EU Lautstärkenbegrenzung deaktivieren - default_gain.conf Datei gesucht
  • 2 Antworten
Pr0_Sh0t
Ich habe schon viel im Internet geschaut und herausgefunden dass man die default_gain.conf Datei für ein verändern des zB Kopfhörer lautstarke abändern soll. Leider finde ich nur für Samsung den Pfad wo sie liegen soll ( system/etc ) ich allerdings finde diese nich .
Habe ein paar Dateien bei denen ich mir aber nicht sicher bin ob dies etwas bringt diese ab zu andern. Und was genau muss ich abändern um zB die Kopfhörer zu verstärken?
audio_policy.conf
# Audio policy configuration for nvidia device builds
# Global configuration section: lists input and output devices always present on the device
# as well as the output device selected by default.
# Devices are designated by a string that corresponds to the enum in audio.h
global_configuration {
attached_output_devices AUDIO_DEVICE_OUT_EARPIECE|AUDIO_DEVICE_OUT_SPEAKER
default_output_device AUDIO_DEVICE_OUT_SPEAKER
attached_input_devices AUDIO_DEVICE_IN_BUILTIN_MIC|AUDIO_DEVICE_IN_BACK_MIC|AUDIO_DEVICE_IN_REMOTE_SUBMIX
# audio hardware module section: contains descriptors for all audio hw modules present on the
# device. Each hw module node is named after the corresponding hw module library base name.
# For instance, "primary" corresponds to audio.primary.<device>.so.
# The "primary" module is mandatory and must include at least one output with
# AUDIO_OUTPUT_FLAG_PRIMARY flag.
# Each module descriptor contains one or more output profile descriptors and zero or more
# input profile descriptors. Each profile lists all the parameters supported by a given output
# or input stream category.
# The "channel_masks", "formats", "devices" and "flags" are specified using strings corresponding
# to enums in audio.h and audio_policy.h. They are concatenated by use of "|" without space or "\n".
audio_hw_modules {
primary {
outputs {
primary {
sampling_rates 48000
channel_masks AUDIO_CHANNEL_OUT_STEREO
formats AUDIO_FORMAT_PCM_16_BIT
devices AUDIO_DEVICE_OUT_EARPIECE|AUDIO_DEVICE_OUT_SPEAKER|AUDIO_DEVICE_OUT_WIRED_HEADSET|AUDIO_DEVICE_OUT_WIRED_HEADPHONE|AUDIO_DEVICE_OUT_AUX_DIGITAL|AUDIO_DEVICE_OUT_ALL_SCO|AUDIO_DEVICE_OUT_WIFI_DISPLAY
flags AUDIO_OUTPUT_FLAG_PRIMARY
aux_ac3_dts_pass_through {
sampling_rates 32000|44100|48000
formats AUDIO_FORMAT_IEC61937
devices AUDIO_DEVICE_OUT_AUX_DIGITAL
flags AUDIO_OUTPUT_FLAG_DIRECT
inputs {
primary {
sampling_rates 8000|11025|12000|16000|22050|24000|32000|44100|48000
channel_masks AUDIO_CHANNEL_IN_MONO|AUDIO_CHANNEL_IN_STEREO
devices AUDIO_DEVICE_IN_BUILTIN_MIC|AUDIO_DEVICE_IN_BLUETOOTH_SCO_HEADSET|AUDIO_DEVICE_IN_WIRED_HEADSET|AUDIO_DEVICE_IN_BACK_MIC
a2dp {
outputs {
a2dp {
sampling_rates 44100
devices AUDIO_DEVICE_OUT_ALL_A2DP
usb {
outputs {
usb {
devices AUDIO_DEVICE_OUT_ALL_USB|AUDIO_DEVICE_OUT_ANLG_DOCK_HEADSET|AUDIO_DEVICE_OUT_DGTL_DOCK_HEADSET
r_submix {
outputs {
submix {
devices AUDIO_DEVICE_OUT_REMOTE_SUBMIX
inputs {
submix {
channel_masks AUDIO_CHANNEL_IN_STEREO
devices AUDIO_DEVICE_IN_REMOTE_SUBMIX
nvaudio_conf.xml
<?xml version="1.0" encoding="utf-8"?>
<!-- Copyright (c) 2012 NVIDIA Corporation. All Rights Reserved.
