![dumbo1](/data/avatars/s/212/212287.jpg,q1569149551.pagespeed.ce.1jSosmYd8v.jpg)
dumbo1
Stamm-User
- 389
!!!Weder ich noch Android-Hilfe übernehmen eine Haftung sollte durch das flaschen dieser Rom euer Note 7 defekt werden!!!
Diese Rom läuft sehr sauber, keinerlei probleme beim telefonieren oder sonstigen.
HIER noch der Link zu xda
- Photo Studio Fix
- Based on latest International BPH7
- ODEX (Current deodex tools not working properly)
- 560 DPI ROM
- Heavily Debloated
- 0 LAG (Super Smooth Experience)
- Huge Battery Improvement (as good as it gets)
- Latest SuperSU 2.78 included
- Latest Busybox included
- OTA Updater included
- Dolby Atmos
- Beats Audio
- Viper4Android
- Screen Recorder
- Torch
- AGPS Unlocked
- Satellite View Unlocked
- Screen Mirror Fix
- Wireless Tethering fully operational
- Applock Added
- XML's Modifications/Updated
- Power Menu with Extras
- Low Battery at 10%
- Critical Battery at 1%
- International Boot Animation
- Data Toggle (Power Menu & Quick Toggle)
- Capture Screen Toggle
- SBike Mode Toggle
- Invert Colors Togglek
- Wi-Fi Calling Toggle
- Bike Mode
- Ability to edit APN's
- Over 300 Fonts now available
- LTE Only Mode Unlocked
- Samsung Keyboard with Symbols (same key)
- Call/Message Block
- Save And Restore Text Messages
- Enable exit buttons in default browser
- Enable scheduled messaging option in messaging app
- Continuous music while using camera
- Enable manual rotation option in gallery
- NO SIM ALERT removed when no sim inserted
- Stability Fix
- Build.prop MODS
- Multi-User Support
- XML Addons
- Network Power Saving Mode Added
- Native Call Recording (REC Button)
- Auto Record Calls
- Messaging App Split-View Mode
- MyFiles Enable Directory Search
- XML Corrections @ others.xml
- SMS Character - 999
- SMS Max Slide Count - 999
- SMS Recipient Limit - 999
- SMS VCARD Enabled
- SMS Copy to SIM
- SMS Copy to SD Card
- SMS Priority Level
- SMS Folder View
- Etc, Etc... (Over 100 CSC Added Features/Enhancements)
- Floating Messages (Work in progress)
- TEKHD Quality[
- 560 DPI ROM
- Heavily Debloated
- Dolby Atmos
- Beats Audio
- Viper4Android
- Screen Recorder
- Torch
- AGPS Unlocked
- Screen Mirror Fix
- Applock Added
- SBike Mode Toggle
- Bike Mode
- Stability Fix
- Build.prop MODS
- XML Addons
- Auto Record Calls
- SMS VCARD Enabled
- SMS Copy to SIM
- SMS Folder View
- TEKHD Quality[
URv5.1
– Identify unsaved phone numbers added to Advanced Settings
– More options/features added (to the whole OS/Apps) (Calendar/Memo/Messages/etc…) See example below.
URv5
– Custom 3Minit Added
– TEKX Control Update
– TEKXodus N7 F/FD & TEKXodus N7 T version sync (Sync at URv5)
– Don’t like 3Minit? Ability to revert… (NO 3Minit) – Note 7 Section
– Outdoor Mode added to Display Settings
URv3.1
- USB/Wireless Plug/Unplug disable wake up
- 15% Darker status bar power button (for better visibility)
URv3
- Potato Clock (Align clock left/center/right, change clock's color/font/size etc...)
