rickydavid
Das ist bei mir momentan.
j to the 4n;68666046 schrieb:
Viper10 3.1.0 (19th September)
Additions & Updates
- Temperature Infoline
- Battery
- CPU
- GPU
- Thanks for the extra work you sons of murricans. Supports Fahrenheit - Setting is pulled from the HTC Weather app.
- Theme Brigthness Slider
- Slider
- Thumb
- Autobrightness button
- Extended Wifi,Bluetooth and DND Settings Panel are getting themed now
Fixes & Cleanups
- Fixed Visual Theming FCing when the header wasn't reorderd once
- Header clock color can be applied now without setting an HTML preset
- Added required statusbar reboot for some visual theming items
OTA is available via Settings->About->Software Update or VenomTweaks->Advanced->OTA Update.
Fullroms will follow later..or at the weekend, will be away for two days (developer meeting from my company).
ivicask;68666749 schrieb:
