ROOT Moto G - Anleitungen, Fragen und Diskussion
  • 340 Antworten
FrostStep schrieb:
wähle mal *#*#7378423#*#*
Sobald ich das eingegeben habe, verschwindet die Eingabe und es passiert nichts.
Folgenden Befehl mit Fastboot ausführen:
fastboot oem device-info
(bootloader) 'device info' is not supported oem command
(bootloader) See 'fastboot oem help'
FAILED (remote failure)
finished. total time: 0.031s
> fastboot oem help
(bootloader) config...
(bootloader) fb_mode_set
(bootloader) fb_mode_clear
(bootloader) bp-tools-on
(bootloader) bp-tools-off
(bootloader) qcom-on
(bootloader) qcom-off
(bootloader) unlock
(bootloader) lock
(bootloader) get_unlock_data
(bootloader) cid_prov_req
(bootloader) read_sv
(bootloader) off-mode-charge
OKAY [ 0.036s]
finished. total time: 0.038s
fastboot unlock-info
Teste das mal
Versuch doch einfach mal TWRP zu flashen, da das nur mit offenem Bootloader klappt.
commands:
update <filename> Reflash device from update.zip.
flashall Flash boot, system, vendor, and --
if found -- recovery.
flash <partition> [ <filename> ] Write a file to a flash partition.
flashing lock Locks the device. Prevents flashing.
flashing unlock Unlocks the device. Allows flashing
any partition except
bootloader-related partitions.
flashing lock_critical Prevents flashing bootloader-related
partitions.
flashing unlock_critical Enables flashing bootloader-related
partitions.
flashing get_unlock_ability Queries bootloader to see if the
device is unlocked.
flashing get_unlock_bootloader_nonce Queries the bootloader to get the
unlock nonce.
flashing unlock_bootloader <request> Issue unlock bootloader using request
flashing lock_bootloader Locks the bootloader to prevent
bootloader version rollback.
erase <partition> Erase a flash partition.
format[:[<fs type>][:[<size>]] <partition>
Format a flash partition. Can
override the fs type and/or size
the bootloader reports.
getvar <variable> Display a bootloader variable.
set_active <suffix> Sets the active slot. If slots are
not supported, this does nothing.
boot <kernel> [ <ramdisk> [ <second> ] ] Download and boot kernel.
flash:raw boot <kernel> [ <ramdisk> [ <second> ] ]
Create bootimage and flash it.
devices [-l] List all connected devices [with
device paths].
continue Continue with autoboot.
reboot [bootloader] Reboot device [into bootloader].
reboot-bootloader Reboot device into bootloader.
help Show this help message.
options:
-w Erase userdata and cache (and format
if supported by partition type).
-u Do not erase partition before
formatting.
-s <specific device> Specify a device. For USB, provide ei
ther
a serial number or path to device por
t.
For ethernet, provide an address in t
he form <protocol>:<hostname>[:port] w
here <protocol> is either tcp or udp.
-p <product> Specify product name.
-c <cmdline> Override kernel commandline.
-i <vendor id> Specify a custom USB vendor id.
-b, --base <base_addr> Specify a custom kernel base
address (default: 0x10000000).
--kernel-offset Specify a custom kernel offset.
(default: 0x00008000)
--ramdisk-offset Specify a custom ramdisk offset.
(default: 0x01000000)
--tags-offset Specify a custom tags offset.
(default: 0x00000100)
-n, --page-size <page size> Specify the nand page size
(default: 2048).
-S <size>[K|M|G] Automatically sparse files greater
than 'size'. 0 to disable.
--slot <suffix> Specify slot suffix to be used if the
device supports slots. This will be
added to all partition names that use
slots. 'all' can be given to refer
to all slots. 'other' can be given to
refer to a non-current slot. If this
flag is not used, slotted partitions
will default to the current active sl
ot.
-a, --set-active[=<suffix>] Sets the active slot. If no suffix is
provided, this will default to the va
lue
given by --slot. If slots are not
supported, this does nothing. This wi
ll
run after all non-reboot commands.
--unbuffered Do not buffer input or output.
