fromfuture
Philosoph
- 4.594
Fastboot ist über adb
mai55@xda schrieb:Installation instructions ROOT
1 Download folder - Tools to install ROOT on В313 -
and unpack. Link entfernt
2. Set new_twrp, to obtain root-rights. After installing TWRP (before mounting ROOT) be sure to make a backup copy of the firmware.
3. Go into TWRP and put Custom_Kernel+Busybox_P8. Overloaded
4.Go into TWRP and put SuperSU patch-v2.66_Pro.Der Link enthält die kostenpflichtige SuperSuPro und wurde darum entfernt [MarkusK]
After installing, press reboot system and see a prompt to install SuperSU. Make a swipe to the right.
After reloading You get a fullDer Link enthält die kostenpflichtige SuperSuPro und wurde darum entfernt [MarkusK] SuperSu Pro 2.66.
ATTENTION! This can be done only on a custom kernel flashed the SuperSu patch. Otherwise get ballup or eternal download.
Important! When you get the update You need to observe the following rules
1. Before upgrading firmware, it is always necessary to remove ROOT and TWRP
2. Using TWRP to restore a previously made backup of the firmware (without ROOT)
3. Install stock recovery (attached to TWRP ).
3. Now you can upgrade without problems.
