hanspampel
Ehrenmitglied
- 9.865
Da es hier im Bereich ja so gut wie nix gibt, stelle ich hier mal nen OC Kernel fürs N10 vor.
Download CWM flashable KERNEL zip
Settings für KTweakerT App
****** Thermal throttle interface ******
Governors und schedulers erklärt:
Voltage Anhaltspunkte für UV'ler
Funktionserklärung der Battery-Safer Einstellungen:
Quelle
Ktoonsez presents:
KTManta kernel features
•Built with Linaro 4.7 so its 8,000,000,000,000 times faster
•Linux kernel 3.4.74
•Google/Samsung open source
•Optimized kernel configuration
•unsecure root adb
•init.d support
•Governors (MSM-DCVS, ABYSSPLUG, BADASS, SUPERBAD,LAGFREE, SLEEPY, SCARY, SMARTASSV2, WHEATLEY, LAZY, ADAPTIVE, INTERACTIVE, PEGASUSQ, LULZACTIVE, KTOONSERVATIVE, CONSERVATIVE, ONDEMAND, USERSPACE, PERFORMANCE) (most of these coming soon)
•Schedulers (CFQ, BFQ, VR, SIO, NOOP, DEADLINE)
Download KTweakerT App V3.4
Installationshinweis:(This download is an installable apk file from any File Explorer, not a flashable zip file. ***** IF AFTER YOU DOWNLOAD IT YOUR BROWSER CALLS IT COM.ZIP, RENAME IT TO COM.APK AND INSTALL IT!!!!!!!!!!!! *****)
Download App
ChangelogImmer nach der Installation des Kernels zu tun:
