Ultimate MultWwindows HACK
  • 6 Antworten
gangster1708
Features:
Quote:
- FULL Control over the MultiWindow Bar
- Add applications to the MultiWindow Bar with ease
- Remove added applications
- Alphabetical representation of the added applications (inside my app)
- No need for restarting the device
- Reads the settings of the old application, and gets the icons on each boot to fix a lot of bugs
- Control Framework-Defined applications, including Samsung PreDefined Ones
- Very flexible framework
The parts of this mod:
Quote:
- The Framework Hacks: Low-level (smali) edits to some parts of the framework, there are no side-effects, and you don't have to reenter your accounts after installing the mod. This part is the most important part, the additional mod communicates with the control app.
- The Control App: the app which allows you to choose which apps are to be added to the multi window functionality and/or control pre-defined framework-side ones.
The application now is COMPLETELY free.
That said, if you like the app, you can support it by donating any amount you want.
How to use this mod:
Quote:
Requirements: A supported base, deodexed, CWM recovery
- Flash modded framework files corresponding to your firmware
- Download the apk, move it to your sdcard, and install it normally
- Use the application, pick your apps
- Reboot, and then check the MultiWindow Bar
- Click on edit button on the MultiWindow Bar, and add the new apps to the bar.
NOTE: The control app works on all firmwares, but you have to choose the right modded framework files for your corresponding firmware.
MORE INFOS AND DOWNLOAD IN THE LINK BELLOW
[MOD][4.1.2][XXELK4][Deodex/Odex]MultiWindow Complete Control {Add/Remove/Control} - xda-developers
Reaktionen: olex. und FCB-Fan
Funktioniert wunderbar mit omega 33.1 Rom. Mit der MultiWindow Controller App lassen sich ganz einfach die gewünschten apps hinzufügen.
Hi
Was muss ich den da nehmen mein Rom CM10.1 Dxelk1
Danke
rup micha, diese mod läuft wohl eher auf stockbasierten sammy roms, genau wie dieser hier, der auf legend95k basiert, aber aktueller ist.
klick mich :)
hmmmm,schade ;)
naja kommt zeit,kommt rat
solltest du tatsächlich ein galaxy tab 10.1 besitzen, wie angegeben, ist diese forumssektion für dich die RICHTIGE!
stelle deine frage am besten nochmals HIER ! :)
Ja , aber auch ein S3 und ein Note10.1
