[RECOVERY][N710x]PhilZ 6.48.4 [CWM 6.0.4.7] (06.07.2014)
  • 219 Antworten
Ja geht mit der neusten vom 8.12.
Hallo, bin vom Note-Forum wegen Gerätewechsel frisch ins Note2-Forum gewechselt und hab mal eine ganz blöde Frage:
Ich bin derzeit noch auf Stock-4.1.2, hab sie allerdings mit Framework gerootet. Kann ich das Philz-Recovery als tar einfach mit Mobile Odin flashen?
Ja.
Reaktionen: Edea72
Es gibt eine neue Version von PhilZ Touch! 6.07.9
LINK: Goo.im Downloads - Browsing n7100
Changelog seit der letzten Version für das Note 2:
All versions start of 6.02.2 are KitKat based
6.07.8 (28.12.2013)
- fix exiting "pause on logs" mode with virtual keys caused erroneous validation
- fix exiting screen off mode with hardware key could cause erroneous validations
- fix some devices could not exit "pause on logs" mode with screen touch
- bring immediate touch responsiveness after exiting screen off mode and "pause on logs" mode
- fix erroneous first menu validation when exiting screen off mode on some devices
- fix long press and move action could be triggered while swiping outside menus and returning to first touched area
- increase threshold for long press and move action for easier triggering
- small touch scroll optimizations
- improve touch responsiveness on low res devices
- code clean-up and optimization
- fix log text could overwrite clock/battery icons on some low res devices
- after successful zip install with sideload, hide the install background icon
- after installing zip with sideload, do not trigger "pause on logs" mode
- loki: sync latest sources (support LG G2 VS98012b)
- New: HTC One Verizon (m7vzw)
- New: Galaxy Note 3 International, Sprint and TMO (now built with cm-11.0 device tree and kernel)
- New: Galaxy S Relay 4G - SGH-T699 (apexqtmo)
- New: LG G Pad 8.3 (v500)
- New: Samsung Galaxy Premier I9260 (superior)
- New: Samsung Galaxy Mega 6.3 I9200 - SGH-i527 (meliusltexx)
- New: Samsung Galaxy Mega 5.8 i9150 (melius3gxx)
- New: Galaxy S i9000 support (galaxysmtd) : still needs cat /proc/mtd to add in extra.fstab
- New: Galaxy S3 verizon - SGH-I535 (d2vzw)
6.05.6 (21.12.2013)
- better fit text logs on non HD devices: stop slightly overwrite of bottom virtual keys separation bar and clock/battery area
- fix logs overwriting bottom virtual keys and progress bar in sideload mode
- add 5 extra partitions support in nandroid: can be added in fstab and will be auto detected
- custom backup and restore menu: move reboot item to top of partitions list
- custom backup and restore menu: auto hide all unused items
- advanced menu: hide /data/media toggle for non datamedia devices
- sync loki sources: add new LG devices
- SuperSU update to 1.86
- busybox: merge @Chenglu changes to support selinux (no tar --selinux yet)
- huge code clean ups and fixes
- New: Samsung Galaxy Mega 5.8 I9150 (melius3gxx)
- Note 3: fix device name to hlte
- Note 3: ramdisk changes to better handle enforced selinux and usb mount storage
- Note 3 (hlte): add modem support in backup/restore
- Note 3 (hlte): repack on @Chenglu ramdisk to fix time
- Note 3 (hlte): fix boardconfig for correct ums lun path (mount usb storage)
- i9100/n7000: add extra.fstab support
- i9100/n7000: use built in kernel exfat modules for faster writes to exfat cards
Rein in der Theorie sollte PhilZ nun kein Problem mehr mit KitKat ROMs haben!
Grüße
Reaktionen: sebden, Karakan und Astra-Celly
Hallo, ich hatte die ganze Zeit die 6079 von philz auf meinem Note. Hatte dauern Abstürze oder Fehlfunktionen beim aroma filemanager und beim dr. Ketan multitool habe dann mal die 5015 draufgeflasht und alles läuft prima. Ist die CWM 6045 etwas buggy ??
Danke ..
Zitat aus XDA:
philz_touch_6.07.9-n7100 seems buggy.
