Bisasam
Hallo, wurde hier inzwischen eine Lösung gefunden für das Problem mit dem nicht angezeigten Internen Speicher?
03-12 16:20:01.864 478 532 E sdcard : opendir /data/media/0 failed: Permission denied
03-12 16:20:02.004 478 533 E sdcard : opendir /data/media/0 failed: Permission denied
03-12 16:20:02.004 478 532 E sdcard : opendir /data/media/0 failed: Permission denied
# Android fstab file.
# The filesystem that contains the filesystem checker binary (typically /system) cannot
# specify MF_CHECK, and must come before any filesystems that do specify MF_CHECK
#TODO: Add 'check' as fs_mgr_flags with data partition.
# Currently we dont have e2fsck compiled. So fs check would failed.
#<src> <mnt_point> <type> <mnt_flags and options> <fs_mgr_flags>
/dev/block/platform/msm_sdcc.1/by-name/userdata /data ext4 nosuid,nodev,barrier=1,noauto_da_alloc,discard,errors=panic wait,check,encryptable=/dev/block/platform/msm_sdcc.1/by-name/extra
/devices/msm_sdcc.2/mmc_host auto vfat defaults voldmanaged=ext_sd:auto,noemulatedsd
/devices/platform/xhci-hcd auto vfat defaults voldmanaged=usb:auto
# Android fstab file for enabling zRAM on 2GB device
# zramsize is mandatory and indicates how much uncompressed memory you want the zram area to hold.
# Compression ratios in the 30-50% range are usually observed.
#<src> <mnt_point> <type> <mnt_flags> <fs_mgr_flags>
/dev/block/zram0 none swap defaults zramsize=107374183,swapprio=1000
/dev/block/zram1 none swap defaults zramsize=107374183,swapprio=1000
/dev/block/zram2 none swap defaults zramsize=107374183,swapprio=1000
/dev/block/zram3 none swap defaults zramsize=107374183,swapprio=1000
