Cpt. Future
Gast
Neuer Kernel für unser Note 2 N7105 LTE
Wer auf Stock Kernel zurück will, dem wird auch geholfen
Die ZIP Datei entpacken und die .tar Datei mit Mobile ODIN oder ODIN flashen.
Kernel Versions
There are three variants of the kernel for each device
STANDARD (STD) - 1.6ghz FSync() enabled
OVERCLOCK (OC) - 1.8ghz FSync() enabled
EXTREME (EX) - 1.8ghz FSync() disabled
The standard version, has no modifications to the processor clocks or voltages and can be considered a direct replacement for the stock kernel, and with FSync() enabled is completely stable
The OC kernel automatically scales up to 1.8ghz, with the proven voltages and stability from the perseus kernel (the same frequency table is used), and with FSync() enabled is completely stable
The EX kernel also scales to 1.8ghz, and has FSync() disabled. It offers by far the best possible performance. In rare circumstances you must be aware that this can lead to data corruption and the need to wipe / reflash a rom back to the phone. 99% of people will have no issues with this, as it has been extensively tested and proven on my previous kernel, but the risk is there. Dont go moaning to me if you lose your data and haven't got a nandroid backup!
Kernel Features
- Built from official GT-N7100 sources
- 1.6 / 1.8ghz auto scaling
- Optimised VM memory settings, and global readahead
- Auto-rooting of any rom when flashed, even stock
- init.d script support
- CPU Voltage support through 3rd party apps
- Modified GPU DVFS utilisation steps for maximum GPU performance, far better than stock (this is NOT overclocking!)
- No logging / debugging of any kind for higher performance
- Decreased CPU frequency transition latency
- CRC32 slicing-by-8 algorithm
- SLUB allocator
- PEGASUSQ governor (default, others available)
- NOOP schedular, (default, others available)
- +50mb more free ram compared to all other kernels
- lots of other minor tweaks and changes
- ODIN TAR and CWM ZIPS available for all versions
- TouchWiz roms only
Quelle
Download - Current Version
For N7105 (LTE) phones
Changelog
2.10
- Rebuilt from new N7100T source, released Dec 3rd
- All rotation issues in 4.1.2 fixed
- GPU steps reworked for better speed and responsiveness
- Built with linaro 12.11 GCC toolchain, with -O3 optimisation level
- lots of other internal changes
1.06
- Added triangle away support
- Maybe fixed rotation / sensors in newer 4.1.2 TW roms?
1.05
- Fixed all voltage setting and reporting problems (you may need to clear app data in your chosen voltage app)
- Swapped to arm-eabi- 4.4.3 google toolchain rather than arm-linux-androideabi- 4.4.3
- Some minor bigfixes
- Decreased bus frequency increase threshold
1.02
- Fixed all video record problems
- Added custom boot animation support
v1.01
- Fixed video playback issues
- Fixed gameplay issues
- preliminary support for exFAT - works on a usb mounting device
v1.00
- Initial release
Kernel Versions
Kernel Features
- SLUB allocator
Quelle
Changelog
2.10
1.06
1.05
1.02
v1.01
v1.00
- Initial release
