OberstGrausam
Stamm-User
- 1.319
Ihr seid für euer Handeln verantwortlich. Weder ich noch Android-Hilfe übernehmen irgendeine Haftung, falls was schief geht.
Passt beim Overclock/Undervolten auf, da nicht jeder Prozessor mit den selben Werten gleich gut zurechtkommt.
- Compiled from Samsung N8013 Source
- Compatable with Samsung Touchwiz JB roms
- Linux Kernel Version 3.0.42
- Built with Stock Linaro Toolchain 4.4.3
- Full Samsung ExFat SD Support (64GB SD)
- Ability to Overclock to 1600mhz
- Voltage Control
- GPU Control
- Adaptive Body Bias Support
- Boeffla Sound Engine Support
- Triangle Away Support
- Enabled ARCH Power
- Faster USB charging
- Faster Virtual Memory Read Ahead
- Dynamic FSync Control
- ZRam Support and Edits
- Ramdisk Tweaks
- init.d support
- Busybox (/sbin)
- Adb unsecured
- Updated Adb, Adbd, Busybox and more...
- Disabled Wifi multicast for lower battery drain
- Disable Android Kernel Logging for better performance
- Advanced Power Emulation
- Black Crush Fix and MMC-Cap Bug Protection
- Increased timeout for some bad sdcards
- TCP, CPU Power optimizations and fixes
- Clean Display Name in Settings
- Many Miscellaneous Optimizations and fixes
- Added Governors
-Zzmoove
-Lulzactiveq
-Pegasusq
-Conservative
-Powersave
-Userspace
- Added Schedulers
-Zen
-Sio
-Row - CFQ is default scheduler
- Pegasusq is default governor
- Deadline sheduler edits
- Improved Performance
- Smooth
- Improved Battery Life
Downloads
Zeus Kernel 4.0
Older Builds:
Zeus Kernel V1
Zeus Kernel 2.0.0
Zeus Kernel 3.0
A big thanks to ptmr3, Yank55-lu, AndreiLux, Faux123, civato, AndiP and all those i have credited in my commits!
Source : Github
ROM Developers- You are more than welcome to use this kernel in your rom, just throw me some credit in your OP, Thanks!
Wenn euch der Kernel gefällt und ihr die Arbeit von Sbreen94 wertschätzen wollt, dann denkt über eine Spende nach!
Zeus Kernel 4.0
Older Builds:
Zeus Kernel V1
Zeus Kernel 2.0.0
Zeus Kernel 3.0
Source : Github
- Für Kernel spezifische Einstellung wird Trickster MOD empfohlen. Hier könnt ihr die CPU Taktfrequenz, die Voltages etc. einstellen
- Für die optimale Akkulaufzeit wird Pegasusq als Governor empfohlen, sowie CFQ oder ZEN als scheduler. Mehr zum Thema gibts HERE
- Exfat funktioniert nun komplett!
- Bitte macht vor dem Flashen ein Backup. Nur zur eigenen Sicherheit!
Wenn ihr im XDA Forum unterwegs seid, dann gebt sbreen94 ein Danke.
Originalthread auf XDA: [KERNEL][July 1][N8013/8010] Zeus Kernel 2.0.0 I CPU OC/UV I Zram I Tweaks I - xda-developers
Rom von sbreen für N8013/N8010: ★[ROM][N8013/010][7/10] Hyperdrive RLS3 ║ Tweaks ║ Unmatched Customization & Speed ★ - xda-developers
All credits belong to sbreen94!
Eine Version fürs N8000 ist in Arbeit. Ich werde es hier einpflegen sobald sie verfügbar ist.
Eigene Erfahrungen mit dem Kernel:
Ich habe den Kernel mittlerweile seit fast zwei Wochen am laufen und bin restlos begeistert! Das System läuft merklich schneller und flüssiger! Ich verwende die Einstellungen, welche für die optimale Akkulaufzeit empfohlen werden. Mit diesen Einstellungen schaffe ich bei gleicher Nutzung eine längere Nutzungsdauer als beim Stock Kernel oder bei Kcrudup Kernel (Zu finden, hier: http://goo.gl/AqT5a).
Zudem habe ich noch keine freezes, reboots oder ähnliches festgestellt. Ich kann ihn bedenkenlos als Alltagskernel empfehlen und lehne mich so weit aus dem Fenster zu sagen, dass er genauso stabil läuft wie der Stock Kernel.
Allerdings verzichte ich auf Overclocken oder Undervolten, da die Akkulaufzeit ohnehin schon exzellent ist und ich keine extra Leistung brauche!
Changelog:
5/24
Zeus Kernel v1
- Initial Release for N8013
7/1
Zeus Kernel 2.0.0
- Zram enabled
- Ramdisk Tweaks
- Add init.d support
- Add Busybox (/sbin)
- Adb unsecured
8/24
Zeus Kernel 3.0
- Upgraded to Linux Version 3.0.40
- Added Zzmoove Governor (really good battery saving gov)
- Tweaked up threshold in pegasusq governor
- Fixed charging voltages thanks to xda user in this thread!
- Disabled Android Logger by default
- Reduced Battery monitor wakelock timeout
- Increased Virtual Memory read ahead
- Added many optimizations to the Zram Functionalities
- Added GPU Control
- Removed Debugging from wifi, cifs and ntfs modules
- Fixed up Dynamic FSYNC
- Added intial support for exfat module loading
- Adaptive Body Bias Control Thanks to AndreiLux
- CPU Frequencies according to load
- Added MMC-CAP brick bug protection just to be safe
- Doubled the flexrate
- Added a ton of other optimizations
- More to enjoy!
9/12
Zeus Kernel 4.0
- Upgraded to Linux Version 3.0.42
- Added Full Samsung 64gb SD Card ExFat Support!!!!
- Added Boeffla Sound Engine 1.6.4 Support
- Added A Memory Leak/fix
- Cleaned up some code
- Cleaned up Display name and local version strings area
- More to enjoy!
