Mcenzie
Stamm-User
- 399
Hinweis: Weder Android-Hilfe noch Oneplus oder ich übernehmen eine Garantie oder jegliche Haftung bei Beschädigung eurer Smartphones!
Downloads :
- Index of /OnePlus3/6.0
______________________________________________________________________________________________
Installation :
- Download der Kernel .zip
- Flashen der Kernel .zip im TWRP
- Reboot
_______________________________________________________________________________________________
Features :
1 - Legendary battery life
2 - Flash & forget
3 - Typical interfaces like display adjustments, sound control, vibration control, and all that boring stuff
4 - Bypasses the verified boot flag for Android Pay compatibility (root still breaks Android Pay but that's your own problem)
5 - Idle power consumption reduced to the absolute minimum (if you have wakelocks from 3rd party apps you're obviously on your own)
6 - Support for FKUpdater's Performance Profiles
7 - Background apps limit raised to 60 from stock 32 (we have 6Gb ram, duh!)
8 - Magical support, I'm here every day, checking posts almost hourly, ready to help anytime (well, unless you fail to read the OP, which contains most info you need)
9 - Seemless integration with my app FKUpdater
10 - Probably more, check my github for all the details - the code speaks for itself
________________________________________________________________________________________________
Links :
XDA : [KERNEL] franco.Kernel - r5 - 9th December
Changelog : http://kernels.franco-lnx.net/OnePlus3/6.0/appfiles/changelog.xml
Downloads :
Installation :
- Reboot
Features :
2 - Flash & forget
Links :