1. Clear cache
2. Clear dalvik
3. Fix Permissions
ältere ChangelogsChange Log 04.06.2014
1. ktoonservative: Added up_freq_threshold_hotplug from @bosskindern
2. ktoonservative: Added down_freq_threshold_hotplug from @bosskindern
3. ARM: appropriate CFLAGS for Exynos5
4. ARM makefile : CFLAGS updated
5. CPUFREQ : pegasusq.c updated
6. Linux 3.4.75
7. Linux 3.4.76
8. Linux 3.4.77
9. Linux 3.4.78
10. Linux 3.4.79
11. Linux 3.4.80
12. Linux 3.4.81
13. Linux 3.4.82
14. Linux 3.4.83
15. Linux 3.4.84
16. Linux 3.4.85
17. Linux 3.4.86
18. Merge in CM latest ramdisk for CM compatibility
19 Upgraded to latest Linaro.
Change Log 12.12.2013
1. Linux 3.4.73
2. Linux 3.4.74
3. Merge in source drop from 4.4.1
4. Merge in ramdisk from 4.4.2
5. Heads up to anyone wondering, KTweaker DOES with with FART and dalvik modes.![]()
Change Log 12.08.2013
1. Created duplicate permissions lines in ramdisk for CPU sysfs items for the stubborn devices.
Change Log 12.07.2013
1. Linux 3.4.71
2. Linux 3.4.72
3. CM 11 support!!!!!
Change Log 11.25.2013
1. Fixed GPU locking at certain frequency
Change Log 11.24.2013
1. Linux 3.4.68
2. Linux 3.4.69
3. Linux 3.4.70
4. Updated toolchain
Change Log 11.23.2013
1. Merged in Google source for Kitkat version
2. Upgraded video/gpu drivers
3. Upgraded wifi to version 1.88.45
Change Log 10.31.2013
1. Changed Ramdisk to support Purity/Stock ROMs and keeping CM compatibility
2. Happy Halloween
Change Log 10.28.2013
1. Ramdisk updates for CM and AOKP compatibility
2. Linux 3.4.48 - 3.4.67
3. Wifi upgrade to 1.88.45
4. KTweaker update to 4.3 Google API
5. Soooo many more...............
Change Log 8.4.2013
1. Merged in newest CM10.2 stuff from pulser_g2 so you guys should have full CM10.2 compatibility
Change Log 7.28.2013E
1. Fix GPU Mhz locking at specific Mhz
2. Fix GPU table BUG_ON issue that caused reboots on set on boot options and "Load Default Settings"
1. Fully upgraded to 4.3!!!!!!!!!!!!!!!
2. Linux 3.4.48
3. Linux 3.4.49
4. Linux 3.4.50
5. Linux 3.4.51
6. Linux 3.4.52
7. Linux 3.4.53
8. Linux 3.4.54
9. Re-linaro source from upgrade
10. Merge in newest ramdisk
Change Log 5.14.2013
1. Linux 3.4.42
2. Linux 3.4.43
3. Linux 3.4.44
4. Linux 3.4.45
5. A few GPU updates
6. Monster update for wifi going to version 1.88.16
7. deadline: Allow 0ms deadline latency, increase the read speed
8. block: urgent: Fix dispatching of URGENT mechanism
9. Updates to Interactive gov
10. Bunch of low level memory/hrtimer patches
11. Checkout my github for complete list, Im exhausted.......
Change Log 4.19.2013
1. FIXED VIDEO ISSUE
2. Linux 3.4.40
3. Linux 3.4.41
4. Updated ROM scheduler
5. GPU ION updates
6. SMP updates
7. Several fs updates
8. Optimize lib/memcopy functions
9. bcmdhd: tweaked wakelocks a bit
10. Thats all I remember......
Change Log 4.8.2013
1. NEW GPU OC STEPS!!!! 667 and 720
2. All steps are now divisible by 25 by default
3. Changed KTweaker (now version 3.0) to only let you do steps in 25's for GPU
4. Linux 3.4.35
5. Linux 3.4.36
6. Linux 3.4.37
7. Linux 3.4.38
8. Linux 3.4.39
9. New updated scheduler IO settings from Enigma1987, Osmosis and Malaroths
10. Chipset speed boosts
11. Higher bus speeds to feed the higher GPU speeds
12. Too many upstream updates from google to mention, check out my github if you want to know
13. Make file optimizations
Change Log 3.2.2013b
1. REVERT: Ignore disable_hotpluging while screen is OFF
2. Cleaned up some unnecessary dmessaging
3. serial: samsung: fix leaked requested irq
4. Fix under-sized array while mounting external sdcard's
Change Log 2.28.2013
1. Linux 3.4.34
2. Got Screen OFF Governor going.
3. Added Screen OFF scheduler, this DOES restore your custom settings when screen comes back on
4. KTweaker 2.9 with added "Screen OFF scheduler" option under "Extras"
Change Log 2.27.2013
1. Added battery level MAX MHZ setting for CPU and GPU
2. KTweaker 2.8
3. Linux 3.4.33
4. Added FIFO and FIOPS schedulers (thanks haskerl)
5. Using Ubuntu 12.10 arm-linux-gnueabihf compiler (thanks haskerl)
6. A bunch of new -O3 compiler optimization flags added
7. Lots of upstream google updates
8. ktoonservative will now Ignore disable_hotpluging while screen is off to save some battery
9. Thats all I can remember
Change Log 2.20.2013
1. All the same stuff as 2.18b + THE COLOR TWEAKS RESTORED FROM TEST KERNELS
Change Log 2.18.2013
1. Linux 3.4.30
2. Linux 3.4.31
3. Linux 3.4.32
4. Merged in some CM stuff
5. Compiling CIFS as module
6. Some GPU optimizations
7. A few google updatesChange Log 2.7.2013
1. net: wireless: bcmdhd: Update to Version 1.28-27
2. Added ASIX LAN Support
3. netfilter: xt_qtaguid: Allow tracking loopback
4. Re-arrange some code on ktoonservative for efficiency
Change Log 2.4.2013
1. Linux 3.4.29
2. Enabled -O3 Linaro optimization flag so it 40 trillion times faster, lol!!!!!!!!!!!!!!!
3. Upgraded to Linaro 4.7-2013.01-1-2013
4. sync: don't log wait timeouts when timeout = 0
Change Log 2.2.2013
1. KTweakerT update to 2.7.1, fixed issue where settings were not saving in Thermal Throttle screen
2. block: row: Idling mechanism re-factoring
3. block: row: Dispatch requests according to their io-priority
4. CPU/GPU: adjust MIN/MAX for devices regulators (regulator will now take values all the way down to 700)
Change Log 1.30.2013
1. Ktoonservative: Added no_2nd_cpu_screen_off setting to give the ability to keep 2nd core off while screen is off.
2. netfilter: xt_qtaguid: extend iface stat to report protocols
3. net: wireless: bcmdhd: Fix WD wakelock behavior
4. net: wireless: bcmdhd: Postpone taking wd_wake lock
5. net: wireless: bcmdhd: add check for wake_lock_active on wdwake
6. FIX mismerge from Linux 3.4.8
Change log 1.25.2013
1. Brand new thermal throttling routine (I played Beach buggy for about 3 hours straight before it started to stutter a little bit when crashing into things, lol)
2. You can adjust the minimum Mhz to drop to during thermal throttling, default is 1200000 (1200 Mhz), sysfs file is here (I will get this in KTweaker when I get a chance)
"/sys/devices/system/cpu/cpufreq/cput_attributes/min_throttle_mhz"
So, to layout the logic, the throttling will only got down to 1200 Mhz (if necessary) until you reach your set "start_throttle" temp +15, then it allows throttling down to 800 Mhz, if "Tripping" occurs it allows throttling down to 500 Mhz.