1) it laggy in everything, took up times to show everything
2) mounting aroma file manager seems not working. it hang while mounting devices. took up times to show mounting devices but then, it hang.
Die stabilste Version ist also bisher 5.15.0, welche jedoch keine KitKat-ROMs unterstützt..
Zu 1. = bei mir laggt nichts, PhilZ läuft seit 5.15.0 Top. Die 6.02.1 hatte auch nie Probleme mit meiner 64gb exFat SD-Karte und die neueste 6.07.9 läuft ebenso keinen Deut schlechter oder besser.
Zu 2. = ging nie bei mir ^^
Was man nicht vergessen darf, das navigieren auf sdcard1 dauert halt beim ersten mal etwa 3 Sekunden extra, für mich normal.
Als Änderung fiel mir nur auf das beim "Make clean to install new Rom" ein Fehler kommt das er ext-sd nicht löschen kann. Aber das wird obligat sein für Leute die von einer anderen Androidversionen kommen, bei mir existiert stattdessen sdcard0 und sdcard1 und die werden fachgerecht bereinigt.
Grüße
Habe ProBAM 1.2.4 KitKat probehalber geflasht, schien alles wunderbar. Mangels Features gegenüber den alten 4.3er aber nach wenigen Stunden verworfen.
ballonchef schrieb:
Hallo Leute,
ich habe versucht Philz Recovery mit Odin zu flashen, aber irgendwie hat das nicht geklappt. Habe mein gerootetes Note 2 im Odin Mode an den PC gehängt und geflasht (siehe Screenshot im Spoiler).
Wenn ich nun aber in die Recovery gehe (Vol up + Home + Power Button), sehe ich den normalen Samsung bootloader. Was habe ich falsch gemacht?
Ich habe das gleiche Problem, kann jemand weiterhelfen?
EDIT LÖSUNG GEFUNDEN
Nach dem Flash per Drücken von Lautstärke Oben + Menü + Power taste starten dann ist man im PhilZ CWM!
Volumen up heißt ja auch Lautstärke hoch
Reaktionen: fromfuture
Gibt ne neue version. Glaube ich. Hat jemand schon erfahrung.
Danke
Ja, es gibt in der Tat eine neue Version! Hier der ausführliche Changelog von der letzten bis zur aktuellen Version:
6.12.8 (30.01.2014)
- time and date menu text formatting and order
- version display edit
- add ntfs write support to devices using kernel modules instead of fuse
- loki: merge "Support LG Optimus F7 ZV5_02"
- zip installer: update loki binaries for LOKI devices
- zip installer: use new update-binary sources
- add NTFS kernel module support for more Samsung devices
6.12.2 (28.01.2014)
- manually set time and date in recovery
- support Qualcom time daemon to sync time with main system (credits to dougiebee)
- support RTC offset hack for Qualcom devices without a proper time daemon in system ROM (credits to dougiebee)
- option to drop to system set time and date commands (credits to dougiebee)
- set default nandroid compression level back to low
- roll out exfat-nofuse sources from dorimanx into various kernels from Samsung and other brands
- code fix and cleanup
- New: Oppo N1
6.10.6 (23.01.2014)
- update SuperSU to 1.91
- merge android_system_core changes to adb to fix push to extra storage paths
- do not use performance mode during install zip: fixes hang on unmount /system in updater-script when usb cable is connected
- i9505 ans US variants: update kernel to fix random hang on boot
- update to CWM 6.0.4.7
- merge "Fix up bu restore"
- ROM Manager: workaround to backup/restore to/from external storage
6.10.2 (20.01.2014)
- enhance touch init (fix touch on some Sony devices)
- really fix reading device max brightness value
- loki: merge "Support Open EU LG Optimus F6 and US Cellular Optimus F7"
- New: HTC One X+ (enrc2b)
6.10.0 (18.01.2014)
- read the device max brightness setting to fix brightness toggle on some Sony devices
- merge: "Populate mount menu with new mount/format matrix" - final version
- merge: "Use cat for adb backup."
