Probleme mit LG-Flashtool nach Installation eines LG-Kitkat-ROMs
  • 382 Antworten
Klappt es denn überhaupt noch wieder zur 4.2.2 zu kommen?
Aktuell bin ich nun hier angekommen (und ja, das Kabel ist drin)
Log:
14:11:48 : Restart.....
14:11:48 : Start Date : 2014-03-30 14:11:48
14:11:48 : ---------- QM Testmode ---------
14:11:48 : ***** Check Tool Version *****
14:11:48 : Tool version : 1.6.9.0
14:11:48 : UpgradeDLL version : 2.1.5.0
14:11:48 : Current Dir : C:\ProgramData\LGMOBILEAX\B2C_Client
14:11:48 : LGE USB Driver Version :
14:11:48 : Android PDLV Version :
14:11:48 : Android NDLV Version :
14:11:48 : ******************************************
14:11:48 : [C:\ProgramData\LGMOBILEAX\Phone] Try to delete folder
14:11:48 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone
14:11:48 : SetEmerModeAT()
14:11:48 : _IsConnectedPhone Call
14:11:48 : _IsConnectedPhone(0)
14:11:48 : 0 - NotConnected.
14:11:48 : 1 - Normal connect success
14:11:48 : 2 - Emergency connect success
14:11:48 : *****CheckOS Start********
14:11:48 : Microsoft_Windows7_Professional_Service Pack 1
14:11:48 : *****CheckPCSyncPrograms Start*****
14:11:49 : PCSyncPrograms Not Found - OK and ready to upgrade
14:11:49 : Verifying phone connection...
14:11:49 : dwWaitResetTime(40000 ms)
14:11:50 : _IsConnectedPhone Call
14:11:50 : _IsConnectedPhone(0)
14:11:50 : 0 - NotConnected.
14:11:50 : 1 - Normal connect success
14:11:50 : 2 - Emergency connect success
14:11:51 : _IsConnectedPhone Call
14:11:51 : _IsConnectedPhone(0)
14:11:51 : 0 - NotConnected.
14:11:51 : 1 - Normal connect success
14:11:51 : 2 - Emergency connect success
14:11:52 : _IsConnectedPhone Call
14:11:52 : _IsConnectedPhone(0)
14:11:52 : 0 - NotConnected.
14:11:52 : 1 - Normal connect success
14:11:52 : 2 - Emergency connect success
14:11:52 : The USB cable is not connected with the phone.\nConnect the phone and wait until the USB port is connected. Then, press the 'Retry' button.
14:11:57 : _IsConnectedPhone Call
14:11:57 : _IsConnectedPhone(0)
14:11:57 : 0 - NotConnected.
14:11:57 : 1 - Normal connect success
14:11:57 : 2 - Emergency connect success
14:11:57 : The USB cable is not connected with the phone.\nConnect the phone and wait until the USB port is connected. Then, press the 'Retry' button.
14:12:01 : Check Cancel button active..
14:12:01 : !pUpgrade->StartProcessing ... PostMsg STEP_TYPE_ENV_ERROR
14:12:01 : Page_Error ºÎºÐÀÔ´Ï´Ù
14:12:01 : LG Mobile Phone S/W Upgrade is canceled.\nTo finish the LG Mobile Phone S/W Upgrade, press the 'Finish' button below.
14:12:01 : OnStepMsg STEP_TYPE_ENV_ERROR delete m_pLGCyonUpdate
Mir sieht es aus als wenn die Anleitung nicht genau befolgt wird...hast du denn wirklich alles so gemacht wie beschrieben?
1.
https://www.android-hilfe.de/forum/...wenden-z-b-bei-downgradeproblemem.547320.html
2.[FONT=&quot]
[/FONT]
Wählt Type = 3GQCT (links oben)
PhoneMode = DIAG (oben rechts)
Wählt das zuvor runtergeladene KDZ file = Ordner öffnen klicken, um das LG stock vom Speicherort rom zu wählen.
