Huawei Ascend Y200 - english spoken users
  • 47 Antworten
Yes, try Cleanbaserom#2, run well for me!
Hello guys! Does anyone have tried the clean base ROM #2 flashed in their non-German version of Y200?
I try it and run better than stock OS :thumbsup:, my device is sold in Vietnam market.
my y200 sold in croatia, with croatian language and with clean_base_rom#2 work better than with stockrom. after flashing with clean_baserom, on first start you may choose your language, if your device doesn't response language automaticly.
Lithuanian device, flashed with no issues! :thumbup:
Cool! Thanks Guys for your feedbacks! Now I can try the clean base rom because we all broke our wifi system due to the kernels.
Cleanbase#2 don't flash oc kernel - it swaper kernel, the wifi is ok, I saw that wifi problem when use oc kernel!
I've tried CleanBaseRom#2 but it didn't work. I was getting this:
Installing: /sdcard/CleanBaseRom#2.zip
Finding update package...
Opening update package...
Installing update...
E:Error in /sdcard/CleanBaseRom#2.zip
(status 0)
Installation aborted.
Luckily for me CleanBaseRom did work (old one), that did fix my problem with gprs but now i couldn't use WiFi at all.
Thanks to michelkovacic, after flashing some OC kernel boot, wifi started working as well.
Thanks once more Michel.
Hi VBM, would you mind sharing the kernel that fixed your wifi? My wifi is broken for about 2 months now.. Still downloading the cleanbase rom..
Der ursprüngliche Beitrag von 12:28 Uhr wurde um 12:29 Uhr ergänzt:
is the kernel in the clean base rom swappable?
did you do the following steps...
-wipe data/factory reset
-wipe cache partition
-advanced/wipe Dalvik cache
-mounts and storage/format system + cache
-mounts and storage/mount system + mount data
YES it is
It was oc_kernel_boot.img from this post
That is exactly what I've did. Yet it failed.
open cleanbaserom # 2 with 7zip and copy the META-INF folder in the cleanbaserom, then should go to flash.
sorry the other way... open cleanbaserom with 7zip and copy the META-INF folder in the cleanbaserom#2, then should go to flash.
I was flash with original cleanbase_rom#2, and had no problems. I don't know why that happening some users. What problem is with cleanbase_rom#2 than some users flash without problem, and some of them have problems?
so...is it possible that cyanogenmod 7.2 came for y200?
nothing is impossible... but actually we work on a project much better than cyanogenmod 7.2... more details in a few days :D
Reaktionen: michelkovacic und vBm
Whatever you're working on i really hope to have gtalk working on it :p
And if possible to have source so we can poke and maybe join on developing team. :)
gtalk works, see here
can i say thanx twice?? :D
why gtalk can't start? it say "aplication talk is unexpectedly stopped. Please try again" I have cleanbase rom#2 and oc kernel. gtalk is installed afterward.
Awaiting for any details! :)
P.S is it any releated to y501pro and ICS? :)
Almera
sis71
MegaTheLance
  • MegaTheLance
MegaTheLance
MegaTheLance
  • Niki_xyOn
YuT666
Y