6.09.8 (16.01.2014)
- New: Moto X variants: US Cellular (xt1055), Sprint (xt1056)
- New: Galaxy Tab 2 P3110 (p3110)
6.09.6 (15.01.2014)
- do not error on missing sd-ext when wiping dalvik cache
- merge: "su: Update for latest su daemon compatibility"
- merge "Clean up c formatting - 1"
- merge "Remove "Go Back" option from verify root and recovery options"
- merge "Fix potential chmod failures"
- merge: "Add a copy of the updater binary to the recovery resources"
- merge: "install: Support downgrade scenarios"
- merge: "install: Fix possible overflow condition in the updater "scanner""
- merge: "minui: do not use flexible array initialization"
- merge: "correctly mount tmpfs as /tmp in recovery"
- New: Sony Xperia SP (huashan)
- New: Sony Xperia T (mint)
- New: Samsung i9192 (serranodsub)
- New: Motorola Moto X variants: VZW (xt1060), GSM (xt1058), TMO (xt1053)
- New: Samsung Galaxy Note 10.1 LTE (n8020)
6.09.2 (12.01.2013)
- TWRP: merge "support use TW_USE_MODEL_HARDWARE_ID_FOR_DEVICE_ID"
- toggle prompt on low free space during backup
- SuperSU update to v1.89
- loki: merge "Support LG Vu 3."
- code cleanup
- New: US Cellular CH-R530U (d2usc) support
6.08.9 (04.01.2013)
- gesture action defaults changed
- long press and lift gesture action is now triggered after finger pressed for more than 1 sec
- do not include fb2png on non supported devices
- stop always rebuilding aroma intermediates
- Update: Samsung Exhilarate SGH-I577 (exhilarate)
- New: Galaxy Express AT&T (expressatt)
- New: Asus Transformer Pad TF300T (tf300t)
- New: Asus Transformer Prime TF700T (tf700t)
- New: HTC Evo 4G LTE (jewel)
- New: LG Optimus 4X HD P880 (p880)
- New: Galaxy Tab 3 8.0 SM-T310 - Wifi (lt01wifi)
- New: Galaxy Tab 3 8.0 SM-T311 - 3G (lt013g)
- New: Galaxy Tab 3 8.0 SM-T315 - LTE (lt01lte)
- New: Galaxy Note 3 Verizon (hltevzw)
- New: Galaxy Note 3 Canada (hltecan)
- New: Sony Xperia Z1 (honami)
- New: Sony Xperia ZU (togari)
6.08.7 (03.01.2014)
- fix Free Browse Mode folder cannot be changed in menus once first setup
- add back custom format fstype using vold (now patched in cm-11.0 thanks @cyanogen)
- disable journalling when formatting non voldmanaged extra storage in ext4 fstype
- merge "recovery: Add support for performance control"
- update CWM to v6.0.4.6
- loki: sync sources (support LG G2 D80010o)
- default backup compression level is now 5 (medium)
- v500: fix background width to 1200 pixels
- e970: fix OTA assert line breaking zip installer
- New: HTC Desire 601 (zara)
- New: HTC Droid DNA (dlx)
- New: Samsung Galaxy Grand Duos GT-I9082 (i9082)
Bitte noch nicht flashen! Aufgrund eines Fehlers landet ihr momentan noch nach dem Flash in einer Bootloop! Der Dev weiß bereits bescheid und arbeitet an einer Lösung.
Grüße
hab gerade gesehen, dass die Philz V 6.12.8 (30.01.2014)
jetzt auf 02.02.2014 steht.
Ist das die fehlerfreie Version.???
Danke
Genau, der Dev hat die Fehler in der Version behoben und das Recovery gegen die fehlerfreie Version ersetzt. Es soll nun keinen Bootloop mehr geben und es lassen sich problemlos 4.4.x-Roms flashen.
Download-Link:
http://goo.im/devs/philz_touch/CWM_Advanced_Edition/n7100
Falls ihr Fehler findet, dann lasst es uns wissen. :)
Der OP wird später angepasst.
moin,
in der FAQ von Philz bei punkt 10/11 steht ja was zu diesem Error 7 wegen zu alter Update-Binary...
Könnte mir das mal einer etwas genauer erklären ?
Wäre gerne Uptodate, aber woher bekomme ich den genau diese neue Update Binary für ein Rom ?
Klar kann man auch einfach diese abfrage in Philz ausschalten, aber ich hätte es schon ganz gerne ohne Error, er schreibt ja auch das die schon 2 Jahre alt ist, da wäre updaten schon nicht schlecht :)
Wenn mir da jemand die Update Binary hochladen könnte wäre ich auch dankbar.
