[ROM] [AOSP] [Nightly/Release] CarbonRom JB [XT925/XT926]
  • 8 Antworten
UWdus
UWdus
Dauer-User
329
Da hier recht wenig los ist mit Custom ROMs obwohl es ja seit ca. 2/3 Monaten auf XDA quasi Schlag auf Schlag geht, möchte ich hier mal mein aktuelles ROM vorstellen. Das ROM läuft sehr sehr smooth und hat klasse Mods. Den Original-Thread findet ihr hier: [ROM][AOSP] [Nightly/Release] CarbonRom JB [XT925/XT926] - xda-developers
Das ROM benötigt einen geöffneten Bootloader!!!
About Carbon
CarbonRom is an aftermarket firmware based on the Android Open Source Project. We are dedicated to fast, stable, and feature-filled roms, honesty and communication with our users, and openness with our code. We like frequent builds, with the very latest and greatest hardware support and fixes. We strive to not only provide you with the best rom we can build, but also to give back to the Android community and our fellow developers. For us, this is about creating something we can be proud of and hope you will enjoy.
Please feel free to look at, build, and use our code on CarbonDev GitHub.
We would like to thank CyanogenMod for their device trees, framework/settings mods and their code that was incorporated into this project. We also extend our gratitude to the devs whose code that we have incorporated. Proper authorship has been maintained and can be viewed on our repository.
Special thanks also go to Slim Rom for some of their features, PA, AOKP, and anyone else we may have borrowed commits from that hasn't been mentioned here. If you feel you have been unfairly left out, please - let us know.
Carbon Updates
Join us on these Social Media Channels to keep yourself up-to-date on all the latest Carbon news, updates, contests, and more! Join our completely open Google+ community for insider conversation with devs and other users.
Download Carbon
All Carbon downloads and further information such as features, changelog, and FAQ can be found on our goo.im page.
Goo.im Downloads - Browsing carbon
Changelog
For a detailed changelog, check out the changes made each night here:
Change Log
Support
We spend an astonishing amount of time developing this software. We can't spend much time on XDA as a result, so if you need support, please try the following:
1) Search. Search, search, search. Yes, you. I don't care how unique or important your question is, it's very likely someone has adressed it already. Especially if you're even close to new at this.
2) Read our FAQ, which can be found on our goo.im page linked above. It's new, but expanding fast. Just like us!
3) Ask a question in your device forum. Someone will no doubt try to help you. Warning: this help may come in the form of telling you it's a dumb question that has been asked before. See step 1 - such are the perils of asking questions when you haven't done the research yourself. Android is about helping yourself.
4) Ask a question on our IRC channel. Connect to #teamcarbon on irc.freenode.net or click here. You'll find several other Carbon fans and usually one or more devs as well. Please be polite.
Who is Team Carbon?
Andros11
BigShotRob
Bionic Beast
dg4prez
Kejar31
mattmanwrx
morfic
nocoast
pixeldotz
slick_rick
winner00
Remember, every penny you send to us goes right back into the rom. It's used for hardware, server costs, etc - all the things that help us make Carbon better with every release. Your support means the world to us! If you've enjoyed Carbon, please consider a donation toward this goal. Thank you, and we hope you continue to enjoy Carbon!
Der ursprüngliche Beitrag von 09:12 Uhr wurde um 09:20 Uhr ergänzt:
In der aktuellen Nightly vom 08/07/2013 gibt es Probleme mit Bluetooth-Audio, die zu einem Reboot des Telefons führen. Dies ist nicht ein Problem des ROMs - der BT-Audio Bug kam mit der Kernel-Version 3.0.85 und somit sind alle AOSP und CM ROMs davon betroffen.
Ansonsten:
- GPS super fix!
- Kamera funktioniert einwandfrei
- Akkuverbrauch würde ich als normal bezeichnen (nicht besser als beim Stock ROM)
Insgesamt bin ich hochzufrieden. So smooth ist mein Stock ROM noch nie gelaufen. Wie @Patrick89bvb es so schön beschrieben hat: Wie eine neues Telefon :)
Reaktionen: Dr.No und p1312k
welchen Link soll ich nehmen? Ist die mb886 die Richtige für das RAZR HD?
xt925 wäre richtig, wenn ich dich richtig verstehe. :)
Reaktionen: Dr.No
ok. Danke.. Steht zwar auch in der Nightly, aber in einem Thread hier hatte ich was von mb886 gelesen. ohne Englisch ist einfach Mist :sad:
mb886 ist der Motorola Atrix HD.. aber ein wenig Englisch geht immer (auch zum Schluss mit Google Translator). Mein Englisch ist nicht viel besser (Abschluss Note 5) und trotzdem bin ich in London klar gekommen und die wenige englische Kunden die ich Betreuer verstehen mich gut. :) Also immer mit der Ruhe. :D
Auch mit der Nightly vom 17.07 funktioniert das Bluetooth-Audio-Streaming nicht und verursacht einen Hardboot.
Ich habe jetzt Bytecodes N38 Kernel geflasht, mit dem das Problem angeblich behoben sein soll. Kann ich aber frühestens heute abend ausprobieren.
Naja, das ist wohl ein allgmeines Kernel Problem, ich warte ab. Zurzeit nutze ich auch mein MW1 nicht für Musik hören. Maximal um zu telefonieren, da passiert es zum Glück nicht.
Hallo, habe CarbonRom erfolgreich geflasht aber mein xt925 findet mein WLAN nicht.....Tablet und Laptop finden es sofort.....ist das ein bekannter Bug? habe die letzte Version geflasht...
Greetz Johannes
Hatte ich auch bei der vom 22. Hab dann einfach ne älter geflashed und dann ging es wieder - wobei bei der Version vom 27.7 geht mein WLAN....
Gesendet von meinem XT925 mit der Android-Hilfe.de App
