[ROM] 18/10 ViperOneM9 5.2.0 ◦ Tweaks | HUB | Sidebar | OTA ○ 1.95.401.3
  • 513 Antworten
Es gibt ein neues Update, mit "kurzem" Changelog:
mikalovtch;71863124 schrieb:
ViperOneM9 6.1.0 (14th April)
The rom is based on the new HTC's base! The full wipe is recommended!
Additions & Updates
  • Rebased to 4.28.401.3
  • Updated to Magisk 12.0
  • Updated to MagiskManager to 4.3.1
  • Reorganized and cleaned up VenomTweaks
    • Reduced the settings per tab to make it clearer
    • Introduced more subsections for those instead
    • Extracted some settings to own tabs
    • Moved some settings to the right place
  • Double Tap anywhere on homescreen to turn off the screen
  • Swipe Down anywhere on homescreen to expand the statusbar
  • Datausage info line (longpress opens data usage settings)
  • Option to choose the desired networkmodes you want to toggle with the neqs networkmode tile
  • Option to choose to toggle to LTE Only instead of LTE Auto for the HEQS LTE Quicksetting
  • Custom colored notifications can expand child notifications now
  • Change the background, text and icon color of all info lines at once
  • Improved disable vibration systemwide - vibratepattern was not handled
  • Option for Signal Icons on left
  • Option for Battery on left
  • Option to remove app drawer, places all your apps on your homescreen instead
  • Change switches track and thumb color system wide
  • Settings icons take color of the one you select for the checked thumb switch state.
  • Custom calender shortcut now also working for the header
  • Option to hide the date in the header
  • Added additional html time formats in VenomTweaks, includes now three new ones with date included
  • Swipe Up on homescreen to open appdrawer
  • Random Animation and Interpolation type
  • Whitelist for random Animation and Interpolation types
  • Custom shortcut for appdrawer (previous option was just for custom applications)
  • Option to hide lock icon on lockscreen
  • Option to set a custom image for your lock icon
  • Made signal strength tweaks visible again, adds option to show signal strength with either dbm or asu level
  • Three finger gesture will show a short toast now for toggable modes
  • Updated HTC Lockscreen with current playstore version
  • Updated HTC Sense Home with current playstore version
  • Made switch track color visible when preference is disabled
  • All incompatible preferences are disabled when AOSP lockscreen is selected
  • Option to swap volume keys when in 90° landscape orientation
  • Custom ListView animations
    [YOUTUBE]un6oQC62peI[/YOUTUBE]
    • 13 different animations
    • 9 different interpolations
    • blacklist option
    • customize duration
  • Opening apps in VenomSidebar, Quicklaunch, HEQS and NEQS will bring the app to the top now, instead opening a new instance
  • Readded Overlay warning dialog when granting permissions - Google removed that for some reason
  • Added "Ignore" Button to the overlay warning dialog
  • Added option to hide header footer text (Like on active VPN connection "Device may be monitored")
    • You find the option in VenomTweaks->Statusbar->Customize->Header with clock
  • Custom Appdrawer Background color with transpareny support
  • Set dimming level of lockscreen
  • Set dimming level of secure lockscreen (pin/pattern)
  • Last app action brings app to the top instead of starting a new instance
  • Longpressing sync tiles in neqs opens sync settings now - very hacky implementation, sry google for messing up your code.
  • Several UI enhancements in VenomTweaks
    • Nougat seekbars
    • Nougat toggles
    • Fixed title font size of seekbar preferences
    • Material like revert buttons
    • Changed ColorPicker Dialog layout, so the keyboard does not interfere
  • Added "Sync All" QS Tile (Syncs all accounts in Settings->Sync & Accounts)
  • Added QS Tile to toggle AutoSync
  • Increased column count to 5 in the QS Customizing Panel
  • Added option to disable child notifications
  • Sense Home custom open app animations
    • Bounce
    • Fade
    • Push Down
    • Push Left
    • Push Right
    • Push Up
    • Rotate
    [YOUTUBE]zf_7y0jlfro[/YOUTUBE]
  • Added screenshot and partial screenshot action to three finger gestures
  • Added partial screenshot as button mapping action
Fixes & Cleanups
  • Fixed headsup timeout
  • Fixed clock color resetting temporarily when expanding and collapsing the statusbar
  • Fixed Last app still starting a new instance, instead of bringing an already open app to foreground
  • Fixed lockscreen opacity value not sticking in VenomTweaks
  • Fixed FakeIMEI not working
  • Fixed three finger tab vibration not happening
  • Fixed custom weather shortcut for weather widget in notification pulldown
  • Fix Google Now mappings not working on stock navbar
  • Fixed Ambient Notifications Whitelist not being accessible in VenomTweaks (No one reported it, so it seems no one is using that feature, wasted days on it to get that working, LOL)
  • Fixed Sprint bootanimation (Fullrom only)
  • Revert to official Sense Home
  • Fix three finger gesture "Go to previous app" action
  • Fixed three finger gestures: Moved implemenation to native framework. Works instantly after boot now and does not require selinux to be permissive.
