[Kernel] GCC5.2 TA-MOD Xceed
  • 138 Antworten
TheKen
TheKen
Dauer-User
364
Jetzt auch für MM
UPDATES!!
04-10-2016
    • Ramdisk cleanup
    • Toolchain updates
    • Removed some stuff from LG
    Download:
    LP Version
    Version Information LP
    Status:
    Stable
    Current Stable Version: Production build 7
    Stable Release Date: 2016-04-10
    MM Version
    Version Information MM
    Status:
    Stable
    Current Stable Version: Production build 2
    01-20-2016
      • Ramdisk cleanup
      • GCC Compiler directives update from mainline linux
      • LMK Updates from Motorola
      • Initial MM Support for D855 only
    MM Version
    12-25-2015
    • Ramdisk updates(zram related stuff and some cleanup)
    • few updates(check my git)
    Download
    D855-LP-prod-bld5
    12-04-2015
    • Ramdisk edits/updates(thanks to duki994)
    • Updates to binder
    Download
    D855-LP-prod-bld4
    11-23-2015
    • Refactored Voltages and currents for higher steps
    • Fixes to binder
    • Updates to Cubic TCP Congestion
    Download
    D855-LP-prod-bld3
    Important!!
    * Clear Synapse Application data..
    * This update switches us back to Interactive Governor..please refrain from using any other tweaking apps yet refrain from changing any component on Interactive..its best to run as it is..
    * Update comes with the EXFAT drivers for SDXC support..though personally I have not tested this as I only own a 16gb UHS1 SDHC card...
    * Initial support for D850 Variant
    Download
    D855-LP-prod-bld2.zip | by kairi_zeroblade for G3
    Download für noch Ältere Versionen
    XDA:
    [KERNEL][GCC5.2][TA-MOD] Xceed [Synapse][BUM… | LG G3 | XDA Forums
    Info:
    Home · zeroblade1984/Galbi Wiki · GitHub
    Download liste:
    !Unbedingt auf die richtige Version (d855) achten!
    alle Versionen
    Der Dev empfiehlt ausdrücklich Synapse...
    Vor dem flashen daten von Synapse leeren
    Meines erachtens der Top Kernel für das G3
Reaktionen: mratix, DroidJunky und Smittels
Mal grobe Settings
Gov. Ondemand
CPU Max 2649
GPU Max 578
Gov. msm-adreno-tz
I/O row 2048 (beide)
Gov: interactive (getweaked)
Bin mal gespannt wie der Kernel sich nach ein paar Tagen anstellt.
Hat ja leider sehr wenige governor und generell weniger Einstellungsmöglichkeiten. Vor allem der Hotplug fehlt mir bisher.
Ansonsten läuft er absolut stabil.
Hab ihn nur mal geschwind drauf gemacht da ich Synapse absolut nicht leiden kann…
Ein paar Sachen fehlen mir persönlich noch wie OC UV und paar GOV.‘s
@Smittels hast du Synapse mit UKM oder nur Synapse?
Hatte ja ukm noch vom gabriel drauf.hab den xceed einfach drüber geflasht.
UV gibt es: unter cpu,unterhalb der tunables kannst du in 5er,10er und 15er schritten undervolten und dir die spannungstabellen anzeigen lassen.
Edit:
Eigentlich solltest du den kernel adiutor nutzen können. Gibt ja weniger einstellungsmöglichkeiten (kerne nicht einzelnd ansteuerbar).
Ich habe den nur kurz mit Kernel Adiutor eingestellt...
Hab mich vertippt meinte nicht UV sondern Hotplug :-(
Der Dev meint das mit Synapse mehr Settings zur verfügungstehen...
Bei mir werden dauernd apps (vor allem der browser) beendet. Jemand ne idee wo dran das liegen kann?
Werden bei hoher RAM-auslastung apps beendet?
Hatte ich mit anderen Kernel nie.
Meine externe SD Karte wird nicht gemountet... Liegt anscheinend wm Datei system EXFat
Bin auch zurück zum gabriel. Hatte doch zu viele Reboots und Freezes. Ausserdem fehlt der hotplug. Werde bei der nächsten Version noch mal testen.
Ich finde der läuft sehr gut - auf Gov interactive und ohne weiteres tweaken. Keine Freeze, keine Abstürze etc. Bin sehr zufrieden vom subjektivem Eindruck. Aber er hat in der Tat nur recht wenig Einstellungsmöglichkeiten (nutze Kernel Adiutor).
Hab ihm auch noch mal ne chance geben und muss sagen,dass ich echt sehr zufrieden bin! Für die DOT musste ich beim Gabriel Kernel alles ordentlich runterschrauben.
Interactive
50UV
12UC
SLS on
Reaktionen: Black-Angel
Danke für die Info....werde mich in nächster Zeit auch mal an den Kernel wagen
Update MIT exfat unterstützung...
Läuft bisher ganz gut. SD Karte wird auf jeden Fall schon mal erkannt.
@Smittels sogar das Radio geht mit dem Kernel....
Finde es ein bisschen schade,dass der Dev uns so wenig einstellungsmöglichkeiten lässt. Der Interacrive governor bietet eigentlich so viele tweaks,aber bei der Version jetzt kann man ja wirklich keinen wichtigen Parameter mehr anpassen.
Geht eigentlich... Verbringt man schon keine Stunden mit einstellen... Nur fast Charge fehlt mir etwas...
Neue Version!!
- zurück zur stabileren Toolchain (er sagt zwar nicht welche,aber schätze dass er von UBER zurück zu ARCHI ist)
- Batterydrain beseitigt
Edit: weder archi noch uber,er macht seine eigenen toolchains
Reaktionen: TheKen
So ein hochstapler! :-D
Reaktionen: hermi327
MP87
  • Gabberlein
Gabberlein
  • nexus963
nexus963
