[KERNEL] blu_spark (OOS)
  • 3 Antworten
Rosa Elefant
Gast
Und noch einer für das noch fehlende Custom-ROM-Unterforum. :blushing:
Der blu_spark-Kernel scheint in der OnePlus-Welt schon länger zu existieren, zuletzt gab es ihn für das OnePlus 5. Der Entwickler eng.stk hat als anscheinend erster Kernelmodifizierer eine angepasste Version für das OnePlus 5T (Oxygen OS) hochgeladen.
Funktionen:
  • Build with custom toolchain blu_naro-7.2 (cortex-a73.cortex-a53 targeted, build with latest Crosstool-NG from developer snapshot Linaro GCC 7.2-2017.10)
  • Full -O2 build with device and target flags enhanced, linaro build improvements, etc
  • Less is more: stockish OP5 builds based on OnePlusOSS/android_kernel_oneplus_msm8998
  • Systemless installer (doesn't touch system partition, OTA friendly)
  • Removed some debug and logging options
  • ARM enhanced performance and battery patches
  • CVE security patches, general upstream and CAF fixes
  • Several CPU Governors (blu_active modded own governor by default - fastlane mode available!)
  • No OC, use 100HZ base timer frequency
  • msm_performance input boost toggle on/off (enabled by default), tweaked cpu_boost driver
  • Enhanced TCP methods (westwood is default), Network and Wifi tweaks and updated drivers
  • Several I/O control tweaks, added schedulers FIOPS and ZEN v2 is default, tweaked and upstreamed filesystems (F2FS, ExFAT, NTFS, CIFS & NFS)
  • Removed verify and forced encryption (ext4 is still forced file based encryption - FBE), patched SafetyNet flags to pass CTS
  • Stock thermal driver by default (custom tunables available for ROMs with no thermal daemon)
  • Disabled hotplug, also on low battery levels (CTL and BCL)
  • Optimized crypto routines
  • Swap and adaptive LMK off by default, 60 apps on background by default
  • Vibrator Strength tunable and Gesture Haptic Feedback control (touchpanel)
  • KGSL fixes and reworked GPU driver (goes to idle @ 180MHz)
  • KCAL - Advanced color control for Qualcomm MDSS v2 (RGB calibration and post-processing features)
  • DASH charge and USB Fast Charge (USB mode up to 900mA with MTP on)
  • Battery/Notification LED control
  • Multimount fstab (you can use data and cache partitions as f2fs or ext4) with tweaked options
  • FS fsync toggle on/off
  • Wakelock blockers available
  • CDROM emulation on mass_storage (compatible with DriveDroid 0.10.36+)
  • init.d support (put your scripts in /system/su.d or /su.su.d [systemless SuperSU], /magisk/.core/post-fs-data.d [Magisk])
  • Compatible with Kernel Adiutor and others
Die Installation dürfte wie üblich per TWRP funktionieren.
Runterladen auf XDA:
[KERNEL] [blu_spark r51 OP5T] [OOS 4.7.*]
Ich hol den Thread mal aus der Versenkung. Nutzt jemand von euch diesen Kernel? Würde den gerne mal testen, was genau muss ich da machen? Bin auf der aktuellen 5.1.1 Stock Rom, mit Magisk gerootet. Einfach die zip in twrp flashen und gut, oder muss ich etwas beachten?
Einfach im drüber flashen und gut ist
Schon längst gemacht aber danke trotzdem :thumbup:.
  • Rosa Elefant
Rosa Elefant
  • Rosa Elefant
Rosa Elefant
  • Rosa Elefant
Rosa Elefant