Change log 1.24.2013
1. MAJOR additions to ktoonservative so it is fully configurable for all different needs
2. Ktoonservative renamed "boostpulse_value" to "boost_cpu"
3. Ktoonservative added "boost_turn_on_2nd_core": Set to a 1 to turn on 2nd core during touch boost, 0 to not.
4. Ktoonservative added "boost_gpu": Set to 0 to NOT boost GPU during touch boost or use, 100 or 266 or 350 or 400 or 450 or 533 or 612 to boost the GPU to that Mhz.
5. Ktoonservative added "boost_hold_cycles": Set to a value to hold the boost for, as usual 22 = approx 1 second.
6. Ktoonservative added "disable_hotpluging": Set to a 0 to leave hotplugging enabled, set to 1 to NEVER hotplug which will leave the 2nd core on full time.
7. Linux 3.4.27
8. Fix for empty app-mounted directories (This was requested by Kroenen66)
9. lib: cpu_rmap: avoid flushing all workqueues
10. Lots of debug code removed to reduce dmesg
Change Log 1.18.2013
1. Linux 3.4.26
2. KTweaker 2.6.2, added GPU current speed to "General"
3. Couple tweaks to GPU OC/UC control
4. Added boost-pulse to Ondemand as promised
5. About 50 patches from google upstream source
6. Some tweaks to deadline scheduler
7. Thats all folks.............. (out of town all this weekend and next week for work so time was limited on this release)
Change Log 1.11.2013
1. Linux 3.4.25
2. Tweak to ktoonservative that seems to have killed the crackle while playing music.
3. Couple patches to KTweaker
Change Log 1.6.2013
1. Update ktoonservative boost pulse to check current Mhz to make sure it doesnt downscale it.
2. Update pegasusq boost pulse to check current Mhz to make sure it doesnt downscale it.
Change Log 1.5.2013-F
1. Linaro optimization compiler flags
2. Added Touch Booster to ktoonservative to behave just like interactive
3. FIXED TOUCH BOOSTER LOCK ISSUE
4. Use boostpulse_value in Governor Adjustments to set the Mhz to boost to. 1000Mhz is default.
5. Added Touch Booster to pegasusq to behave just like interactive
6. Lots of build.prop optimizations from EniGmA1987, here they are:
kernel.random.read_wakeup_threshold=1024
kernel.random.write_wakeup_threshold=2048
kernel.shmmax = 256MB
net.core.rmem_max = 1.0MB
net.core.wmem_max = 1.0MB
vm.swappiness = 10
vm.vfs_cache_pressure = 20
Change Log 1.2.2013
1. Raised Thermal Control upper limit to 200!
2. Ktoonservative tweaks to make it behave better on 4.2.
Change Log 12.18
1. JUMP_LABEL patch
2. Couple Linux patches from my S3 kernel
3. Improved slide2wake functionality while unplugged
4. Linux 3.4.24
5. Vibration interface is now active (valid values are between 0-49, 0 = no vibration, 49 being max stock strength)
6. Fixed up CPU/GPU tables to be divisible by 5 so they can be tweaked properly.
7. Load defaults will now load the default voltages according to YOUR specific device chip.
8. Thermal throttle interface (not implemented in KTweaker yet but can be accessed in "/sys/devices/system/cpu/cpufreq/cput_attributes" folder.
9. New KTweaker app
10. Forgot to tell you guys KTWeaker comes with a Widget, so give it a try. *Remember that widgets are very limited to what they can do. *I.E. there are no drop-lists so I can add governor selection and stuff of that nature.
1. BE VERY, VERY, VERY CAREFUL GUYS, I TAKE NO RESPONSIBILITY IF YOU OVERHEAT AND OR MELT YOUR CHIP FROM RAISING THESE VALUES!!!!!!!
2. Stock values are cpu_start_throttle = 80, cpu_stop_throttle = 78, mem_start_throttle = 85, cpu_stop_throttle = 80
3. Start values should always be higher than stop values by at least 1
4. I have a hard coded limit of 50-90 (probably as high as anyone wants to go, I set mine at cpu_start_throttle = 85, cpu_stop_throttle = 83 to test and saw temps of 108 for over 1 second a few times running benchmark apps)
5. You can also get the current temperature from the "cur_temp" file (I will add this and the adjustments to KTweaker as soon as I can)
Changelog 12.16
1. Finished GPU OC/voltage control (thanks pushistiky)
2. Some tweaks to slide2wake
Change log 12.15
1. Linux 3.4.22
2. Linux 3.4.23
3. Lots of battery savers for wifi
4. TCP tweaks for extra speed (Im loving this little opto from Babyhuey)
5. Sweep2wake is born (use KTweaker to enable it. To use it, swipe from far left to far right or top to bottom without letting go and it wakes up)
6. GPU voltage control (Use KTweaker under Voltage)
7. Updated KTweakerT
7. Updated freq table, thanks to AndreiLux for the help
8. Added ZEN and ROW scheduler
Change Log 12.03
1. KtweakerT is born
(LINK: Free Online Storage - MediaFire)
