Gast7007
Gast
Ja, genau ist ungeändert nur deodex.
isabella-herzchen schrieb:(zur gegen Probe vielleicht noch mal die Settings.apk hochladen)
GrußIsa
W: Config flags size > 38. Exceeding bytes: 0x2400.
W: Invalid config flags detected: string-ERR0
W: Config flags size > 38. Exceeding bytes: 0x9C00.
W: Invalid config flags detected: string-ERR1
W: Config flags size > 38. Exceeding bytes: 0x2A02.
W: Invalid config flags detected: string-ERR2
W: Invalid config flags detected: string-ERR3
W: Config flags size > 38. Exceeding bytes: 0x8801.
W: Invalid config flags detected: string-ERR4
W: Config flags size > 38. Exceeding bytes: 0xE703.
W: Invalid config flags detected: string-ERR5
W: Config flags size > 38. Exceeding bytes: 0xDE00.
W: Invalid config flags detected: string-ERR6
W: Config flags size > 38. Exceeding bytes: 0x5401.
W: Invalid config flags detected: string-ERR7
W: Config flags size > 38. Exceeding bytes: 0xE401.
W: Invalid config flags detected: string-ERR8
W: Config flags size > 38. Exceeding bytes: 0x4F00.
W: Invalid config flags detected: string-ERR9
W: Config flags size > 38. Exceeding bytes: 0x4803.
W: Invalid config flags detected: string-ERR10
W: Invalid config flags detected: string-ERR11
W: Invalid config flags detected: string-ERR12
Exception in thread "main" brut.androlib.AndrolibException: Multiple resources: spec=0x0104005f string/needPuk, config=[DEFAULT]
at brut.androlib.res.data.ResConfig.addResource(ResConfig.java:63)
at brut.androlib.res.data.ResConfig.addResource(ResConfig.java:56)
at brut.androlib.res.decoder.ARSCDecoder.readEntry(ARSCDecoder.java:193)
at brut.androlib.res.decoder.ARSCDecoder.readConfig(ARSCDecoder.java:162)
at brut.androlib.res.decoder.ARSCDecoder.readType(ARSCDecoder.java:128)
at brut.androlib.res.decoder.ARSCDecoder.readPackage(ARSCDecoder.java:103)
at brut.androlib.res.decoder.ARSCDecoder.readTable(ARSCDecoder.java:81)
at brut.androlib.res.decoder.ARSCDecoder.decode(ARSCDecoder.java:49)
at brut.androlib.res.decoder.ARSCDecoder.decode(ARSCDecoder.java:40)
at brut.androlib.res.AndrolibResources.installFramework(AndrolibResources.java:675)
at brut.androlib.Androlib.installFramework(Androlib.java:641)
at brut.apktool.Main.cmdInstallFramework(Main.java:252)
at brut.apktool.Main.main(Main.java:91)
Cleaning up unclosed ZipFile for archive P:\AndroidMultitool_v3.5\Files\framework-res.apk
Deodexing AGPSProvider.apk [DONE]
Deodexing AirSharing.apk [DONE]
Deodexing BasicDreams.apk [DONE]
Deodexing Bluetooth.apk [ERROR]
Deodexing Books.apk [ERROR]
Deodexing BrowserProviderProxy.apk [DONE]
Deodexing Calculator.apk [ERROR]
Deodexing Calendar.apk [ERROR]
Deodexing CalendarProvider.apk [DONE]
Deodexing CellBroadcastReceiver.apk [DONE]
Deodexing CertInstaller.apk [DONE]
Deodexing ChargingAlbum.apk [ERROR]
Deodexing Chrome.apk [ERROR]
Deodexing CloudPrint.apk [ERROR]
Deodexing DocumentsUI.apk [DONE]
Deodexing DownloadProviderUi.apk [DONE]
Deodexing Drive.apk [ERROR]
Deodexing EmergencyData.apk [DONE]
Deodexing FaceLock.apk [DONE]
Deodexing Galaxy4.apk [DONE]
Deodexing Gmail2.apk [ERROR]
Deodexing GoogleCalendarSyncAdapter.apk [DONE]
Deodexing GoogleContactsSyncAdapter.apk [DONE]
Deodexing GoogleTTS.apk [ERROR]
Deodexing Hangouts.apk [ERROR]
Deodexing HoloSpiralWallpaper.apk [DONE]
Deodexing HTMLViewer.apk [DONE]
Deodexing Huawei_Swype_for_Huawei.apk [ERROR]
Deodexing HwAllBackup_Local.apk [ERROR]
Deodexing HwBluetoothImport.apk [DONE]
Deodexing HwCAService.apk [DONE]
Deodexing HwDeskClock.apk [ERROR]
Deodexing HwFileManager.apk [ERROR]
Deodexing HwFingerprintService.apk [DONE]
Deodexing HwFloatMms.apk [ERROR]
Deodexing HwFloatTasks.apk [ERROR]
Deodexing HwFMRadio.apk [ERROR]
Deodexing HwKaraokeEffect.apk [DONE]
Deodexing HwLauncher6.apk [ERROR]
Deodexing HwMediaCenter.apk
Huawei are using software engineering tools that are not readily available.
Huawei werden mit Software-Engineering-Tools, die nicht ohne weiteres verfügbar sind