NVIDIA Corporation and its licensors retain all intellectual property and
proprietary rights in and to this software and related documentation. Any
use, reproduction, disclosure or distribution of this software and related
documentation without an express license agreement from NVIDIA Corporation
is strictly prohibited.
<!DOCTYPE AudioConfigs [
<!ELEMENT AudioConfigs (alsa_device)>
<!ELEMENT alsa_device (pcm_config, playback, capture, call, fm_playback)>
<!ELEMENT playback (pcm_config, device, path)>
<!ELEMENT capture (pcm_config, device, path)>
<!ELEMENT voice-call (pcm_config, device, path)>
<!ELEMENT device (path)>
<!ELEMENT path (ctl, at)>
<!ELEMENT alsa_device EMPTY>
<!ATTLIST alsa_device name (music|voice|aux|voice-call|bt-voice-call|fm-radio) #REQUIRED>
<!ATTLIST alsa_device card_id CDATA #REQUIRED>
<!ATTLIST alsa_device card_name CDATA #REQUIRED>
<!ATTLIST alsa_device device_id CDATA #REQUIRED>
<!ELEMENT pcm_config EMPTY>
<!ATTLIST pcm_config rate (8000|11025|16000|22050|32000|44100|48000|64000|88200|96000|176400|192000) #IMPLIED>
<!ATTLIST pcm_config channels (1|2|3|4|5|6|7|8) #IMPLIED>
<!ATTLIST pcm_config bps (16|32) #IMPLIED>
<!ATTLIST pcm_config period_size CDATA #IMPLIED>
<!ATTLIST pcm_config period_count CDATA #IMPLIED>
<!ATTLIST pcm_config start_threshold CDATA #IMPLIED>
<!ATTLIST pcm_config stop_threshold CDATA #IMPLIED>
<!ATTLIST pcm_config silence_threshold CDATA #IMPLIED>
<!ATTLIST pcm_config avail_min CDATA #IMPLIED>
<!ELEMENT device EMPTY>
<!ATTLIST device name (speaker|headphone|earpiece|bt-sco|aux|builtin-mic|headset-mic|bt-sco-mic|voice-call|bt-voice-call) #REQUIRED>
<!ELEMENT path EMPTY>
<!ATTLIST path name CDATA #IMPLIED>
<!ELEMENT param EMPTY>
<!ATTLIST param name CDATA #REQUIRED>
<!ATTLIST param val CDATA #REQUIRED>
<!ELEMENT ctl EMPTY>
<!ATTLIST ctl name CDATA #REQUIRED>
<!ATTLIST ctl val CDATA #REQUIRED>
<!ELEMENT at EMPTY>
<!ATTLIST at node CDATA #REQUIRED>
<!ATTLIST at cmd CDATA #REQUIRED>
<!ELEMENT at EMPTY>
This file is used to declare various board specific audio configs
<AudioConfigs>
<alsa_device name="music"
card_id="1"
card_name="tegramax98088"
device_id="0">
<pcm_config rate="48000"
channels="2"
bps="16"
period_size="1024"
period_count="4"
start_threshold="4095"
stop_threshold="4096"
silence_threshold="0"
avail_min="1"/>
<param name="ulp" val="0"/>
<param name="HW Rates" val="48000 44100"/>
<playback>
<device name="headphone">
<path name="on">
<ctl name="Left HP Mixer Left DAC1 Switch" val="1"/>
<ctl name="Right HP Mixer Right DAC1 Switch" val="1"/>
<ctl name="Headphone Jack Switch" val="1"/>
</path>
<path name="off">
<ctl name="Headphone Jack Switch" val="0"/>
<ctl name="Left HP Mixer Left DAC1 Switch" val="0"/>
<ctl name="Right HP Mixer Right DAC1 Switch" val="0"/>
</path>
</device>
<device name="speaker">
<path name="on">
<ctl name="Left SPK Mixer Left DAC1 Switch" val="1"/>
