Peri25
Dauer-User
- 274
Super danke, Ich warte bis die neue kommt. Hast du mein Post vorher gelesen? ist das normal das kein Setup kommt nach einem Fullwip?
j to the 4n;70227870 schrieb:
Viper10 4.4.0 (23rd December)
Additions & Updates
- First Magisk compatible rom available
- Keeps all carrier related features working, like VoLTE, WiFi-calling etc. Passes safety net by default.
- Requirements: Stock rom (RUU), phh su and Magisk
- Uncheck the module in Magisk Manager to have a 100% stock rom again
- OTA engine is compatible with that Magisk version
- WIP: VenomHUB Addons need to migrated to be magisk compatible. For now don't flash them.
- Updated to latest SuperSU 2.79
- Added NEQS UserTile
- NEQS theming is also applied on Multiuser panel now
- Updated Visual Theming
- Updated notification pulldown to Android N
- Added visual theming for APM
- Updated to new Sense Home from Playstore
Fixes & Cleanups
- Fixed system r/w toggle on Advanced Tab
- Fixed issues with system r/w actions on phh su, things like toggling bootsound, installing bootanimations work properly now
- Fixed issues with packageinstaller
- Fixed issues with busybox
- Fixed issues with su.d not working (fullrom only)
- Fixed multiuser not hiding
- Fixed multiuser not working on verizon (fullrom only)
- Fixed quicklaunch not showing any apps after reboot
- Fixed custom neqs tiles not getting added
- Fixed custom neqs tiles theming
- Fixed issues with white space in header if enabled many infolines and other widgets below clock
- Fixed infinite scrolling on homescreen
OTA:
As usual available via Settings->About->Software Update or VenomTweaks->Advanced->OTA Update
FULLROMS:
MAGISK Version:
The Magisk version and instructions how to install it are also available via the above link.
The huge advantage of the magisk version is, that the rom itself won't touch the /system partition and so will pass safety net by default.
Additionally all carrier features that work on stock will also work now on the magisk sideloaded Viper10 rom. Means VoLTE, Wi-Fi Calling and other stuff will work.
Be aware not to modify anything on /system, else you break safety net, and mentioned carrier features.
We made the OTA engine magisk compatible, so the next update you can flash without worrying about it.
The VenomHub Addons are NOT magisk compatible yet...that need to wait till the next year.
Credits to [MENTION=4470081]topjohnwu[/MENTION] ofc for magisk and for helping out on that module..and actually everywhere he can. Also credits to [MENTION=4637027]Black-FR[/MENTION] and the others guys (I don't know the xda names) for the testing and [MENTION=2605798]nkk71[/MENTION] for being a sed god.
Ich werde es mal probieren.Black-FR schrieb:Hast du es mal mit magisk hide versucht?
(Ist im magisk Manager zu finden... dort die gewünschte App hinzufügen)
