MarcoG:
Dauer-User
- 2.275
Mit Erlaubnis von tbalden dem Developer der Kernels,stelle ich euch den CleanSlate Kernel für das Op8pro vor.
Ich habe ihn schon auf dem Pixel4xl genutzt und war sehr zufrieden.
Thread auf Xda
Thread auf Xda
- Flashlight Notification/Call blinking
- AdrenoBoost v2.2 - boost GPU for gaming
- Dynamic Schedtune Boost (EAS boosting) - credits to @joshuous
- Optimizations, compiled with Clang 10.0.1
- Vibrating Notification Reminder (DETAILS)
- Vibration power control, Notification booster In-Pocket
- Sweep to Sleep touchscreen gesture - highly customizable
- DoubleTap & LongTap on Sweep2Sleep's area gestures - new way to pull down android Notification Area or screen off
- KCAL Color Control (credit to @savoca)
- WireGuard VPN kernel support
- Face down screen off - new gesture, e.g. conveniently use together with 'flip to shh' to turn screen off
- CleanSlate Companion / Config - rootless app to configure
Facts:
- no root required, use /sdcard/uci_user.cfg file to configure 99% of the features without rooting. If you need tweak apps (e.g. EXKM / FK) you'll need rooting!
- built on top of kernel sources released by Google
- built with standard toolchain for stability and efficiency
- kept stable, no tweakings, just features
- stable and reliable, keeping close to stock except addition of Usability features
Unlocked OnePlus 8 Pro, stock or with magisk root
- BACKUP: make sure you have a stock image downloaded (boot img) from OnePlus before installing this!
- INSTALL:
Firstly install CleanSlate configuration and CleanSlate companion apps on your phone (both found down below in Download section). Set them up initially.
Copy unzipped hosts_k file to your sdcard (/sdcard/hosts_k) for k.adaway functionality in Chrome browser
- Non-rooted method: 0. download the non-rooted boot img
1. reboot to bootloader (adb reboot-bootloader)
2. temporary boot cleanslate_x.y.z_stock_20xx-xx-xx.img (fastboot boot cleanslate.......img)
3. if everything went fine, you can reboot to bootloader and flash the image: fastboot flash boot cleanslate.......img
4. reboot, enjoy
- Rooted method: 0. download the installer zip
1. install magisk and a capable kernel manager like EXKM/FrancoKernel
2. flash the cleanslate installer zip from the kernel manager
4. reboot, enjoy
3. reboot, enjoy
- INSTALL:
4. reboot, enjoy
4. reboot, enjoy
3. reboot, enjoy
- Update 1.2.4v2-
10.5.10.OnePlus sources
- Update tree
- Update 1.2.4
Official source update 10.5.10 release
- Updates from OnePlus
- Update 1.2.3 -
minor release
- Update Wireguard 26-june-2020
--- minor fixes
- Update 1.2.1 -
bugfix release
- fix Sweep2Sleep wrongly placed touch area for Op8Pro panel size
--- s2s and DoubleTap gestures should now work flawlessly
--- filtered area Long tap gesture is not working, it's a known bug
- Config app: add Presets view to Sweep2Sleep/Tap settings tab
- Update tree
- Update 1.2.4
- Update 1.2.3 -
minor release
--- minor fixes
- Update 1.2.1 -
bugfix release
Weder ich noch Android Hilfe übernehmen keine Haftung für Schäden,die durch das flashen entstehen
Für Oos 10.5.10
Für Oos 10.5.10
