Cpt
Dauer-User
- 1.252
Mit dieser App wird die externe microSD-Karte des SGS3 verfügbar als USB-Massenspeicher
Quelle
Kopfgeldjaeger schrieb:This app will make the external microSD card of your SGS3 available as USB mass storage device.
So far, the app only executes the commands shown in this posts (thanks d4fseeker and Sakaschi btw!): xda-developers - View Single Post - USB Mass Storage mode? and xda-developers - View Single Post - USB Mass Storage mode?
It was only tested on my GT-I9300 so far.
Changelog
I don't have many posts on this forum yet - this will probably lead to some kind of mistrust. If that's the case for you, you can just use the commands linked in the post above or wait for the reaction of some other SGS3 users. Also, a trojan horse would probably not fit in the 8.8 KB apk fileCode:v1.1 - Added option for going back to MTP v1.0 - Initial release
Download:
v1.1: http://dl.dropbox.com/u/22760184/SGS3_Easy_UMS_v1.1.apk
v1.0: http://dl.dropbox.com/u/22760184/SGS3 Easy UMS.apk
(also, it's attached)
Credits: d4fseeker, Sakaschi, dAKirby309 (icon)
Quelle
