MrTheFredman
Ihr müsst die codes wie eine Telefonnummer in der Telefon APP eingeben
*#12580*369# SW & HW Info
#*#8377466# S/W Version & H/W Version
#*2562# Restarts Phone
#*3849# Restarts Phone
#*3851# Restarts Phone
#*3876# Restarts Phone
#*5376# DELETE ALL SMS!!!!
*#197328640# Service Mode
*#0228# Battery status (ADC, RSSI reading)
*#32489# Service mode (Ciphering Info)
*#2255# Call List
#*3888# BLUETOOTH Test mode
#*7828# Task screen
*#5282837# Java Version
*#232337# Bluetooth MAC Adress
*#232331# Bluetooth Test Mode
*#232338# WLAN MAC Address
*#232339# WLAN Test Mode
*#8999*8378# Test Menu
*#0842# Vibra Motor Test Mode
*#0782# Real Time Clock Test
*#0673# Audio Test Mode
*#0*# General Test Mode
*#2263# RF Band Selection / Network modes select
*#9090# Diagnostic ConfiguratioN
*#7284# USB I2C Mode Control
*#872564# USB Logging Control
*#4238378# GCF Configuration
*#0283# Audio Loopback Control
*#1575# GPS Control Menu
*#3214789650# LBS Test Mode
*#745# RIL Dump Menu
*#746# Debug Dump Menu
*#9900# Takes you to System Dump, where Disabling Fast Dormancy gives a boost to your network speed on some networks (both wifi and Gprs), same code to re-enable it
*#44336# Sofware Version Info
*#0289# Melody Test Mode
*#2663# TSP / TSK firmware update
*#03# NAND Flash S/N
*#0589# Light Sensor Test Mode
*#0588# Proximity Sensor Test Mode
*#273283*255*3282*# Data Create Menu
*#273283*255*663282*# Data Create SD Card
*#3282*727336*# Data Usage Status
*#7594# Remap Shutdown to End Call TSK
*#34971539# Camera Firmware Update
*#526# WLAN Engineering Mode
*#528# WLAN Engineering Mode
*#7412365# Camera Firmware Menu
*#07# Test History
*#3214789# GCF Mode Status
*#272886# Auto Answer Selection
*#8736364# OTA Update Menu
*#301279# HSDPA/HSUPA Control Menu
*#7353# Quick Test Menu
*2767*4387264636# Sellout SMS / PCODE view
*#7465625# View Phone Lock Status
*7465625*638*# Configure Network Lock MCC/MNC
#7465625*638*# Insert Network Lock Keycode
*7465625*782*# Configure Network Lock NSP
#7465625*782*# Insert Partitial Network Lock Keycode
*7465625*77*# Insert Network Lock Keycode SP
#7465625*77*# Insert Operator Lock Keycode
*7465625*27*# Insert Network Lock Keycode NSP/CP
#7465625*27*# Insert Content Provider Keycode
*#272*IMEI# then we will get buyer code (For samsung galaxy sIII mini csc code)
Noch das übliche:
Weder ich noch android-hilfe übernemen Haftung für schäden oder Datenverlust an eurem gerät!!!
*#2255# Call List
#*7828# Task screen
*#07# Test History
Noch das übliche:
