[OS, 4.2.2] irvanus' OS
  • 149 Antworten
I
irvanus
Update: Improvements on google map and AGPSvements on google map and AGPS
Read this posting about the release of the stable version!
jelly bean rom 4.2.2 for cynus t1 / imo S88 / myphone a898 / q smart S22 / Intex Aqua flash.
changelog:
-new version from base port rom.
-new custom kernel from mr.trizet.. please thanks for him
-Compas and OTG support
-improvements and revisions to the various parts of the system rom.
-auto focus on the camera has been working with kernel revisions.
-wifi, bluetooth, gps, fm radio ... works well.
-and others
Link to OS (~F1B)
Update: V1.2
Changelog:
-support switch 3G for second simcard
-improvement on google map and AGPS
-improvement on gallery and music
-auto mount usb storage on otg
-improvement on settings
-new kernel with down voltage.
-odex rom
-and other.
Link to OS v1.2 (~F8)
thank you very much for :
-mr. tri setiyanto for kernel and its support.
-Dev team imo S88 on whatsapp
-group facebook imo S88
I remember not responsible for any possible problems caused by installing this rom. any risk to your responsibility
Reaktionen: opg2000, naklar, MKKLR21 und 2 andere
Hello irvanus ,
which kernel source did you used ??
LG nicklas519
PS : Try to replace these files
system/lib/libcamalgo.so
system/lib/libcameracustom.so
system/lib/libmhaldrv.so
to fix the autofokus .
@irvanus:
I tested this ROM and had some minor issues: YGPS isn't available in engineer mode (even after installing the patch). There are still some menu items in english when setting system language to german (not really a problem for me).
Autofocus doesn't work (as you mentioned). GPS TTFF is about 2 min (navigation not yet tested).
@nicklas519:
ich habe testweise die drei Files ersetzt. Danach bootet das Gerät nicht mehr. Vermutlich passt die libmhaldrv.so nicht zum Boot-Image.
I tried to replace the three files. After that, the device doesn't boot any more. I think, libmhaldrv.so doesn't fit to the boot image.
Ok Danke fürs ausprobieren :)
LG nicklas519
I found another small bug: sometimes the soft button lights stay on even when the display is off.
Kleiner Fehler gefunden: manchmal bleibt die Beleuchtung der Softbuttons an, wenn das Display aus geht.
Nach der Analyse der build.prop bin ich der Überzeugung, dass es sich um eine Portierung vom Amoi N820 handelt. Das Boot-Image dürfte aus einem Stock-JB-ROM V.4.1 eines baugleichen Gerätes stammen.
könnte mal bitte jemand mit einem anderen ROM mit Antutu 4.0.1 einen Benchmark zum Vergleich machen? Ich habe einen Wert von ca. 6700 im Kopf.
Ich habe bei einem zweiten Durchlauf sogar über 8200 erreicht und wollte diesen Wert verifizieren.
I found some other bugs:
-Front camera picture is upside down
-Apps in app drawer are not sorted alphabetically
-Softbuttons sometimes need two taps to work
Ich habe weitere Bugs entdeckt:
-Bild der Frontkamera ist kopfüber
-Die Sortierung der Apps im Drawer ist nicht alphabetisch
-Manchmal muss man die Softbuttons zweimal antippen
latest version of this rom has been working well. gps works well. bluetooth and wifi works normally. major improvements contained in the kernel of mr.trizet. kernel has improved the camera's autofocus function. kernel running at 1.2GHz. support for USB OTG, and magnetic sensors. Another change is the replacement of base rom to version 1.1. hopefully everything will go smoothly.
please be patient. later I will share here
hello irvanus,
i have tested your beta file "boot-422-8.zip" from 4shared and it works by me perfect, nice work.
i think you can post it :)
Works really well. Good job, Looking forward to the latest update.
guten morgen zusammen
es ist eine neue version der 4.2.2 im umlauf. lauft gut und die probleme der beta sind behoben :)
was mich stört ist das branding beim start was ich nicht mehr geändert bekomme und der factory mode wird nur noch in chinesisch angezeigt :-( wenn hier jemand nen tipp hat wie ich das wieder geändert bekomme wäre ich happy ;-)
IMO S88 BLOG: [ROM] JELLY BEAN 4.2.2 STABLE V1.1
ich habe die Version auch schon installiert. Ist für mich das derzeit beste ROM für das T1.
Pros:
- Autofokus funktioniert
- GPS funktioniert gut (TTFF 62s, Genauigkeit unter 3m, Navigation tadellos)
- flott (siehe Anhang)
Cons:
- grausames Bootlogo
- Menüs und Apps teilweise englisch
- kein TV-Ausgang
Die Animation beim Start oder Herunterfahren schalte ich ab, indem ich die ZIP und mp3 in /System/Media umbenenne.
MKKLR21 schrieb:
Cons:
ja, genau. schrecklich ist noch milde ausgedrückt :confused:
leider habe ich es bis dato nicht geschafft den geflügelten totenkopf zu ersetzten :cursing:
bin hier mit meinem latein am ende, hat jemand einen vorschlag wie ich das bootlogo ersetzt bekomme?
wenn nicht, der rest des roms ist so gut das ich mit diesem minus leben kann ;-)
Ich hab mich des Problems angenommen. Einfach die update.zip im Anhang mit CWM flashen.
  • update.zip
Reaktionen: gamer97 und Bundfrosch
suppi, danke :)
jetzt kann ich grinsen und freuen!
Damit geht es auch
ROM Toolbox Pro
Auch ohne Pro
grüße
utze
Kann jemand helfen ? Downloadlink für Rom geht leider nicht !
sind dann die Menüs dann auch alle mit dem Update auf deutsch?
I will later give an update and revision of the rom.
servers from hosting impaired. so you can not download it
Funktionieren die Lockscreen-Widgets eigentlich auch auf einem verschlüsselten Lockscreen (z.B. PIN)?
Und wie siehts mit der RAM-Verwendung aus, hat man wieder ähnliche Zustände, wie bei ICS?
Wenn das alles geht, würde ich die ROM gerne mal ausprobieren. :)
  • marcel_btf
email.filtering
Z
  • zimboman
2 3
dragonball
dragonball
Bundfrosch
190205