URv2.1
- Netflix Fix (Some users were having issues with Netflix… problem solved)
URv2
- New N7 Google/Samsung Signature Verification Cracked/Disabled
- Traditional Signature Verification also Disabled
- TEKHD's Extreme/Advanced Power Menu
- Ability to swap Extreme/Advance Power Menu Colors/Theme (via flashable Extensions)
- Default - No Ads (Ad Free ROM)
URv5
URv3.1
URv3
URv2.1
URv2
![http%3A%2F%2Ftekhd.com%2Fimages%2FTEKHD_Extreme_Power_Menu8.png](/proxy.php?image=https%3A%2F%2Fimg.xda-cdn.com%2F4-KYvdRNZoqZEtAoBpxMCkD4LBA%3D%2Fhttp%253A%252F%252Ftekhd.com%252Fimages%252FTEKHD_Extreme_Power_Menu8.png&hash=5cccc0190e092a39868b6fb480ff7759)
![http%3A%2F%2Ftekhd.com%2Fimages%2FTEKX_N7_Expansion_8.png](/proxy.php?image=https%3A%2F%2Fimg.xda-cdn.com%2FiRaOqF-WlGXeqmEt6_KYT9ArCx0%3D%2Fhttp%253A%252F%252Ftekhd.com%252Fimages%252FTEKX_N7_Expansion_8.png&hash=47156dee014573983db91592a5e7f7ac)
![http%3A%2F%2Ftekhd.com%2Fimages%2FTEKXodus_Red_Extreme_Power_Menu.png](/proxy.php?image=https%3A%2F%2Fimg.xda-cdn.com%2FuC6EuEvzJnRFamvvWnFZ-kbPLM8%3D%2Fhttp%253A%252F%252Ftekhd.com%252Fimages%252FTEKXodus_Red_Extreme_Power_Menu.png&hash=485d431e26342a7a88dd2ac9c5ecbe97)
![http%3A%2F%2Ftekhd.com%2Fimages%2FTEKXodus_Green_Extreme_Power_Menu.png](/proxy.php?image=https%3A%2F%2Fimg.xda-cdn.com%2FoS-FgPIh0K1jYYIUopnB_otmDI8%3D%2Fhttp%253A%252F%252Ftekhd.com%252Fimages%252FTEKXodus_Green_Extreme_Power_Menu.png&hash=704064905dc7b200a8da696f159950e3)
![http%3A%2F%2Ftekhd.com%2Fimages%2FTEKXodus_Yellow_Extreme_Power_Menu.png](/proxy.php?image=https%3A%2F%2Fimg.xda-cdn.com%2FEaQbqLnEGzmPwnete2xasXSGfU0%3D%2Fhttp%253A%252F%252Ftekhd.com%252Fimages%252FTEKXodus_Yellow_Extreme_Power_Menu.png&hash=3bb4506ce8be9b45447ff6070fd0be31)
![http%3A%2F%2Ftekhd.com%2Fimages%2FTEKXodus_Stock_Extreme_Power_Menu.png](/proxy.php?image=https%3A%2F%2Fimg.xda-cdn.com%2FEhuTWV8IUFll8kW_qs5vRoRbCdc%3D%2Fhttp%253A%252F%252Ftekhd.com%252Fimages%252FTEKXodus_Stock_Extreme_Power_Menu.png&hash=675f7f7a5deb09d0cc593e617db191a7)
![http%3A%2F%2Ftekhd.com%2Fimages%2FTEKXodus_Stock_Dark_Extreme_Power_Menu.png](/proxy.php?image=https%3A%2F%2Fimg.xda-cdn.com%2FMsBYg9Sj_HdeRtxB46E0RBPZLt4%3D%2Fhttp%253A%252F%252Ftekhd.com%252Fimages%252FTEKXodus_Stock_Dark_Extreme_Power_Menu.png&hash=51fca481f5da03b8d6efad2b32280827)
1. Odin hier Downloaden
2. Die neusten Bootloader und Modem hier downloaden
3. Rom hier Downloaden und auf sd-Karte kopieren, bevor ihr Twrp aufspielt die Entwickleroption frei schalten und die OEM-Entsperrung anschalten.
4. TWRP hier ziehen und über Odin flashen, wenn neu startet sofortLautstärke+/Home/Powertaste gedrückt halten. Wenn zu spät einfach Lautstärke -/Powertaste getrückt halten, startet neu
5. Im TWRP erst formatieren und dann wipe, delvik cache
6. Das Verzeichnis auswählen wo die Rom liegt und starten
7. den Anweisung von TEKHD folgen, dauert ca. 5-10min und startet neu
8. Spaß haben
9. Bei updates müsst ihr nicht neu installieren, nur drüber bügeln
natürlich vielen Dank an TEKHD
8. Spaß haben
