LineageOS 17.1 Unofficial
  • 158 Antworten
Update
lineage-17.1-20220206-UNOFFICIAL-federer.zip
- synchronisiert mit LA Sources
- Patch level Januar
- Kernel/Device/Vendor Sources aktualisiert
Download und Installation --> LineageOS 17.1 Unofficial
Reaktionen: Makko123
Hello.
On the FDR-A04L, it starts booting and then reboots, just like the pele ROM, and then it repeats.
@Kerohira
On the FDR-A01L, it is ok (for my device)
@Kerohira
Could you please test lineage version from 20211106 and make logs during the start?
Normally it should work on this version with logs.
@SeriouslyUnserious
I understand.
Where are the logs stored?
If you on windows first you should install
[TOOL]Minimal ADB and Fastboot [2-9-18]
Then start the application (black window), start your device and plug to the pc, then type or copy
adb logcat
Copy the output to txt or page and send me.
@SeriouslyUnserious
Thank you!This is the result.
  • log.txt
Reaktionen: SeriouslyUnserious
@Kerohira I'll check it later and write you.
Reaktionen: Kerohira
Thank you!
@Kerohira
So you have original ROM?
If yes, could you give me some informations.
You can get these with the same application you have installed.
First type adb shell
Then
cat /proc/app_info
cat /system/build.prop
@SeriouslyUnserious
This is the result.
  • app_info.txt
  • build.prop.txt
Thank you for the update!
I tried it, but it still reboots during startup.
Here is the log.
  • log.txt
The dmesg log.
  • lineage_dmesg_log.txt
Additional logs.
  • logcat.txt
  • logcat_radio.txt
  • lineage_dmesg.txt
Firmware files.
  • image.zip
Log generated by the updated ROM.
  • log.txt
  • logcat_radio.txt
  • lineage_dmesg.txt
Update
lineage-17.1-20220214-UNOFFICIAL-federer.zip
- hinzugefugt FDR-A01L Variante und dabei paar Fehler korrigiert.
I guess I had not replied before for some reason. Sorry.
It worked fine!
  • SeriouslyUnserious
2 3
SeriouslyUnserious
2 3 4
FrankWeisser
FrankWeisser
grizzly79
  • grizzly79
SeriouslyUnserious
