merhans
Philosoph
- 1.362
-bald fertig-
Description
Vanilla RootBox is built straight from RootBox sources and always carries a very light installation with no extra/useless apps. This means, you can enjoy a pure Android experience combined with AOKP/CM features and some CM cherry-picks. Keep in mind Jelly Bean is only at the beginning stage of development and there will be minor bugs. Every RootBox releases are stable and always up to the challenge for a daily usage. If you're wondering how this ROM differs from any other AOKP roms out there, I only have one thing to say: Try it yourself and choose the one that meets your requirements.
Installation
-Nandroid Backup machen
-Update Recovery
-Factory Reset durchführen
-Installiere die passende .zip
-Installiere die Gapps
-flashe einen anderen Kernel
-reboot
kursives ist nicht zwingend notwenig
How to upgrade RootBox versions:
1. Download RootBox update
2. Flash RootBox update
3. Wipe Cache (Optional)
4. Wipe Dalvik Cache (Optional)
5. Reboot
RootBox Sources
www.github.com/Root-Box
Downloads
Official Releases - Nightlies
Stable | Nightlies | Google Apps
Mirror 1 - Basketbuild
Quick Tip: To avoid bad flashes and unexpected surprises, make sure you check the md5sum of the downloaded zip file against the one displayed on Goo.
Description
Installation
-Update Recovery
-reboot
5. Reboot
RootBox Sources
Downloads