Okay, dann versuche ich mal Licht ins Dunkel zu bringen.
Erst mal als allgemeine Info vorweg: In so ziemlich jeder flashbaren Zip befinden sich 2 Dateien, namens "Updater-Binary" und "Updater-Script". Das "Updater-Script" enthält die Befehle, die beim Flashen der ZIP ausgeführt werden sollen. Wenn du beispielsweise einen Kernel flasht, steht in der Updater-Script die Anweisung, die "boot.img" in die /boot Partition zu extrahieren. Die Befehle aus dem Updater-Script werden durch die Updater-Binary interpretiert und bearbeitet.
Bei älteren (2+ Jahre) Updater-Binaries kommt es wohl zu Inkompatibilitäten beim Flashen von KitKat ROMs, besonders bei der Überprüfung des Gerätecodes vor dem Flash.
Interessant für PhilZ User ist nun: Phil hat in der neusten Version der Recovery (die haben auch wir Note 2 User) eingestellt, dass auf jeden Fall die Updater-Binary von der ZIP hergenommen wird, welche du flashen möchtest und keine neue, die die Recovery mitbringt. Das KANN bei alten Updater-Binaries eben zu den Problemen führen, dass das Gerät beim Flashen nicht erkannt wird und der Flash abgebrochen wird.
Dafür gibt es 2 Lösungsmöglichkeiten:
1. Man kann sich aus einem neuen CM11-Release eine Updater-Binary ziehen und damit die alte vorhandene aus der ZIP ersetzen.
2. Man öffnet die Updater-Script mit einem Texteditor und entfernt sämtliche Zeilen, welche eine Produktcodeüberprüfung vor dem Flash auslösen. Logischerweise stehen die ziemlich weit oben.
Grüße
Hallo, ich hoffe, ich bin mit meinem Problem im richtigen Thread, aber da es wahrscheinlich mit Philz zusammenhängt poste ich es einfach mal hier.
Da ich immer zwischen 2 ROM´s switche (ff + Hurricane), hab ich natürlich von jeder ROM immer ein aktuelles Backup auf der externen SD ;).
Ich habe mir gestern die aktuelle Hurricane 10.0 geflasht (Alles mit Philz 5.15), und nach dem Einrichten ein komplettes Backup erstellt, welches auch
ohne Fehler erstellt wurde. Bin dann nochmal zur ff gewechselt, und wollte heute wieder die Hurricane zurükflashen.
Ich führe vor jeder Wiederherstellung eines Backups einen kompletten FullWipe aus, und formartiere nochmal nachträglich alles (Daten, Cache, Preload, interne SD usw.)
Das Backup kommt also auf ein komplett "sauberes" N2. Nur diesmal geht irgendwas nicht, das Backup der Hurricane wird zwar komplett
und ohne Fehler wieder hergestellt, doch sobald ich mein N2 dann neu starte, fährt es hoch bis zum Samsung - Schriftzug, und danach tut sich nichts mehr... :huh:
hab das Ganze jetzt 3 x wiederholt, immer mit dem gleichen Ergebnis. Backup wird komplett wieder hergestellt, N2 bleibt nach dem Neustart beim Samsung Schriftzug hängen.
Das ff - Backup lässt sich dagegen ohne Probleme zurückflashen bzw. danach startet mein N2 ganz normal.
Ist zwar jetzt kein Drama - notfalls flashe ich die ROM nochmal neu, doch vielleicht hat Jemand einen Tip, woran es liegen könnte, bzw. was man in so einem Fall tun könnte.
Gruß bootmanager :)
Jemand schon Erfahrung gesammelt?
Hallo Leute,
ich wollt mal wissen ob jemand weis was das sein kann das sobald ich auf die 6.19.2 wechsle ich bei Aromainstaller sporadische freeze bekomme, bleit einfach stecken.
Man kann ja nix falsch machen oder? Hab die cwm Version entschieden,
rauf ziehen installieren recovery reboot fertig oder?
Lg
Lulemator
Androidwizard
Androidwizard
DirtyKlot
DirtyKlot
DirtyKlot
DirtyKlot