Klickt auf "normal Web Upgrade test" (unten rechts)
Dann öffnet sich ein weiteres Fenster, klickt auf "Upgrade starten"-Button, ein paar Sekunden warten, ein weiteres Fenster öffnet sich "Wählen Sie Land & Sprache"
=> Land = Different Country
=> Sprache = Deutsch
Jetzt auf OK klicken, um fortzufahren
Nabend,
Ich habe in Moment Mahdi Rom drauf und möchte gerne zurück auf Stock.
Habe mich nach zwei Anleitungen gehalten. Einmal Offline und Online Methode. Leider bricht Downgrade bei 49% ab. Schon zehnmal neugestartet
LG Nie wider Kaufen dann hat man solche Probleme nicht mehr.
Blödsinn, ist ein tolles Smartphone. Lest mal bei Samsung was die für Probleme mit dem KK Update haben, da können wird uns von schreiben
Je nach stand Punkt. LG unterstützt viele D802 Versionen nicht mit Kit kat. Angeblich sollte überall bis April Kit kat zur Verfügung stehen. Bei Samsung hast du ja denn Wahl bei 4.3 Bleiben oder bei bekannten Probleme auf 4.4.2 updaten und Odin Funktioniert immer.
MfG
Udo Kallina
Ich hatte das S 2, 3 und 4, erzähl mir bitte nichts über Samsung
Wenn du dir ein internationales G2 gekauft hättest und kein türkisches wärst du wohl auch zufrieden
Reaktionen: Esme Wetterwachs
Doofe Frage, aber wieso lässt man das LG Tool nicht die KDZ runterladen und muss es selber machen? Ich würde auch gerne wieder unrooten, habe aber bissel schiss das ich auch bei 49% oder so hängen bleibe :D
Frage ist nicht doof sondern LG flash utilies.
Also ich habe soeben mit dem LG Service Tool mein Root entfernt. Ich hatte 4.4.2 installiert und mein Handy gerootet, wollte das nun rückgängig machen und habe im LG Service Tool "upgrade Probleme rückgängig machen" ausgewählt, worauf das Tool die passende KDZ zu meinem Gerät geladen und installiert hat. Nun ist Root weg und ich zufrieden da alles wieder original ist. Also klappt wunderbar :D
hallo,
ich habe alle schritt erfolgreich gemacht außer der letzte schritt, wenn ich die KDZ auswähle und auf NORMAL WEB UPGRADE drücke und ladet kommt einfach dazwischen eine Fehlermeldung, da steht das ich R&D Flash Tool Upaten soll aber warum und wie?
Danke
Kann mir jemand bestätigen, dass diese Anleitung noch funktioniert?
Es klappt bei mir nicht, es endet genauso wie die online Version.
Bei beiden stürzt das Flash Tool ab und schließt sich.
Vorherigen bei 'normal Web Upgrade', wollte man das Land und die Sprache auswählen soll, kommt bei mir die Meldung nur 'LG Mobile s/w läuft bereits'.
Dann stürzt es ab, nachdem ich den Flash Vorgang starte.
Kann jemand etwas dazu sagen? Wäre großartig.
Lg
Funktioniert einwandfrei mehrmals die Woche gemacht.
Die offline Version dann, korrekt?
Kommt im Flash Tool bei dir die richtige Meldung, nachdem du auf normal Web Upgrade klickst?
Ja alles normal.
Bei mir hat auch alles genau so gepasst wie beschrieben... Jedoch habe ich in download Modus immer noch rooted stehen... Ist das bei euch auch so?
Ja...nicht beachten.
Danke für die Info..
Volt hat ja jemand einen Tipp für mich, wie ich es zum laufen bekomme..
Der ursprüngliche Beitrag von 09:56 Uhr wurde um 11:14 Uhr ergänzt:
Ich bin nun etwas weiter gekommen.
Zumindest kam der Flash-Vorgang. Handy startet am Ende neu und es kommt mein normales Handy Desktop.
Also an sich wurde nichts getan.
Ich hatte Kitkat drauf und wollte die Katkat nochmal neu drauf spielen, da durch den Upgrade Fehler entstanden sind.
Die LGMobile Software sagt, dass der Upgrade erfolgreich beendet wurde. Die Anzeige auf dem Handy sah danach aus, als ob es wirklich flashen würde, aber nö.
Jemand eine Idee?
Julian23
Julian23
s2i9100
s2i9100
s2i9100
Tomibrue
