[Kernel] OnePlus 5 - Blu_Spark
  • 5 Antworten
CerealKiller77
CerealKiller77
Stamm-User
435
OnePlus 5 - Blu_Spark Kernel
Weder ich, noch Android-Hilfe.de übernehmen für die Durchführung dieser Anleitung eine Verantwortung oder Garantie.
Die Durchführung dieser Anleitung erfolgt auf eigenes Risiko !!!
1. Vorbereitung
Downloads:
Blu_Spark Kernel für OxygenOS und Custom ROM´s [KLICK]
Blu_Spark Kernel flashen:
  • Kernel downloaden
  • Ins TWRP booten
  • In TWRP auf Installieren tippen
  • Die geladene Kernel .zip Datei auswählen und flashen
  • Dalvik und ART Cache löschen
  • OP5 neustarten
Blu_Spark Kernel Features:
  • Build with custom toolchain blu_naro-5.4 (cortex-a57 targeted, build with latest Crosstool-NG from developer snapshot Linaro GCC 5.4-2017.05)
  • Full -O2 build with device and target flags enhanced, linaro build improvements, etc
  • Less is more: stockish OP5 builds based on OnePlusOSS/android_kernel_oneplus_msm8998
  • Systemless installer (doesn't touch system partition, OTA friendly)
  • Removed some debug and logging options
  • ARM enhanced performance and battery patches
  • CVE security patches, general upstream and CAF fixes (with time)
  • Several CPU Governors (blu_active modded own governor by default - fastlane mode available!)
  • No OC, set 100HZ base timer frequency (for now)
  • msm_performance input boost toggle on/off (enabled by default), tweaked cpu_boost driver
  • Enhanced TCP methods (westwood is default), Network and Wifi tweaks and updated drivers
  • Several I/O control tweaks, added schedulers FIOPS and ZEN v2 is default, tweaked and upstreamed filesystems (F2FS, ExFAT, NTFS, CIFS & NFS)
  • Removed verify and forced encryption (ext4 is still forced file based encryption - FBE), patched SafetyNet flags to pass CTS
  • Stock thermal driver by default (custom tunables available for ROMs with no thermal daemon)
  • Disabled hotplug, also on low battery levels (CTL and BCL)
  • Optimized crypto routines
  • Swap and adaptive LMK off by default, 60 apps on background by default
  • Vibrator Strength tunable and Gesture Haptic Feedback control (touchpanel)
  • KGSL fixes and reworked GPU driver (goes to idle @ 180MHz)
  • KCAL - Advanced color control for Qualcomm MDSS v2 (RGB calibration and post-processing features)
  • DASH charge and USB Fast Charge (USB mode up to 900mA with MTP on)
  • Battery/Notification LED control
  • Multimount fstab (you can use data and cache partitions as f2fs or ext4) with tweaked options
  • FS fsync toggle on/off
  • Wakelock blockers available
  • CDROM emulation on mass_storage (compatible with DriveDroid 0.10.36+)
  • init.d support (put your scripts in /system/su.d or /su.su.d [systemless SuperSU])
Man muss vorher erst den Speicher irgendwie anders formatieren, den als ich den Kernel installiert habe, hat der Kernel bei mir die komplette Partition gelöscht :sad:.
@Domi_nex
Und hast du von ext4 zu f2fs gewechselt ?
Bearbeitet von: CyPress1988 - Grund: Direktzitat entfernt. Gruß CyPress1988
Reaktionen: Domi_nex
Wechselt ja automatisch.
Deswegen war ich so verärgert das alles futsch war.
Keine Ahnung habe wieder das normale OxygenOS drauf gemacht.
Ich denke eher, dass alles futsch war, weil du den Bootloader freigeschaltet hast aber das ist normal, deswegen sollte man vorher immer seine Daten extern sichern.
Genau, beim unlocken des Bootloaders wird immer ein FullWipe durchgeführt.
Kosake77
Kosake77
Bajuware
Kosake77
Kosake77
suzanne1
