Nexus-Fan
Stamm-User
- 174
Wird sich wahrscheinlich nicht mehr bessern. Leider.
Aafter two months, going through the Technical Service, in the end they have already indicated to me how to solve it, in a "patch" plan and thanks to **** from the Telegram group (Thank you very much). Well, it seems that it is a problem with the Bluetooth codecs, which are wrong. The solution, because there are two ways, leave the operator's network at 3g/2g when the device is going to be used, or, in my case with Movistar, deactivate the 4G option of the operator's network data. With vodafone, **** tells me that there is no option!
Come on, it's a chore..... that every time you go to take the car or motorcycle, you have to deactivate the 4G option... anyway
I hope they get their act together and solve this problem...which, by the way, also happens to other mobiles, such as the One Plus Nord, owned by ****'s wife, the same thing happens....
Regards
. Muss wohl wieder nach Frankreich.
