Bootloop Ascend Mate 7 TL10
  • 30 Antworten
post the error
d:
fehler posten
C:\Tools>fastboot format recovery
formatting 'recovery' partition...
FAILED (remote: Command not allowed)
finished. total time: 0.016s
C:\Tools>fastboot oem unlock
FAILED (remote: data parse fail)
finished. total time: 0.000s
C:\Tools>fastboot erase boot
erasing 'boot'...
C:\Tools>fastboot erase system
erasing 'system'...
C:\Tools>fastboot boot boot.img
creating boot image...
creating boot image - 7809024 bytes
downloading 'boot.img'...
OKAY [ 0.796s]
booting...
finished. total time: 0.811s
C:\Tools>fastboot boot recovery-img
cannot load 'recovery-img': No such f
C:\Tools>fastboot boot recovery.img
creating boot image - 9748480 bytes
OKAY [ 0.998s]
booting...
finished. total time: 1.014s
fastboot oem get-bootinfo
unlock bootloader first
or Ask a user on xda for a cwm backup stock firmware
d:
bootloder entsperen oder nach cwm backup fragen.
yes dload by holding vo+ how ever or recovery an update how ever.
d:
dload flashen und so
mm ..dont load dload ..don't enter on recovery
..i've loss the boot? i have white-black scren alternate on-off .. is possible flash the boot? take from umpack rom?
go to fastboot
fastboot reboot recovery
Du musst Vol+, Vol- drücken und dann den Power-Knopf...
Dann solltest Dein Update starten...
You' ve to pull Vol+, Vol- AND then the power-button - - > 3 keys and hold roundabout 10 seconds.
Try this, please.
if you dont boot in recovery try:
you can flash:
fastboot flash recover recovery.img
fastboot flash boot boot.img
fastboot flash system system.img
fastboot reboot
Das übersetze ich jetzt nicht auf Deutsch.
Reaktionen: Radagast
mit dem, was geht, um das Telefon zu starten?
zu fehlen scheint ..
with what starts to boot the phone?
seems to be missing ..
does not take the reboot into recovery
I go with flash system
Der ursprüngliche Beitrag von 22:41 Uhr wurde um 22:46 Uhr ergänzt:
wow in this time i have start dload
isabella I have to offer to you a dinner
You're right :D
Isa is our super-joker ;)
GZIO
Ingrimmsch
Ingrimmsch
GZIO
GZIO
GZIO
GZIO
Ingrimmsch
Ingrimmsch