<ctl name="Left SPK Mixer Right DAC1 Switch" val="1"/>
<ctl name="Int Spk Switch" val="1"/>
</path>
<path name="off">
<ctl name="Left SPK Mixer Left DAC1 Switch" val="0"/>
<ctl name="Left SPK Mixer Right DAC1 Switch" val="0"/>
<ctl name="Int Spk Switch" val="0"/>
</path>
</device>
<device name="earpiece">
<path name="on">
<ctl name="Left REC Mixer Left DAC1 Switch" val="1"/>
<ctl name="Right REC Mixer Right DAC1 Switch" val="1"/>
<ctl name="Earpiece Switch" val="1"/>
</path>
<path name="off">
<ctl name="Earpiece Switch" val="0"/>
<ctl name="Left REC Mixer Left DAC1 Switch" val="0"/>
<ctl name="Right REC Mixer Right DAC1 Switch" val="0"/>
</path>
</device>
</playback>
<capture>
<pcm_config start_threshold="1"/>
<device name="builtin-mic">
<path name="on">
<ctl name="Left ADC Mixer MIC1 Switch" val="1"/>
<ctl name="Right ADC Mixer MIC1 Switch" val="1"/>
<ctl name="Int Mic Switch" val="1"/>
</path>
<path name="off">
<ctl name="Int Mic Switch" val="0"/>
<ctl name="Left ADC Mixer MIC1 Switch" val="0"/>
<ctl name="Right ADC Mixer MIC1 Switch" val="0"/>
</path>
</device>
<device name="headset-mic">
<path name="on">
<ctl name="Left ADC Mixer INA1 Switch" val="1"/>
<ctl name="Right ADC Mixer INA1 Switch" val="1"/>
<ctl name="Mic Jack Switch" val="1"/>
</path>
<path name="off">
<ctl name="Mic Jack Switch" val="0"/>
<ctl name="Left ADC Mixer INA1 Switch" val="0"/>
<ctl name="Right ADC Mixer INA1 Switch" val="0"/>
</path>
</device>
<device name="back-mic">
<path name="on">
<ctl name="Left ADC Mixer MIC2 Switch" val="1"/>
<ctl name="Right ADC Mixer MIC2 Switch" val="1"/>
<ctl name="Int Sub Mic Switch" val="1"/>
</path>
<path name="off">
<ctl name="Int Sub Mic Switch" val="0"/>
<ctl name="Left ADC Mixer MIC2 Switch" val="0"/>
<ctl name="Right ADC Mixer MIC2 Switch" val="0"/>
</path>
</device>
</capture>
</alsa_device>
<alsa_device name="voice"
card_id="1"
device_id="2">
<pcm_config rate="8000"
channels="1"
bps="16"
period_size="256"
period_count="4"
start_threshold="1023"
stop_threshold="1024"
avail_min="1"/>
<playback>
<device name="bt-sco">
<path name="on">
<at node="/dev/pts29" cmd="at%setaudio=4\r\n"/>
</path>
</device>
</playback>
<capture>
<device name="bt-sco-mic"/>
</capture>
</alsa_device>
<alsa_device name ="aux"
card_id="0"
card_name="Tegra"
device_id="3">
channels="2"
bps="16"
period_size="1024"
period_count="4"
avail_min="1"/>
<param name="HW Rates" val="48000 44100 32000"/>
<playback>
<device name="aux"/>
</playback>
</alsa_device>
<alsa_device name="wfd">
channels="2"
bps="16"
period_size="1024"
period_count="4"/>
<playback>
<device name="wfd"/>
</playback>
</alsa_device>
<alsa_device name ="voice-call"
card_id="1"
device_id="3">
channels="2"
bps="16"
period_size="1024"
period_count="4"
avail_min="1"/>
<call>
<path name="on">
<ctl name="Call Mode Switch" val="1"/>
</path>
<path name="off">
<ctl name="Call Mode Switch" val="0"/>