  • Fixed custom overscroll color not working
  • Fixed cropping images with google photos in VenomTweaks not taking right aspect ratio
  • Fixed decrease neqs panel causing empty panel after reboot
  • Fixed Notification Screen On Setting not working
  • Fixed wrong description in color settings
  • Fixed custom weather, clock, calender shortcuts not working
  • Fixed folder transpareny default values
  • Fixed Sense Home force closing when resetting to default settings in VenomTweaks
  • Fixed perms of bootsound..didn't work before when enabled in VenomTweaks
  • Fixed custom autobrightness not working at all
  • Fixed notifications with child notifications not expanding
FULLROMS:
Viel Spaß, beim flashen.
Reaktionen: Sparren und Holli33
Das ist ein Antwort.So zum sagen hey Leute Team Venom ist wieder da. Danke freue mich.
Das liest sich super... und echt praktische Sachen dabei!
schöne Ostern
Gibt's irgendwo die firm ? Am liebsten mit twrp ...
Und kann ich beim installieren einstellen das ich auch den internen Speicher platt mache ?
Da hat sich soviel misst angesammelt ...
Aber wie ? Bei Full wipe ? Im Aroma oder twrp ?
Im Aroma wirst du gefragt, wie du installieren willst, dann wähle die Option mit wipe. Weiß jetzt nicht auswendig wir die genau heißt
Ja , hatte ich bei der 6.0.0 ja auch so gemacht , aber der ganze misst war noch da ...
Du kannst es zur Sicherheit natürlich vorher auch in twrp machen oder du nimmst die fw die alles platt macht. Da hatte ich aber etwas Probleme das Rom über twrp zu installieren. Ist aber schon lange her
Die 6er läuft auch gut so wie es ist , Aber wenn ich die 6.1.0 drauf mache , würde ich gern von Null anfangen und nicht den Dreck von der 4er bis jetzt mit schleppen ...
Ich Versuchs einfach mal ... Danke dir ...
Genau, gerne
hab gerade die neue Version installiert (mit wipe) und bei mir klappt die "ok google" Sparcherkennung nicht. Sprachmodel ist trainiert, Einstellung und Berechtigungen sind aktiviert.
klappt das denn bei euch?
Es gibt ein neues Update, für die Viper:
mikalovtch;74031056 schrieb:
ViperOneM9 6.2.0 (4nd October)
Fullrom only
Additions & Updates
Full Nougat Sprint Support Thanks to @thicklizard
Working Handsfree activation
Working Sprint Apps
Fixed tethering
To be able to change PRL, flash the Fix in VenomHUB
Full T-Mobile Support
Working Wi-Fi Calls
Full Verizon Support
Latest Verizon base 4.49.605.11 Thanks to @santod040 for posting RUU.
Working Advanced Calling
Fixed sdcard issue
Updated to Magisk v14.0 & Magisk Manager v5.3.0
Additions & Updates
Added 5x6 appdrawer Thanks to @fichl.
Option to set quicksettings rows count for portrait and landscape
Sliders in VenomTweaks match now the switch colors
Updated to latest Sense Home
Fixes & Cleanups
Fixed camera open doubletap power
Fixed hidden battery icon reappearing for some randomly or after a reboot
Fixed Colorpicker Dialog not usable on huge display and font size
Fixed 3-Finger toogle action
FULLROMS:
Reaktionen: DrAlenFeinstone und Holli33
