Phiber2000
Dauer-User
- 919
Du musst nur den DL-Modus vorher wiederherstellen. Schau einfach nur nochmal in die FAQ vom Toolkit! Da steht alles genau beschrieben.
autoprime;64553220 schrieb:here is D855 16G 30B KDZ link :victory:
http://csmgdl.lgmobile.com/dn/downloader.dev?fileKey=FW4DCC3332TXAZRAB5452PI/D85530B_00_1217.kdz
if you break down the KDZ you could flash all the partitions (minus primary gpt) to a 32GB phone.
this KDZ is in the hands of CM devs who will soon be updating the CM13 blobs n things
#teamcodefire #1
So.. if you already have TWRP installed I would flash the rpm, tz, modem, system and boot partitions from the KDZ.. Both 16GB and 32GB phones would work with that method. Stock boot.img will have to be "bump'd" if you want to keep TWRP.
As mentioned above.. this KDZ is from a 16GB D855. I'm not 100% sure.. but I think the GPT might be set for a 16GB phone so if a 32GB user flashes the FULL KDZ as is you will lose 16GB of /data. So obviously... only flash this KDZ if you have a 16GB D855. But I suggest not flashing the KDZ and instead flashing the partitions from the KDZ listed above.. better to keep TWRP and root.
Best way to root on Android 6.0 is to flash Chainfire's latest SuperSu zip which patches the boot partition with root. You can grab that here - EXPERIMENT: Root without modifying /system #2: Automation - Post #3
Use the latest 2.65 version (or higher).
