adl
Dauer-User
- 663
Danke, wollte nur einer Freundin helfen, die so arge Probleme mit dem Empfang hat und dachte man kann ja mal ein andres Modem flashen, aber sie hat das "G" Modell und ich das normale.
email.filtering schrieb:@DAD214 & Co.: Ihr seid alle herzlichst dazu eingeladen, hierbei aktiv mitzuarbeiten!
New build is already in progress - Milestone 6. This will be the last official release before Jelly Bean!
In light of the recent leak of the Samsung 4.0.4 ROM for the i9100, version XXLQ5, we advise you do NOT flash this ROM, its kernel, or any ROM based on this kernel at this time.
This kernel contains a hard-brick bug, which is known to cause (currently) irreparable damage to the device, resulting in what most users experience as a "bricked" phone.
If you have already flashed this kernel or a ROM based on it, do not panic. Firstly, do NOT use recovery to try to flash anything. Do NOT wipe or format, or flash anything from recovery! Don't try to flash another kernel or ROM!
If you wish to change ROM (please do this with caution and only if you understand what you are doing), use ODIN to flash a new kernel, and then proceed as normal to flash. Ensure the kernel you flash is NOT affected by the bug.
At present, we believe the following ROMs are affected by this issue:
[ROM][XXLQ5][July 07]CheckROM RevoHD™ V7 its True!
[ROM][ICS 4.0.4][04/07][XXLQ5][Stock][ODEXED][DE-ODEXED][ROOT BusyBox] by TugaPower
Leaked Samsung XXLQ5 4.0.4 ROM and anything using its kernel
email.filtering schrieb:Ich selbst bin derzeit ein bisschen in der zeitlichen Zwickmühle und werde daher wohl erst ab dem 23. Juli dazukommen diesbezüglich aktiv zu werden. Aber ich will es eben ordentlich machen, weshalb ich es bisher nicht einfach nur kopiert und hingeklatscht habe.
