[KERNEL][6.0.1]AK Kernel Nexus 6P (AOSP /CM13)
  • 32 Antworten
bearclaw
bearclaw
Dauer-User
502
Allgemeines:
Official Site: ak.hiddenbytes.org
Full Changelog: Github Link
A kernel for Nexus 6P:
XDA Thread: [KERNEL] [12/02] [AOSP/CM13] [F2FS] [3.10.96+] [UBER5.3] ☆ AK ☆ [v. 039 - v. 039.EAS]
Install/Uninstall: Link
Kernel Control: Synapse
Kernel Updater: Donwload v1.4
Kernel Profiles thread: Link
Downloading: AK Kernel
Features:
AOSP & CM13 Compatible
Ramdisk Anykernel Format (We can flash over any Roms)
Merged latest Android Patches
Latest security Patches Inside
Linux 3.10.97+
Google 3.10 Common branch merged
Multirom Support
Kali Net-Hunter Support
Mouse and KeyBoard support
Optimized RCU
Thermald Engine Optimized
F2FS Support (Latest Patches from Stable Main Branch)
A53: Min 302Mhz, Max 1708Mhz
A57: Min 302Mhz, Max 2054Mhz
Zen tune from Manjaro Kernel
Enabled power_efficient workqueues
Optimized Memcopy/String Libs
Compiled with Latest Uber Toolchain 64bit - Version 5.3
Makefile flags Optimizations
Schedulers: Deadline, Noop, Row, Cfq, Fiops, Bfq, Sioplus, Zen, Tripndroid
Software CRC Control
Memory Card clock control
Laptop Mode Control
Governors: Interactive, Conservative, Ondemand, Powersave, Performance, Impulse, ElementalX, ZZmoove
CPU Boost
MSM Perfromance Driver Control
GPU Boost control for Gaming Performance
KCAL Control with Profile Support
Z-RAM
Gestures Control: DoubleTap2Wake, Sweep2Wake, Sweep2Sleep
Vibrator Light/Strong Control
TCP Congestion Control (Default Westwood)
Low Memory Killer Control
SE Linux Control
State Notifier
WakeLock Control (wifi, proximity, modem, Bluetooth)
Headphone sound boost control
Enhanced cpu boost drivers
Drive droidsupport (mountcdrom)
Backlight Dimmer
High Perfomance Audio Processing
High Brightness Mode
Optimized lib sort
Optimized memset/memcpy
Optimized Rwsem
Installation:
- Einfach per CustomRecovery (TWRP) installieren.
Version Information
Status: Stable
Last Updated 29.02.2016
Reaktionen: Ravenna
Neue Version Version AK 0.24 ist draußen. OP upgedatet.
Und schon wieder eine neue Version.
AK 0.25
--- Beiträge zusammengeführt -
SMALL CHANGELOG
cpufreq patches
updated random32
added bluesleep wakelock control
ecc ecc
Version AK 0.26 ist draußen.
Jetzt ist der Kernel auch mit CM13 kompatibel
hast schon jemand Erfahrung mit dem Kernel zwecks Batterie und die Stabilität ?
Er läuft sehr stabil. Von der Akku Laufzeit bringt er etwas mehr als der Standard Kernel in der Pure Nexus Project Rom. Aber der ist auch schon sehr gut eingestellt.
naja habe CM 13 laufen mit Stock Kernel daher.
Also wie gesagt, ich hatte auf dem one plus den kernel auch auf einer cm basierten Rom. Dort war die Laufzeit deutlich besser.
ich werd ihn mal Testen ganz am anfang wie du denn Thread erstellt hast hatte ich ihn mal geflasht kam aber bootloop. jetzt hast du aber hier ein update drin mit cm 13 kompatibel. Teste ihn mal.
Neue Version ak 0.28 ist draußen
SMALL CHANGELOG
compiled with new uber tc 5.3.x
various fixes and patches
ecc
Habe nun endlich seid letztem Freitag nach einem kurzen zuk z1 Ausrutscher mein Angler und aufgrund verschiedener Detail Einstellungen mittlerweile die cm13 basierte und in unseren breiten leider zu wenig beachtete MoKee Rom MK 60.1 in der aktuellen nightly Version am laufen....Nun zu meiner eigentlichen Frage mit dem cm MoKee stock kernel ... Zeigte "der Gerät" immer schnelles laden an....und die Ladezeit von unter 20% auf 100% Prozent lag unter 60 min....mit dem AK kernel 031er Version zeigt es das nicht mehr auf dem sperrbildschirm an sondern nur noch aufladen und es braucht gut doppelt so lang . hat der AK kernel die Funktion nicht....oder muss ich sie in der Synapse APP etwas spezielles aktivieren?? Danke im voraus für euer feedback.....
Also bei mir zeigt es schnelles laden an.
bearclaw schrieb:
Hast du irgendwas an den Einstellungen verändert, oder den ak einfach so am laufen?
Hab mit den verschiedenen Profilen rumgespielt, war wohl die meiste Zeit auf dem ENexus Conservative V2 Profil, hab aber wie gesagt die anderen profile eingestellt und mit perfmon geschaut, welche Auswirkungen sie auf die Geschwindigkeit/performance bzw. Auf die Frequenz haben. Fand das ENexus Conservative super, klasse Performance selbst bei Spielen und trotzdem super Akku.
Reaktionen: bearclaw
Und welcher ist in deinen Augen der beste für normale Nutzung ( Whats App , Internet , Wlan , 4G ... keine spiele ) ? :)
[doublepost=1454355361,1454353999][/doublepost]Also. Kann sagen das CMTE und AK34 mit textdroider dpi auf 530 DPI funktioniert :)
Ich fand wie gesagt ENexus Conservative V2 super, gaaaanz leichte lags hin und wieder aber die nehme ich in Kauf für gute Batterie. Wenn du nicht spielst kannst du ENexus endurance V2 versuchen, das ging bei mir bei den Spielen zu langsam und Batterie hab ich auch keinen allzu grossen Unterschied zum Conservative Profil gesehen.
Um wirklich ein wirklich aussagekräftiges Testergebnis abzugeben muss ich aber ein Profil über mehrere Tage testen und vergleichen, da aber zzmove neu dazu kam muss ich schon wieder neu testen
Ich kann in Synapse nur diese auswählen :confused2:
Schau mal im Ak Profiles thread vorbei [PROFILES] [AK KERNEL] [6P] AK Kernel Synapse Profiles thread for the NeXus 6P
I'm 3. oder 4. Beitrag findest du Mambas verschiedene profile. Da einfach das ENexus Conservative oder endurance runterladen und in den synapse Ordner (profile) kopieren.
Dann in synapse gaaaanz nach links zu den Profilen Wischen, Profil auswählen, Haken drücken und dann restore profile.
Synapse startet dann neu, dann noch so lange auf das X drücken und Synapse neu starten bis kein X mehr erscheint.
Ich finde synapse persönlich etwas zu kompliziert und unausgereift, einfach nicht intuitiv genug, aber man kann wohl am meisten einstellen - so whatever works [emoji4]
Bei mit erscheint die tgz nicht wenn ich sie einfügen. :-/
[doublepost=1454358614,1454358523][/doublepost]Nun hat er es :)
Ich habe die ganze Diskussion mal in den passenden Thread verschoben. :)
ergenekon
  • Hunter04
Bourbon
  • macke007
fazerdirk
fazerdirk
