[KERNEL] [Stock] [MM] [Gabriel] [D85x]
  • 9 Antworten
TheKen
TheKen
Dauer-User
364
SO ihr Flashaholics....
Hier der neue Kernel von mostafaz
XDA
Aktuelle version:
1.7
Changelog:
V1.7
* CPU Over-Clock to 2.8 GHz
* GPU Over-Clock to 657 Mhz
V1.6
* Introduce Linaro 5.3 Toolchain
* Fixed latest kernel crash
* Add Ondemand CPU_Governor from semaphore kernel (nexus 4)
* Update Intelli_Thermal driver (parameters descriptions)
* Set High Performance Profile After Boot Up to Finish the OS Load Process
As Fast As Possible and Smoothly,
Normal Profile will set after CPU Temp Goes Under 65 degC, Just a While
V1.5
* F2FS bring up to date with Kernel.org latest codes,
stable branch 4.7-rc1-3.4 - 2016-06-03
* Sync FS just once before suspend, not all the time
* Mako Hotplug added
* Quick Wakeup driver added
( system back into suspend without fully resuming
if the wake reason was a special quick wakeup event )
* Make MPDecision to be Conservative
* Enhanced Power Efficiency by NVIDIA implemented
* Interactive CPU back to LGe changes
* CPU Boost updates and Relative Dependencies Removed
this should solve last Kernel oops
* Back light control by jon777 added
Force Rom to use defined min/max back light
/sys/module/lm3697/parameters/*
* Arch Power & Gentle Fair Sleepers sysfs added
/sys/kernel/sched/*
disabling gentle fair sleepers may bring you smoother ui
* Add MMC CRC control sysfs
/sys/module/mmc_core/parameters/use_spi_crc
( Enabling software CRCs on the data blocks can be a
significant (30%) performance cost )
V1.4
* Support F2FS (see this instruction)
* Neon-mode activated
* Neon optimized Crypto
V1.3
* Fix kernel crash/reboot
* Add Smartmax cpu_governor
* cleanup dmseg to produce better logs
* Install custom busybox for my later needs
* Enable msm_thermal by default
V1.2
* Support Exfat
* Tune down default thermal limit to 72 & 75 degC
* Switch to XZ kernel compressor
* Initial support for D850, 1 ,2
V1.1
* Introducing UBERTC-7 toolchain, Experimental (first time for G3)
* CPU_Governor added:
zzmoove,alucard,impulse,intellimm,hyper,nightmare, darkness,lionheart,(slim & elementalx : gpu_boost feature)
(i can't have slim and elementalx at same time) :\
interactive synced with AOSP source
* GPU_Governor added:
conservative + adreno idler,simple gpu algorithm
* Minimum GPU Freq 27 MHz
* Hotplug added:
alucard,msm
* I/O Scheduler added:
bfq,fiops,sioplus,zen,vr,tripndroid
* CPU_Boost updated
* Scheduled Workqueue implemented
* CPU Voltage control supported
* MSM_Thermal v2 implemented
* KCal v2 implemented
* Live user sharpening control implemented
can access by "/sys/devices/virtual/graphics/fb0/sharpening"
* KSM ,disabled by default
* Adaptive LMK (by motorilla) implemented
* Fsync implemented
* TCP congestion algorithm (westwood & ...)
* State notifier (determine screen state, on & off)
* ZCache,ZRam,Zsmalloc,Frontswap implemented
zram compressor can switch to lzo or lz4
maximum compressor streams can change from 1~4 cpu
## enabling zram can drain battery faster, google zcache,zram,frontswap
## to enable 512 MiB zram copy these commands to your init.d script or run in terminal:
Code:
swapoff /dev/block/zram0;
echo "1" > /sys/block/zram0/reset;
echo "lz4" > /sys/block/zram0/comp_algorithm;
echo "2" > /sys/block/zram0/max_comp_streams;
echo "512MB" > /sys/block/zram0/disksize;
mkswap /dev/block/zram0;
swapon /dev/block/zram0;
* Process reclaim implemented (i don't think it's working ...)
* EXT4 filesys updated
* Frandom implemented (10-50 times faster than what you get from Linux urandom)
* Disabled crc check
* memutils, memcpy, memmove optimization
Download:
Mediafire
Empfohlenes Kernel Tool by BuLLeT_93
Synapse mod
Download
P.S.: das übersetzen spare ich mir mal
Hier die Favoriten Einstellungen vom DEV:
# My simple profile
cpu alucard
hotplug alucard
gpu powersave
i/o noop 1024
screen
232 237 256, saturation 75 (franco config)
entropy
read 512, write 256
fsync off
thermal
core control off
freq throttle 75, core throttle 72
temp,core hysterecis 10
# My smoothness profile
cpu slim/elementalx
down_differential 10
input_enent_timeout 800
sampling_down_factor 2
ui/sampling_rate 15000
hotplug alucard
sample_rate 35%
gpu msm-adreno
simple algorithm laziness 3, ramp threshold 7
screen same
i/o fiops 1024
entropy same
fsync same
Reaktionen: Atzef
Update auf V1.3
Update V1.4
Update auf V1.5
Update V1.6
Und gleich noch auf V1.7
Für Lollipop fand ich den Gabriel mit Abstand am besten, aber die Marshmallow Versionen haben mich bisher noch nicht überzeugt. Performance ist ok,aber DOT ist lausig. Oder kommst du auf DOT > 4 Std?
Kamm ich eh kaum mit einer [emoji20]
Der kernel will bei mir nicht richtig. Alle Funktionieren aber dieser hir nicht.
Entweder Sagt mir das System das meine SD Karte Beschädigt sei oder das Gerät hängt in einer Bootschleife.
Gestern hat es 1 mal Geklapt aber nach einem Neustart hing es wieder in der Bootschleife.
Der Xceed in Version 4d Funktioniert super und bleibt wohl auch vorerst.
Für die kurze Zeit der Entwicklung (bislang ca. 14 Tage) finde ich den Gabriel schon recht gut. Natürlich kann er zur Zeit noch nicht mit dem Xceed oder Soild mitthalten, diese werden aber auch schon seit ca. einem halben Jahr kontinuierlich weiterentwickelt.
Der Gabriel-Kernel bietet sehr viel nette Einstellungsmöglichkeiten und was ich als sehr großes plus empfinde, er kann im enforced Selinux Modus betieben werden und somit ist endlich ein großes Sicherheitsloch gestopft worden, auch wenn Viper4Android dadurch nicht funktioniert.