--version Display version.
-h, --help show this message.
Braucht man da kein Root? Gehen dann die Daten verloren?
Wenn ich das hier (Motorola Moto G 2013) so lese, dann ist mit "Download the correct image file and copy the file into the same folder as your adb and fastboot binaries." der "platform-tools"-Ordner in Windows gemeint?
Nein zum flashen von TWRP braucht man kein Root sondern nur einen offenen Bootloader.
Und es wird lediglich die Stock Recovery überschrieben. Nichts gelöscht.
Die Images die du flashen willst, steckst du in den selben Ordner wo auch ADB und Fastboot drin ist.
Der Ordner müsste "Minimal adb and fastboot" heißen.
Google sagt, dass "Minimal adb and fastboot" eine Alternative zu Android SDK ist. Also muss bei mir "platform-tools" sein
Also, ich habe diesen Befehl eingegeben:
fastboot flash recovery twrp.img
und das kam dann:
(bootloader) has-slot:recovery: not found
target reported max download size of 536870912 bytes
sending 'recovery' (10014 KB) ...
OKAY [ 0.328s]
writing 'recovery' ...
OKAY [ 0.374s]
finished. total time: 0.718s
Und jetzt?
Also, dein Bootloader ist offen!
Hast erfolgreich TWRP geflasht.
Jetzt kannst du ja mal ins Recovery booten,
Kenne nur die Tastenkombination beim Moto G nicht.
Bin hier eher aus Zufall in deinen Thread rein geraten [emoji28]
Wenn ich das mache, kommt wieder diese Fehlermeldung mit "kein Befehl":
und nach einer halben Minute wird rebootet.
So, nochmal in den Bootloader booten, TWRP nochmal flashen, danach das Gerät einfach vom PC trennen und ausschalten.
Dann mit der Tastenkombination ins Recovery booten.
Wenn wieder dieses "Kein Befehl" kommt
Dann mal den powerbutton gedrückt halten und dann kurz Volumen up drücken.
Danke, jetzt hat's funktioniert. (rooten kann ich damit nicht? Kann man damit Backup vom ganzen System machen?)
Nur hängt sich TWRP beim Sperrbildschirm auf und nichts läuft mehr. "Swipe right to Unlock" funktioniert nicht. Ich habe ihn deaktiviert.
Ich habe jetzt BackUp gemacht, wie kann ich ihn auf meinen PC ziehen? Der Ordner "TWRP" ist leer.
Doch du kannst rooten. Einfach die aktuellste SuperSu.zip flashen.
Danach noch wipe Cache und dalvik.
Komplettes Systembackup geht natürlich auch.
Einfach mal n bisschen googlen, du brauchst noch n wenig Fachwissen [emoji4]
Reaktionen: stardust011
habe mein Moto G XT1039 mit Android 5.1 auf der Motorola Seite ensperrt. Hat alles funktioniert. Jetzt wollte ich das Handy mit der CF-Software rooten. Der Rootvogang belibt mit der Meldung cmd:flashig unlock hängen
Auch ein Rooten mit KingRoot vom PC schlägt fehl. Hat jemand einen Tip, wie ich meine Hand doch noch rooten kann
Willkommen im Forum,
ich habe dich in den bestehenden Thread verschoben, den du dir mal ansehen solltest, ob Du vielleicht eine Lösung findest, bis jemand Dir antwortet.
Bitte in Zukunft erstmal umsehen, ob solch eine Frage schon mal in letzter Zeit gestellt, oder wie dieser Thread angepinnt, also oben festgehalten wurde.
Vielen Dank!
flashing unlock im Zusammenhang mit Root kenne ich gar nicht.
Normalerweise ist der beste Weg an Root zu gelangen TWRP zu flashen und dann einfach mittels TWRP SuperSu zu installieren. Um so One-Click Lösungen wie KingRoot mache ich einen großen Bogen.
HALLO an die lieben Experten!
Auch ich will mein Moto G2 rooten (und danach das G1 X1032 auch wieder, der Root verschwand beim Systemupdyate vor Jahren leider urpötzlich)
ICH will NICHT spielen, sonder Sicherheit, Privatsphäre und Full-Backups jederzeit. Darum gehts.
