bandit1976
Inventar
- 16.072
Ist es noch nicht so, dass man während des Bootvorgangs die Rom auswählen kann?
I've just built v28, it's not a big update, actually only a log update. Now I'm working on the not showing boot menu on cm11s
Goggle schrieb:Da du CM11s als Primary hast siehst du das Bootmenü soweit ich weiß nicht.
Ich denke das der Bug mit CM11s demnächst gefixt wird.
Ok, I now understand why it doesn't show the boot menu on cm11s, the problem is that cm11s kernel is so old that it's missing a few commits needed for multirom. Not my fault at all. I'm not sure they will update it because those commits are old but they still didn't merge them in the shipping cm11s branch
KINGbabasula schrieb:To cm11s users (good news):
I don't really like to do this, but people want cm11s as primary so I've changed a file and did a separeted build for cm11s, you can find them here https://www.androidfilehost.com/?w=files&flid=18199 . As I said I don't like to build 2 times everything so cm11s version will be less updated
KINGbabasula schrieb:Updated the recovery. Now it has f2fs support
https://www.androidfilehost.com/?fid=23622183712461343
