CrDroid Custom-ROM (Android 12) auf dem Poco F3
  • 3 Antworten
wakko
crdroid 8 (Android 12) wurde released:
crDroid Android - Browse /alioth/8.x at SourceForge.net
Update (Dirty über die Android 11 Version) lt. Anleitung hat bei mir ohne Probleme funktioniert:
Flashing Instructions:
Pre-installation:
TWRP : LINK TO NEBRASSY 3.6.0 : https://build.twrp.me/twrp-3.6.0_11-0-alioth.img
gapps : Nikgapps and Flamegapps are both tested
Magisk 23.0 for root (after first boot) - (Download from here)
First time installation:
if coming from Vasishath or “fastboot boot Nebrassy.img” : tap advanced/installing recovery ramdisk and select Nebrassy img
(re)boot recovery
flash Firmware (minimum requirement 12.5.3) (skip if you are on 12.5.3 or later)
flash crDroid (toggle auto flash twrp)
reboot recovery
(optional) flash Gapps (no auto toggle needed)
(optional) flash Magisk (no auto toggle needed)
(optional) flash DFE
format
boot system
Update installation:
skip format
Neues Update + neuer Flashing Guide (siehe XDA)
16-01-2022
* updated to crDroid 8.1 code
* updated to sec. patch level 2022.01.05
* added statusbar colored icon customization
* added statusbar notification count toggle
* added led controls (crdroid > notfications)
* added toggle to disable headsup for most apps
* added increasing ring volume toggle
* added option to choose battery percentage position (left/right)
* set 120 fps screen recorder
* added translation to pocket mode
* added translation to touch responsiveness
* synced with latest sources
* updated translations
* some other fixes and improvements
und weiter gehts 😋
18-01-2022
* configure powermenu lockdown pref on start
* added signal and wifi icon style theming
* added back icon shapes, icon packs, fonts customisation
* added an option to force pre-O apps to use full screen aspect ratio
* allow toggling camera/mic privacy indicator
* allow toggling location privacy indicator
* allow to suppress notifications sound/vibration if screen is ON
* added parameters for Hotspot 2.0
* fixup low mic input on Telegram and whatsapp calls on speaker
* tune zram performance
* switch to our own Pocketmode package
@wakko Wir sind hier ein deutschsprachiges Forum. Kannst du daher bitte die Release-Notes auf Deutsch bereitstellen? Danke!
Reaktionen: hurcoman und Zweeni
Plumpi
vander
V
  • tieger79
chgiceman
chgiceman
CustomRomundso
CustomRomundso
CustomRomundso
