nonamw
DovaRom is a ASOP/PA based Rom with the brand new Halo System from Paranoid!
INSTRUCTIONS:
1. Download the "DovaRom" from below and the Gapps for 4.2.2
2. Backup your current Rom
3.Factory Reset/Wipe Caches
4.Install Rom and Gapps via CWM 5.Boot and have fun! (First Bootup can take 5min!!)
Features:
- Paranoid´s brand new Halo!
- Long press Home key feature!
- Paranoid Preference!
- Galaxy S3 settings!
- Pie Control!
- CM & Paranoid Wallpapers!
- Dual Boot kernel!
- More coming soon!
---------------------------------------------------------------------------------------------------------------------------------------------------------------------------- FAQ:
Q: "What is the Wallpaper/Icons Pack/ Widget from the Screenshots?"
A: Icons: Minimal UI || Widget: DashClock || Wallpaper: Origami LiveWallpaper.
Q: "How do I use the bubbles?"
A: Pull down the notification center and click the bubble icon at the top.
Q: "Is it ready for daily use?"
A: Yes, it is!
Q: "Can you add.....?
A: No, I have less time at the moment!
Bugs:
- WiFi Hotspot not working.
- Camera CAN crash! Reboot fixs it!
- Halo Bugs! I can´t do anything against that!
Version 1.0.1 [26513]
Entfernt.
