Mayday
Enthusiast
- 1.018
2.4.3.0
Fixed 2 bugs related to restore, one dealing with mknod failures (by bigbiff) and one dealing with restoring hardlinks (by Dees_Troy)
NOTE: If your backups weren't restoring correctly in earlier 2.4.x versions they should restore correctly now. Hopefully you didn't delete those backups. If you're still having problems, run the restore, go to advanced and copy log, then give us the log. Complaints without logs will be rightfully ignored.
Added a scroll bar to file selectors and listboxes courtesy of Tassadar
Added libblkid for more accurate detection of file systems and can now detect exFAT properly thanks to bigbiff
Added a screen dim effect 2 seconds before screen off on some devices
Finally fixed file selector crash (one of the joys of working with multi-threaded software)
Fixed loading of screen timeout setting during startup
Improvements and bugfixes to screen timeout code
Fix Military Time setting persisting
http://goo.im/devs/OpenRecovery/n7100/openrecovery-twrp-2.4.3.0-n7100.zip
http://goo.im/devs/OpenRecovery/n7100/openrecovery-twrp-2.4.3.0-n7100.img.tar