**** Only the screen OFF Mhz setting is active in Extras so far
2. Added screen off Mhz setting
3. Linux 3.4.21
4. mm/compaction.c: fix deferring compaction mistake
5. lowmemorykiller: Compact memory when killing processes
6. lowmemorykiller: Use asynchronous compaction
7. Added some Ramdisk stuff from CM10 to see if CM10 nightly's will behave!
LINK: KTManta-12-03-2012.zip
Change Log 11.29
1. Linux 3.4.9 thru 3.4.20
2. HDMI audio out fix (thanks craigacgomez)
3. Added governors (slp, intellidemand, abyssplug, badass, pegasusq)
4. Overclock/Underclock
5. Voltage control
6. That's all I can think of
LINK: KTManta-11-29-2012.zip
Change Log 11.26
1. Initial Release
LINK: KTManta-11-26-2012.zip
1. Linux 3.4.71
2. Linux 3.4.72
1. Linux 3.4.68
2. Linux 3.4.69
3. Linux 3.4.70
2. Happy Halloween
Change Log 8.4.2013
2. Linux 3.4.48
3. Linux 3.4.49
4. Linux 3.4.50
5. Linux 3.4.51
6. Linux 3.4.52
7. Linux 3.4.53
8. Linux 3.4.54
1. Linux 3.4.42
2. Linux 3.4.43
3. Linux 3.4.44
4. Linux 3.4.45
2. Linux 3.4.40
3. Linux 3.4.41
5. GPU ION updates
6. SMP updates
Change Log 4.8.2013
4. Linux 3.4.35
5. Linux 3.4.36
6. Linux 3.4.37
7. Linux 3.4.38
8. Linux 3.4.39
1. Linux 3.4.34
2. KTweaker 2.8
3. Linux 3.4.33
1. Linux 3.4.30
2. Linux 3.4.31
3. Linux 3.4.32
Change Log 2.4.2013
1. Linux 3.4.29
Change Log 2.2.2013
7. Linux 3.4.27
1. Linux 3.4.26
1. Linux 3.4.25
Change Log 1.6.2013
vm.swappiness = 10
Change Log 1.2.2013
Change Log 12.18
1. JUMP_LABEL patch
4. Linux 3.4.24
9. New KTweaker app
Changelog 12.16
Change log 12.15
1. Linux 3.4.22
2. Linux 3.4.23
Change Log 12.03
3. Linux 3.4.21
Change Log 11.29
5. Voltage control
Change Log 11.26
1. Initial Release
Die 3 Settings sind im Anhang,
- einfach runterladen
- entpacken
- die drei Dateien in den Ordner "KTweaker" schmeißen, sollte schon PegasusQ drin sein.
- KTweakerT App öffnen
- und auf "Restore Prefs from sdcard" gehen.
- die Dateien können dann ausgewählt und geladen werden
- mit "Apply restored settings?" bestätigen
Quelle
- entpacken
Quelle
Code:
1700MHz 1100mv, stable
1600MHz 1075mv, stable
1500MHz 1050mv, stable
1400MHz 1025mv, stable
1300MHz 1000mv, stable
1200MHz 975mv, stable
1100MHz 950mv, stable
1000MHz 925mv, stable
900MHz 900mv, stable
800MHz 875mv, stable
700MHz 850mv, stable
600MHz 850mv, stable
500MHz 850mv, stable
400MHz 850mv, stable
300MHz 850mv, stable
200MHz 850mv, stable
"Battery Level Low" = 30
"Battery Level High" = 15
"CPU Mhz for Low Level" = 800 Mhz
"CPU Mhz for High Level" = 1200 Mhz
"GPU Mhz for Low Level" = 266 Mhz
"GPU Mhz for High Level" = 400 Mhz
AND
Under "General" settings I have:
"CPU Max" = 1800 Mhz
"GPU Max" = 612 Mhz
RESULTS
When battery is 31% and above:
"GPU Max" = 612 Mhz
When battery is between 16% and 30%:
"CPU Max" = 1200 Mhz
"GPU Max" = 400 Mhz
When battery is 15% or less:
"CPU Max" = 800 Mhz
"GPU Max" = 266 Mhz
AND
"GPU Max" = 612 Mhz
RESULTS
"GPU Max" = 612 Mhz
"GPU Max" = 400 Mhz
"CPU Max" = 800 Mhz
"GPU Max" = 266 Mhz
Quelle