</path>
<path name="on">
<at node="/dev/pts29" cmd="at%setaudio=2\r\n"/>
</path>
<path name="off">
</path>
</device>
<path name="on">
<at node="/dev/pts29" cmd="at%setaudio=3\r\n"/>
</path>
<path name="off">
</path>
</device>
<path name="on">
<at node="/dev/pts29" cmd="at%setaudio=1\r\n"/>
</path>
<path name="off">
</path>
</device>
</call>
<call>
<path name="on">
</path>
<path name="off">
</path>
</device>
<path name="on">
</path>
<path name="off">
</path>
</device>
<path name="on">
</path>
<path name="off">
</path>
</device>
</call>
</alsa_device>
<alsa_device name ="bt-voice-call"
card_id="1"
device_id="4">
channels="1"
bps="16"
period_size="256"
period_count="4"
avail_min="1"/>
<call>
<path name="on">
<at node="dev/ttyACM2" cmd="at%iaudcnf=4\r\n"/>
</path>
<path name="off">
</path>
<device name="bt-sco"/>
</call>
<call>
</call>
</alsa_device>
<alsa_device name="fm-radio"
card_id="1"
device_id="5">
channels="2"
bps="16"
period_size="1024"
period_count="4"
avail_min="1"/>
<fm_playback>
<path name="on">
<ctl name="Left HP Mixer INB1 Switch" val="1"/>
<ctl name="Right HP Mixer INB2 Switch" val="1"/>
</path>
<path name="off">
<ctl name="Left HP Mixer INB1 Switch" val="0"/>
<ctl name="Right HP Mixer INB2 Switch" val="0"/>
</path>
</device>
<path name="on">
<ctl name="Left SPK Mixer INB1 Switch" val="1"/>
<ctl name="Right SPK Mixer INB2 Switch" val="1"/>
</path>
<path name="off">
<ctl name="Left SPK Mixer INB1 Switch" val="0"/>
<ctl name="Right SPK Mixer INB2 Switch" val="0"/>
</path>
</device>
</fm_playback>
</alsa_device>
</AudioConfigs>
Oder weiß jemand von euch welche datei ich abändern muss um die EU begränzumg der Lautstärke zu deaktivieren oder wo die gefragte default_gain.conf Datei bei LG liegt?
Löl du scheinst ja meinen Gedanken zu folgen, allerdings bist du hier im falschen Bereich (Customroms), es betrifft ja normal nur Stockroms, daher sollte die die von dir gesuchte Config bzw. Wert wenn sie denn so heißt bei LG, in den Customroms aber zu finden sein. (auf jeden Fall nach meiner Erfahrung bei Cyogenmodbasierten Roms)
Es lohnt sich aber auf jeden Fall, bei mir war es damals eine ca verdreifachung der Lautstärke(insbesondere bei kopfhörer) im Direktvergleich Stock zu Customrom, ich konnte es dann sogar wieder beim Motorrad fahren benutzen inklusive Telefon, was vorher praktisch ausgeschlossen war.
Wäre ja auch interessant für alle zu wissen ob das Problem bei Stockbasierten Customroms auch beseitigt wurde.
Natürlich, würde gerne ein screenshoot machen. Nur irgendwie geht's gerade nicht. Na dann würde ich einen Moderator bitten das Thema in den Richtigen Bereich zu verschieben.
Du kannst ja mal nach schauen ob die Config bei dir vorhanden ist die wo ich suche. Wäre interessant zu wissen. Wenn sie bei dir vorhanden ist kann es sein dass sie bei mir durch das flashen des Walkman des z1 und z3 verloren gegangen ist.
