[ROM] VegaCream for Advent Vega / PoV Mobii Tegra
  • 104 Antworten
Q
QuesT
[INTRODUCTION]
This ROM is based of the joined effort of a couple of devs (Cass, Eduardo, Corvus, Scanno and Brucelee666) who are working on getting ICS as good as possible for our device. This has resulted in a git repository where all the specific files and patches are located that are needed to compile the Android 4.0.4 AOSP source code and create a working ROM.
I am trying to keep the git repository up-to-date so that all the devs that would to compile the AOSP source code can use the repository to build a good working base rom and put effort in improving the ROM instead of figuring everything out themselves.
I am making VegaCream because i would like to have done this and have some knowledge about making roms. I am working in the IT business for almost 20 years and like many i have a professional and personal life. That means that if i am lucky i have 8 hours per week that i can spend time on this ROM. My wife, my child and my own health are more important then this ROM, so lets keep everything simple and nice. This is supposed to be fun and a hobby (at least it is for me). Let's keep it that way.
[SPECIFICATIONS]
This ROM is based on AOSP 4.0.4 and the device config made by Cass, Eduardo, Corvus and myself (see https://github.com/vegaics).
- DPI is set at 120dpi
- Default ICS Launcher installed
- Apex Launcher installed
- Filemanager installed
- Terminal installed
- Google Apps is installed. This means that the Google base is installed and all the apps that are available in the Play Store are not installed (i.e. GMail, Maps)
- All languages that are available in AOSP are included
- Partition layout is the same as VegaICS beta1 / Modded stock
- /system/app, /system/lib, /system/fonts, /system/framework and /system/usr are Squashfs filesystems.
[INSTALLATION]
With BETA2 there are two ways of installing VegaCream:
- Installing the CWM update zip from recovery
- Using the NVFLASH windows executable.
Use the CWM update zip when you are sure that you have the correct partition layout (modded stock or VegaICS). Always do a *Full Wipe* BEFORE installing the zip file.
Use the NVFLASH installer when you are not sure if you have the correct partition layout or want to repartition and format your NAND. Put your tablet in nvflash mode (back-power-back) and run the exe in windows.
*ATTENTION* The Install zip is *BETA* and it does not have nice text or a good working progress bar. My primary efforts are going to the ROM itself at the moment.
[WORKING]
VegaCream is now on the same level as VegaICS beta1 is. That means it has the same stuff working but it has also the same things that do not work and / or the same problems.
- Wifi (same connection problems as VegaICS beta1)
- Bluetooth (Did not test a lot, but it pairs and communicates)
- (P)EAP (I could connect to the enterprise wifi AP that is available at my work, it connects and could update my apps through the Play Store. The Signal Strength indicator is NOT working when connected to that AP)
- Camera (same as VegaICS beta1)
- 3G Huawei modems
[NOT WORKING]
Look like all devices are working
[CREDITS]
- Cass
- Eduardo
- Corvus
- Scanno
- Brucelee666
- Areo​
*WARNING*
As you might already have read, some people have problems with their touchscreens after flashing a new ROM (this can happen with any ROM). In worst case their touchscreen has died. There has been an investigation into this problem and the conclusion is that there are bad batches of touchscreens that can die when they overheat. This is also due to a design flaw of our tablets. As a precaution it is strongly adviced to disconnect the power from the tablet when booting the first time after flashing a new ROM. This because after flashing a new ROM, the tablet needs to do a lot of processing and that generates heat and increases the change of overheating the touchscreen.
If you feel VegaCream is worth it and would like to show your gratitude (the donate link is added on request):
<<Click here to donate>>
AND also do NOT forget about ejtagle and brucelee666 for their great work.
[DOWNLOADS]
VegaCream BETA RC2:
If you use the CWM zip, please do not forget to do a *Full Wipe*
CWM-Flashable ZIP: VegaCream-RC2-120dpi-Apex.zip
NVFlash: VegaCream-RC2-NVFlash.exe
VegaCream BETA RC1:
CWM-Flashable ZIP: VegaCream-RC1-120dpi-Apex.zip
NVFlash: VegaCream-RC1-NVFlash.exe
VegaCream BETA 4.1:
*Warning* This version uses the new 3.1.10 kernel and can still cause problems. If you are not sure if you want to use this version, then please do not download and install !!!
CWM-Flashable ZIP: VegaCream-Beta4.1-120dpi-Apex.zip
NVFlash: VegaCream-Beta4.1-NVFlash.exe
VegaCream BETA 4:
Here is Beta 4 with the 3.1 kernel. The Wifi problems are fixed and also the suspend problems (hopefully). Sadly at the moment 3G is broken. That is why it is under Fixes and Experiments....
Please remember.... this is experimental !!!
VegaCream Beta 4 - 3.1 kernel
VegaCream BETA 3:
CWM-Flashable ZIP: VegaCream-Beta3-120dpi-Apex.zip
NVFlash: VegaCream-Beta3-NVflash.exe
VegaCream BETA2.1:
CWM-Flashable ZIP: VegaCream-BETA2.1-120dpi-Apex.zip.zip
NVFlash: VegaCream-Beta2.1-nvflash.exe
VegaCream BETA1: VegaCream-Beta1-120dpi-Apex.zip
VegaCream Alpha2: VegaCream-Alpha2-120dpi-Apex.zip
VegaCream Alpha1: VegaCream-Alpha1-120dpi-Apex.zip
[CHANGELIST]
RC2:
- New kernel based on the latest NVidia rel-15r7 kernel.
