AA1973
Enthusiast
- 6.003
Hier der OP von Mioze für die neue OR Version ... und der Link
http://forum.xda-developers.com/showthread.php?t=1242259
This is a modified OpenRecovery (Skrilaz_CZ) based on Androidiani Recovery (89luca89&Azhad) with some enhanced features for Milestone XT720.
Features:
[*]Main OR menu streamlined
[*]Most Androidiani menu options have been moved into OR > Other Utilities
[*]Add ext3/4 support (thanks fjfalcon)
[*]Added SD Card Utility (OR > SD Card Utility)
[*]Added preference for display brightness in OR (OR > Settings > Brightness)
[*]Added utility to reinstall orbootstrap (OR > "Other Utilities" > "Re-install orbootstrap")
[*]New sh hijack binary will boot to fastboot bootloader if volume-down is held (OR > "Other Utilities" > "Re-install orbootstrap" to enable). This should be compatible with all ROMs and stock.
[*]nandroid: removed ability to backup partitions that always fail (this means "Backup All" works now)
[*]Fixed OR > "Wipe Dalvik Cache" bugs (previous OR/AOR don't clear them all)
[*]Added OR > "Power Off" (helpful when phone is being stupid about charging)
[*]Minor update to sdcard-info.txt output
[*]XT720 basebands added (OR > Change Basebands)
Please note that although most Androidiani menu options have been included in the Other Utilities menu item, that does *not* mean I have tested them on XT720.
Installation:
Download link: http://www.multiupload.com/J8Q15SHP4S
[*]Make a nandroid and backup your sdcard
[*]Download OpenRecovery-XT720-01.zip (it contains /sdcard/OpenRecovery and /sdcard/OpenRecovery.zip)
[*]Rename the old /sdcard/OpenRecovery folder to /sdcard/OpenRecovery.bak
[*]Extract OpenRecovery-XT720-01.zip onto the SD card. This will create a new /sdcard/OpenRecovery directory.
[*]Optional: Move/copy all files from /sdcard/OpenRecovery.bak/updates to the new /sdcard/OpenRecovery/updates directory
[*]Optional: Reboot into OR. Select "OR" > "Other Utilities" > "Re-install orbootstrap"
Github: https://github.com/Mioze7Ae/openrecovery_xt720
Thanks: skrilax_cz, 89luca89, Azhad, fjfalcon
MilestoneXT720 - CM 6.3.0 RC3 [FroYo - 2.2.1]
Features:
Installation:
