ysoserious
Stamm-User
- 40
Okay sehr interessant muss i h mal die tage testen ;-)
Danke
Gesendet von meinem Nexus 10 mit der Android-Hilfe.de App
Danke
Change Log 7.28.2013
1. Fully upgraded to 4.3!!!!!!!!!!!!!!!
2. Linux 3.4.48
3. Linux 3.4.49
4. Linux 3.4.50
5. Linux 3.4.51
6. Linux 3.4.52
7. Linux 3.4.53
8. Linux 3.4.54
9. Re-linaro source from upgrade
10. Merge in newest ramdisk
Change Log 7.28.2013E
1. Fix GPU Mhz locking at specific Mhz
2. Fix GPU table BUG_ON issue that caused reboots on set on boot options and "Load Default Settings"
Change Log 8.4.2013
1. Merged in newest CM10.2 stuff from pulser_g2 so you guys should have full CM10.2 compatibility
Change Log 10.31.2013
1. Changed Ramdisk to support Purity/Stock ROMs and keeping CM compatibility
2. Happy Halloween
Change Log 10.28.2013
1. Ramdisk updates for CM and AOKP compatibility
2. Linux 3.4.48 - 3.4.67
3. Wifi upgrade to 1.88.45
4. KTweaker update to 4.3 Google API
5. Soooo many more...............
