siebziger
Stamm-User
- 382
Blöde Frage was bringt eigentlich das Hollandrom?
siebziger schrieb:Blöde Frage was bringt eigentlich das Hollandrom?
nero99by schrieb:Aktuell nix mehr.
Ursprünglich ließ sich das aktuelle DBT-Rom nicht mit tr 1.x rooten; das PHN (Holland)-Rom schon.
Aber seitdem es Tr 2.0 gibt, funzt es auch mit DBT.
nero99by
palorent schrieb:Wenn ich mit Towelroot gerootet habe und mein Handy dann auf Werkseinstellungen zurück setze,ist root dann weg oder nicht?
blubbsa schrieb:Hat jemand schon Schreibrechte auf die SD Karte holen können? Wenn ja wie bzw. womit?
<?xml version="1.0" encoding="utf-8"?>
<!-- Copyright (C) 2008 The Android Open Source Project
Copyright (C) 2013 Broadcom Corporation
Licensed under the Apache License, Version 2.0 (the "License");
you may not use this file except in compliance with the License.
You may obtain a copy of the License at
http://www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing, software
distributed under the License is distributed on an "AS IS" BASIS,
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
See the License for the specific language governing permissions and
limitations under the License.
<!-- This file is used to define the mappings between lower-level system
user and group IDs and the higher-level permission names managed
by the platform.
Be VERY careful when editing this file! Mistakes made here can open
big security holes.
<permissions>
<!-- The following tags are associating low-level group IDs with
permission names. By specifying such a mapping, you are saying
that any application process granted the given permission will
also be running with the given group ID attached to its process,
so it can perform any filesystem (read, write, execute) operations
allowed for that group. -->
<permission name="android.permission.BLUETOOTH_ADMIN" >
<group gid="net_bt_admin" />
</permission>
<permission name="android.permission.BLUETOOTH" >
<group gid="net_bt" />
</permission>
<permission name="android.permission.BLUETOOTH_STACK" >
<group gid="net_bt_stack" />
</permission>
<permission name="android.permission.NET_TUNNELING" >
<group gid="vpn" />
</permission>
<permission name="android.permission.SYSTEM_GROUP_INTERNAL" >
<group gid="system" />
</permission>
<permission name="android.permission.INTERNET" >
<group gid="inet" />
</permission>
<permission name="com.sec.android.permission.CAMERA" >
<group gid="camera" />
</permission>
<permission name="android.permission.READ_LOGS" >
<group gid="log" />
</permission>
<permission name="android.permission.READ_EXTERNAL_STORAGE" >
<group gid="sdcard_r" />
</permission>
<permission name="android.permission.WRITE_EXTERNAL_STORAGE" >
<group gid="sdcard_rw" />
[COLOR=Red][B]<group gid="media_rw" />[/B][/COLOR]
</permission>
<permission name="android.permission.ACCESS_ALL_EXTERNAL_STORAGE" >
<group gid="sdcard_all" />
</permission>
<permission name="com.sec.android.app.sysscope.permission.SYSSCOPE_ACCESS_SYSTEM_INFO" >
<group gid="radio" />
</permission>
<permission name="android.permission.WRITE_MEDIA_STORAGE" >
</permission>
<permission name="android.permission.ACCESS_MTP" >
<group gid="mtp" />
</permission>
<permission name="android.permission.NET_ADMIN" >
<group gid="net_admin" />
</permission>
<!-- The group that /cache belongs to, linked to the permission
set on the applications that can access /cache -->
<permission name="android.permission.ACCESS_CACHE_FILESYSTEM" >
<group gid="cache" />
</permission>
<!-- RW permissions to any system resources owned by group 'diag'.
This is for carrier and manufacture diagnostics tools that must be
installable from the framework. Be careful. -->
<permission name="android.permission.DIAGNOSTIC" >
<group gid="input" />
<group gid="diag" />
</permission>
<!-- Group that can read detailed network usage statistics -->
<permission name="android.permission.READ_NETWORK_USAGE_HISTORY">
<group gid="net_bw_stats" />
</permission>
<!-- Group that can modify how network statistics are accounted -->
<permission name="android.permission.MODIFY_NETWORK_ACCOUNTING">
<group gid="net_bw_acct" />
</permission>
<permission name="android.permission.LOOP_RADIO" >
<group gid="loop_radio" />
</permission>
<!-- The group that releated with VPN -->
<permission name="android.permission.SAMSUNG_MODIFY_ROUTE" >
</permission>
<permission name="android.permission.SAMSUNG_TUNTAP" >
<group gid="vpn" />
</permission>
<permission name="android.permission.SAMSUNG_MODIFY_IPTABLES" >
<group gid="net_raw" />
</permission>
<permission name="com.sec.android.SAMSUNG_MODIFY_ROUTE" >
</permission>
<permission name="com.sec.android.SAMSUNG_TUNTAP" >
<group gid="vpn" />
</permission>
<permission name="com.sec.android.SAMSUNG_MODIFY_IPTABLES" >
</permission>
<!-- The group that releated with URL -->
<permission name="com.sec.android.SAMSUNG_GET_URL" >
<group gid="secnetfilter" />
</permission>
<!-- Group that can use gscaler -->
<permission name="com.sec.android.permission.USE_GSCALER" >
<group gid="graphics" />
</permission>
<!-- The following tags are assigning high-level permissions to specific
user IDs. These are used to allow specific core system users to
perform the given operations with the higher-level framework. For
example, we give a wide variety of permissions to the shell user
since that is the user the adb shell runs under and developers and
others should have a fairly open environment in which to
interact with the system. -->
<assign-permission name="android.permission.MODIFY_AUDIO_SETTINGS" uid="media" />
<assign-permission name="android.permission.ACCESS_SURFACE_FLINGER" uid="media" />
<assign-permission name="android.permission.WAKE_LOCK" uid="media" />
<assign-permission name="android.permission.UPDATE_DEVICE_STATS" uid="media" />
<assign-permission name="android.permission.UPDATE_APP_OPS_STATS" uid="media" />
<assign-permission name="android.permission.ACCESS_SURFACE_FLINGER" uid="graphics" />
<!-- This is a list of all the libraries available for application
code to link against. -->
<library name="android.test.runner"
file="/system/framework/android.test.runner.jar" />
<library name="javax.obex"
file="/system/framework/javax.obex.jar"/>
<library name="javax.btobex"
file="/system/framework/javax.btobex.jar"/>
</permissions>
pokkett schrieb:Geklappt!!!
