Darkman
Ehrenmitglied
- 14.792
WICHTIGER HINWEIS: Weder ich, noch Android-Hilfe.de, übernehmen eine Garantie auf Erfolg, oder die Haftung für jegliche Beschädigungen an eurem "Galaxy Note 10.1". Wenn ihr nicht sicher seit, was ihr macht, könnt ihr hier gerne Fragen stellen, aber wenn ihr danach immer noch nicht genau wisst, was ihr tut: Lasst es bleiben!
Samsung Galaxy Note 10.1
GT-N8000 & GT-N8010 & GT-N8013
Offizielles TWRP Recovery
Ich war mal so frei und habe einen neuen Thread für das Recovery erstellt... so kann ich auch immer die News im Startpost selbst verändern...
What's new in 2.6.0.0:
Special Note: If you are running a custom theme, some of the changes in 2.6.0.0 will likely not be visible with your custom theme.
- Can encrypt a backup to prevent theft of private data from your backup files
- Updated graphics / icon courtesy of shift
- Updated exFAT to latest commits
- Fixed a problem with Samsung TouchWiz decryption
- Update SuperSU binary
- Fixed saving of backup partitions list
- Fixed saving of last used zip install folder
- Fixed backup of datadata on devices that use a separate partition for datadata
- Fixed some issues with the advanced wipe list (android_secure, can now wipe internal storage on data/media deivces and wipe data on the advanced list no longer formats the entire data partition)
- Fixed some problems with partitioning a SD card
- Various other bug fixes and tweaks
Notes about encrypted backups:
Why encrypt your backups? -- Most people store their backups on the device. Any app that has permission to access storage could potentially read your backup files and try to harvest your data. Encrypted backups also provide an added layer of security if you move your backups to other storage devices or to the cloud. The encryption that we're using is probably not strong enough for enterprise level security, but should be strong enough to make it significantly difficult to get to your data.
Encryption is using OpenAES which uses AES 128-bit cbc encryption. If you happen to use a longer password (over 16 characters) then the encryption strength improves to 192 or 256 bits. Do not forget your password. If you forget your password you will be unable to restore your backup. We don't encrypt the entire backup. Encryption is very CPU intensive and can be fairly slow even when we spread the workload over multiple cores even on the latest high-end devices. To ensure that encrypted backups don't take forever, we don't encrypt an
[FONT=Lucida Sans Unicode, arial]Es gibt nun für jedes Gerät (N8000/N8010/N8013) ein extra Recovery!! Dann gibt es mit CM10.1 auch keine Probleme mehr beim installieren...[/FONT]
Die Files findet Ihr in meinem Ordner bei Goo.im --> goo.im/devs/Darkman/Recoverys
kurze Erklärung!!
Die ***-ODIN.zip einmal entpacken und das ***.tar.md5 über ODIN (bei PDA einfügen) flashen.
Die Files OHNE ODIN.zip können direkt übers Recovery geflasht werden.... Habe ich aber nich getestet da ich kein TWRP nutze....
Quelle und Credits gehen an TeamWin Projects - TWRP 2.5 - | TeamWin ... ich habe die **.img nur gepackt für die weitere Verarbeitung
Sollte ich euch mit diesem Thread geholfen haben, würde ich mich sehr über ein
Credits & Big Thanks to
- Google - for the Android
- an das TeamWIN für das TWRP Recovery
Chancelog:
08.08.2013
- Update auf 2.6.0.0
15.04.2013
- Thread Erstellung
