ROM] [30-Oct] Last Firmware Stock (TWPR) << D855-10N
  • 7 Antworten
Beha42
Gast
Why use this ROM ???
For the simple reason that if you like having the latest official update without modifications to make things your way, but want to have bugs that lead often changes made ​​by developers, if you want to keep track unlocking the bootloader (there were rumors that in an update could become blocked from using Bump! to release the bootloader and would lose all ability to install roms.
Features:
2usrmzx
Last Firmware D855
2usrmzx
Root & Busybox
2usrmzx
Adblock Host
2usrmzx
Removed gapps that are available in playstore (book, magazine, youtube, gmail, chrome, hangout etc.)
2usrmzx
Disabled LG OTA (I will only disable firmware updates, the apps for the lg will be available without problem).
Installation:
Root & TWRP (http://forum.xda-developers.com/lg-...mp-unlock-lg-g3-twrp-d852-d852g-f400-t2900614)
Download Zip and copy
Reboot in TWRP
Full Wipe (Dalvik, Cache, System & Data if it is the first time you install, should be a next update reaches only to wipe cache and dalvik but mistakes is advisable to perform a clean installation)
Install Zip
Reboot
WARNING !!!!
The rom only contains what is described above, the rest is 100% stock. The installer performs the same only wipe system alone so the other wipes borne by each user.
Excludes bootloader and modem, only system and kernel.
Thks: Cloudy (script root and busybox), thecubed (bump!)
Features:
2usrmzx
Last Firmware D855
2usrmzx
Root & Busybox
2usrmzx
Adblock Host
2usrmzx
2usrmzx
Installation:
Reboot in TWRP
Install Zip
Reboot
WARNING !!!!
Der ursprüngliche Beitrag von 12:03 Uhr wurde um 12:05 Uhr ergänzt:
Ein Thread nur mit Überschrift auch mal was neues Hier oben bitte in Post 1 einfügen !
Reaktionen: f.h.73 und der berliner
@Beha45:
Nimm' dir einfach ein Beispiel an diesem ROM-Eröffnungsthread und gut ist es.
Die Form deiner Thread-Eröffnung und die hier weiteren Einlassungen von dir sind doch eher schwach.
Beha42 schrieb:
...Wenn es dem Mod nicht passt, soll er doch meinen Müll einfach löschen, und aus die Maus!...
Finde ich übrigens sehr interessant, dass du deine eigenen Beiträge als "Müll" bezeichnest :flapper:
Reaktionen: der berliner
Ich habe mal kurz durchgewischt. Bitte beim nächsten Mal einfach den Thread melden, dann können wir Mods gleich handeln.
Ich bräuchte jetzt nur wieder einen Freiwilligen, der mir den Startbeitrag übersetzt und ich dann einfügen kann.
Danke!
ich habe soeben die N geflasht, dachte auch es hätte alles geklappt. Allerdings kommt bei mir jetzt ständig die Meldung com.android.phone.
Was kann ich machen?
Vielen Dank für Eure Hilfe.
WSO
beim Start oder wann !?
erneut installieren und versuchen.
Der ursprüngliche Beitrag von 21:46 Uhr wurde um 22:35 Uhr ergänzt:
passiert bei mir genauso also nicht zu gebrauchen !!Schade
Also erstmal zu machen? Macht ja keinen Sinn, wenn eure Maschinen damit nicht laufen.
Keine Ahnung wo hier dein Problem ist da
1. das Teil ordentlich läuft und
2. es nur darum ging, ein wenig mehr infos zu der von dir genannten Rom zu Posten.
Wenn du hier mittlerweile schon zwei mal angemacht würdest, könnte man sich allerdings auch mal Gedanken machen, ob es am Forum oder doch am ein persönlich liegt. ;-)
  • Gabberlein
Gabberlein
Fabian00086
Fabian00086
Fabian00086
vielesysteme
vielesysteme
vielesysteme
