[ROM][I9301][6.0.1] *21.08.2016* ResurrectionRemix v5.7.3 [Beta]
  • 5 Antworten
Fifaheld
Fifaheld
Dauer-User
386
About Resurrection Remix ROM
Changelog
Installation
Downloads and useful links
Resurrection Remix the ROM has been based on CM,slim.omni and original Remix ROM builds, this creates an awesome combination of performance, customization, power and the most new features, brought directly to your Device
Many things that in previous versions were tweaked with mods, are now included by default in the ROM so, please enjoy!
Special thanks to, the CM team,OMNI team ,SLIMROMS and of course to all the supporters
Included Main Features
- 6.0.1_r61
-compiled with latest tool chains
-Navigation Bar
-Enable/Disable Navbar
-Navbar Ring Switch
-Navbar Ring Targets
-Navbar Button Customization
-Navbar Dimensions(Potrait & Landscape)
-Statusbar
-Brightness Slider
-Enable/Disable Show Notification Count
-SuperUser Indicator Switch
-Carrier Label
-Carrier Label Switch
-Carrier label Colour
-Quick PullDown Switch
-Smart Pulldown Switch
-Clock Customizations
-Time & date
-Clock Colour
-Day & date Toogle
-Center Clock/Right Clock Choice
-Battery
-Battery Bar customization
-Battery Icon Customization(circle/landscape/Potrait and more)
-Battery % Text
-Network Traffic Indicator
-Theme Chooser
-RR exclusive PITCH BLACK THEME
-Animations
-Toast Animations
-ListView Animations
-System Animations
-Gestures
-Gestures Anywhere Feature
-App Circle Bar
-Choose apps in App circle
-Trigger Width
-Trigger Hieght
-Trigger Position
-Recents Panel
-Clear All button Switch
-Clear All Tasks Switch
-Clear All Button Location(Top right,Top Left,Top Center,Bottom Left,Bottom Right,Bottom Center)
-cLock Widget
-CLock And Alarm Customizations
-Weather Panel Customizations
-Calender Events
-LockScreen
-Lockscreen Shortcuts
-Choose upto 5 Shortcuts
-100 Icons for Shortcuts
-Quick Slider Shortcuts
-Notification Drawer
-Weather Display Switch
-Quick Settings
-Choice to Add 20 Tiles
-Enable 2/3/4 Tiles per Row
-Enable Disable Birghtness Slider in Notification Panel
-Advanced Location Settings Switch(Choose Battery saving/Device Only/High Accuracy Directly in Notification Panel)
-LongPress Toogles to Enter Settings
-Buttons
-Backlight Timer
-Backlight Strength
-Navigation Bar left/Right handed mode Switch
-Power Menu
-Power Menu End Calls Switch
-Volume Buttons
-Wake Up Device
-Playback Control
-Keyboard Cursor Control
-Swap Buttons on Landscape mode
-Perfomance Profiles
-LCD Density
-Expanded Desktop Mode
-All New CM Audio FX App
-Heads Up Customizations
-Overall Smoothness Improvements
-Quick Unlock
-Optimizations to Improve Battery
-ALL cm13 Features
-AND MUCH MUCH MORE
Changelog
Installation Instructions
•Download latest Cyanogenmod 12.1 Build by N1Kolaa (Unofficial but soon Official) , Resurrection Remix 6.0.1,Gapps for 6.0.1 (Pico or Nano) and the Patch
•Flash Cyanogenmod 12.1 ,Reboot let it load
•Boot into recovery after first boot and wipe Data ,Cache ,Dalvik Cache
•Flash Resurrection Remix 6.0.1
•Flash after it the Patch
•Flash the GApps you chose and reboot
•Rom boots after a bit
Update Instructions
- Download the latest build of Resurrection ROM
- Take a nandroid backup
- Flash ROM using recovery
- Flash Gapps
- Wipe cache
- Wipe dalvik cache
- Reboot
- Enjoy!
Installation Files
build 5.7.3 Latest
PATCH
Download GApps
Big thanks to:
XDA developers
CM team
Omni team
Slim rom
aapav01
Rox
Quelle: XDA Forum
Reaktionen: pjozsef54 und Darkmenneken
Achtung: Aktuell hat diese Firmware ein Bug wie es aussieht das es nach dem Setup in einer Reboot Schleife Endet
EDIT: Die Nächste Build ist auch schon angekündigt und die soll wenn alles gut läuft "STABLE" sein
BUGS!
-Camera doesnt work at all
-Gps works but sometimes bugged
-Viper4Android doesnt work
-Random reboot after high cpu usage and high temp of mobile
Screenshot`s
Reaktionen: funkenwerner
Aber geil! Marshmallow fürs neo, hätte ich gar nicht mehr so mit gerechnet!
"Leider" läuft die final LP so gut, dass es lange dauern wird, bis die MM alltagstauglich wird.
Erstmal die nächste Build von RR für das Neo abwarten. Vielleicht legt sie ja einen guten Start nicht was alltagstauglichkeit angeht
Thema und Beitrag Nummer 2 haben ein Upate bekommen.
Neuer Patch eingefügt und neue Installations Anleitung + Bugs die es momentan noch gibt
Hi!
Danke für die ROM Vorstellung, es wäre schön wenn du den Startpost noch in Deutsch verfassen könntest! Dann kann es auch jeder User lesen.
