4dro1d
Enthusiast
- 1.503
Allgemeine Fragen zur Installation bitte hier stellen...
Scheint so als hättest du ein Problem mit dem Clockworkmod.Der Lädt und schreibt gogogo und bleibt dann hängen. Habs extra paar mal probiert und hab extra längere zeit gewartet.. jedoch tut sich nix mehr. MAche ich was falsch?
1. First make sure you have at least 1 Fat32 partition and 1 EXT4 partition on your sdcard
2. If you don't have these partitions ?? backup your sdcard , because everything will be wiped from your sdcard when you create partitions and format them !
3a Use the provided 4EXT recovery (NAND or SD version) to create the partitions and format them.
3b If you rather use a computer for creating and formatting partitions keep in mind that both partitions must be primary partitions (not logical)
4. The recommended size of your EXT4 partition is depending on how many roms and apps you are going to install.. 512M is the minimal size..
5. Restore/move the sdcard contents back to the Fat32 partition
6. (WP7 users) make sure the EXT4 partition is located @ /dev/block/mmcblk0p2
To check this mount your sd-ext partition in 4EXT recovery and use adb shell or QtADB shell and type df
7. Your sdcard is now ready for NativeSD usage..
1. Boot into recovery by executing the usual clcad and haret stuff inside the Recovery folder.
2. Flash the ROM.zip package and follow instructions
3. Reboot and boot the ROM by executing the usual clcad and haret stuff inside the NativeSD folder.
http://forum.xda-developers.com/showpost.php?p=31110719&postcount=2- as of dual installer v2 you can choose your data connection during ROM installation
- For Magldr users I recommend using the RMNET connection
- For all other users I recommend using the PPP connection (default)
- PPP connection should work for all users !
Ja, und lande in 4ext Recovery v2.2.7 RC5.die 4Ext für SD, entpackst diese auf die SD und startest die haret.exe oder clard.exe unter WM6.5.
Dann müßte das Telefon in die Recovery rebooten.
hmm, da ist der Knackpunkt.das Zip auf die Fat32 der SD und mit der Recovery flashen
nicht. Wo finde ich die Version?CWM Touch SD-Version
misc ya 1M
recovery rrecov|ro|nospr filesize recovery-raw.img
boot yboot|ro 5M
system ya 150M
cache ya 2M
userdata ya|asize|hr allsize
Ja, dann installiere es doch!hmm, da ist der Knackpunkt.
Die Anleitung (den Fred) kenne ich, aber der will 4EXT Recovery als Bedingung.
Thx, für die Bestärkung...Du brauchst do nur "install from sd card" auswählen.