Leider stosse ich auf diverse Probleme, die ich alleine als Laie doch nicht gelöst bekomme.
Ich habe nun Abend Morgen Tag zugebracht mit dem Webseiten lesen: Zahllose 1-Click-Tools mit toten Links (incl. CHIP und AndroidPit), 5 Anleitungen, die ich z.T. nicht checke oder auch hier tote Links. Zuletzt endlich das hier entdeckt und probiert: [TUT] Backup, Unlock BL, Root, Lock BL
Leider keinerlei Erfolg auch hier:
mit "rechter Maustaste-> Als Administrator starten" auf die superboot-windows.bat
- nichts geschah... Und ohne Admin führte es zum Reboot des Moto G.
Ich bitte um freundliche Antworten auf meine Fragen und um tatkräftige kompetente Hilfe:thumbup: - als Einstieg in diese doch recht neue Welt!
Ausgangslage:
  • Win7 Pro 64bit +
  • Moto G2 X1068, System 24.41.34 titan_retde, DualSIM -
  • bootloader heute unlocked mit adb-treiber-tools.zip und fastboot - Ich update gerade auf Android 6.0
  • Android Studio, neuer google USB Treiber, neue Motorola Treiber
  • X1068 wird im Explorer erkannt und ist ansteuerbar (natürlich im Normalbetrieb)
  • adb funtioniert sonst aber NICHT - adb BAckup sowie HOLO BAckup enden mit
    adb server is out of date. killing...
    * daemon started successfully *
    adb: unable to connect for backup
    C:\Users\user\Downloads\Moto G\root_logo_cwm_tools Moto G>
  • mit "adb devices" befehl kommen auch keine Einträge zurück, egal, von welchem meiner vielen adb.exe ordner aus ich das starte
  • Im fastboot-Modus heißt es "USB verbunden"
  • beim folgendnen Starten der superboot-windows.bat als Admin verschwindet das cmd-Fenster sofort wieder und es passiert gar nichts
BITTE erklärt mir Newbie doch freundlichst:
  1. warum kriege ich keine adb Verbindung ergo Backup (ich habe ja noch KEIN root)
  2. was mache ich falsch nach de rAnleitung im TUTORIAL
  3. wo kriege ich noch gute Recoverys her??? bei CWM steht "Suport eingestellt - keine Weiterentwicklung" - bei TWRP heiß es immer, es sei auf dem G2 "buggy"??
  4. Welches der vielen Tools zum flashen? GEht das auch, wenn ADB nicht funktioniert?
  5. Verliere ich A6.0 beim rooten via Flash TWRP? Oder bleibt es da?
  6. Welches ROM alternativ flashen? Ich lebe gern mit dem Custom, oder etwas noch besseres zum Energiesparen bitte empfehlen
  7. was meint "wipe" und "dalvik" in den Kurz-Anleitungen ? Z.B. hier: Mototool
  • (Last: Kann ich mit Root und ROM auch die Tools von Motorola zur Migration nutzen? Oder besser via MyPhoneExplorer bzw. Einzel-Backups? Ich vertraue den Amis da eh nicht wirklich ger´ne meine Daten an. Aber 133 Apps wurden einfach so, ohne mein Zutun schon mal übernommen... OHNE Google-Account Login...)
Vorab DANKE fürs Hirnschmalz und die GEduld!
Bitte gerne auch als PN und hier, schaue jetzt öfters nach.
Gruß vom voip_ich
P.S.: Kann es iregendwie stören, dass ich die früheren cmd-Fenster immer offen ließ? Ich wollte vergleichen, ob die gleichen Fehlermeldungen kommen.
P.P.S. Die früher hier ROOT Moto G - Anleitungen, Fragen und Diskussion empfohlenen Methoden und Links sind veraltet :-( Z.B. die MoDaCo Links hier http://wright.modaco.net/files/r1-motog-modifiedrecoveryroot.zip
Z
  • Zeitmanagement
Zeitmanagement
Z
476605
Stromba
