lange Rede kurzer Sinn: Er hat es geschrottet ... wollte es laden, es ging aus u nicht mehr an.
Nun hat er im Inet nachgeschaut und folgendes gemacht:
Laut, Power und Startknopf gleichzeitig, dann kommt er in "Recoverind booting", dann hat er wipe data/factory reset und dann wipe cache partition oder reboot system now ...
Leider hilft überhaupt nichts - es startet zwar neu, bleibt dann aber bei dem blinkenden Samsung-Logo hängen. Anhängend ein paar Fotos ... image2.JPG image1.JPG IMG_2244.JPG
Nun die eigentliche Frage: Können wir das Handy noch retten oder isses Schrott?
Vielen lieben Dank für Eure Hilfe ...
Mal eine Notfallwiederherstellung mit Kies versucht ?.
juni
bierma32
bierma32
V
viper24at
V