RC1:
- Latest Apex Launcher
- Wifi working as it should
- Hopefully no lockups anymore
BETA 4.1:
*THIS IS STILL EXPERIMENTAL*
- Kernel 3.1.10
- WiFi working as it should
- Suspend problems should be solved
BETA 3:
- Updated sources to latest AOSP 4.0.4 version (IMM76L)
- Recompiled the kernel:
- Fixed clock frequency staying locked at 1000 Mhz
- Kernel version shows up in About
- TUN module is compiled into the kernel (not as a seperate module)
- Updated proprietary drivers
- Small change in vold.fstab. You can now see connected USB mass storage devices in settings/storage.
BETA2.1:
- Newly compiled from scratch
- Mms.apk is back.
- LatinIME now has build in languages for spellcorrections and hints
BETA2 (compared to BETA1):
- Removed provision.apk. This may conflict with Google Apps
- Added Advanced Wifi Lock to /system/app
- Changed keyboard
- Updated to latest AOSP 4.0.4 version (IMM76I)
- su, busybox, superuser build from source
- SystemUI.apk force closing should be solved.
- Sound problems (stuttering) solved (thanks brucelee666)
- 3G should be working (it is working on my Huawei E153 dongle)
- Browser updated and includes setting to change useragent
- Webkit updated
- OpenVPN compiled from source
BETA1:
- Bluetooth working (Thanks Brucelee666)
- Video problems should be solved (not all libraries needed were included)
- Enhanced Powermenu implemented (Thanks Brucelee666)
- Both Apex Launcher and Stock Launcher included. You can choose at first boot which launcher you want to use)
ALPHA2:
- Squashfs working, all the apps now on /system.
- Camera working.
- All Languages added
- Added a Filemanager on /data/app (can be removed)
- Added a Terminal on /data/app (can be removed)
- Added tun.ko in /system/lib/modules/
- OpenVPN binaries added
Link : [ROM] VegaCream for Advent Vega / PoV Mobii Tegra
Hallo und einen schönen Rest Sonntag,
ich habe die ganze Zeit VegaICS Beta1 drauf gehabt und war ganz zufrieden.
Seit Gestern gabe ich die Alpha2 des VegaCream mit dem Apex Launcher drauf und muss sagen Hut ab.
Was die sich da geleistet haben alle Achtung ;)
Testet selbst :)
Ich habe das ROM jetzt mal aufgespielt. Bisher habe ich keine Fehler gefunden. Alles funktioniert wie es soll. Und es ist schön schnell!
Der Apex Launcher beginnt mir richtig gut zu gefallen. ;)
Hast du schon du schon den Randlosen Desktop entdeckt ?
Ach und alle die schon die ganze Zeit auf 3g und GPS für ihr Pad warten, gibt es nun die beta 2 test 2 ;)
So, das eine oder andere Problem ist nun doch aufgetaucht.
WiFi nach idle. Das konnte ich mit Auto Airplane Mode würgarrounden. Es stört etwas, das es doch eine Weile dauert bis WLAN wieder aktiv ist. Aber permanent aktiv ist keine Alternative. Hoffen wir mal das es bald mit dem/einem ROM gefixt wird.
Die andere Sache hängt mit den Tasten und Touchscreen zusammen. Teilweise sind die Tasten hypersensitiv. Wenn ich das Tablet nur in den Idle schicken möchte, schaffe ich das praktisch nie ohne das zuerst der Screen für die Tablet-Optionen aufgeht. Kann man den Timeout irgendwo einstallen, so 3 sec wären fein. :D
Manchmal reagiert der Homescreen nicht auf click&hold. Da muß man erst auf eine andere Stelle clicken und dann geht es. Das kann aber auch ein Apex Launcher Problem sein...
Ansonsten funktioniert das ROM ausgesprochen gut und schnell. :thumbup:
Ich habe bisher noch keine Probs mit "Advance Wifi Lock Free" und seitdem auch keine robs mehr mig dem Wlan.
Die Berührungsempfindlichtkeit stellst du in Einstellungen --> Bedienungshielfe --> Reaktionszeit Berühren/Halten ein
[CHANGELIST]
BETA2-test3:
VegaCream-BETA2-test3-120dpi-Apex.zip
[CHANGELIST]
- Changed keyboard
- Webkit updated
[DOWNLOADS]
*VegaCream BETA2:*
CWM Flashable ZIP: VegaCream-BETA2-120dpi-Apex.zip
NVFLASH: VegaCream-BETA2-120dpi.exe
Das ROM funktioniert soweit einwandfrei. Für den Powerknopf habe ich ein Progrämmchen gefunden, das geht problemlos.
Was mich aber immer noch nervt ist Wifi. Selbst mit dem Wifi Lock dauert es teilweise ewig (>30 sec) bis Wifi da ist. Manchmal muß man in den Einstellungen auch von AUS auf AN wechseln. Dadurch wird das Tablet reichlich useless als Sofasurfer. Nix mit mal schnell anschalten, was checken und wieder ausschalten. :angry:
Edit: Ich bin jetzt erst einmal wieder zurück auf HC3.2 9b. Das funktioniert im Alltag einfach deutlich besser. Insbesondere die Tasten- und Touchscreen-Empfindlichkeit bei VegaCream nervt doch erheblich.
Kein Wifi mehr bei mir nach dem Update. Bin wieder zurück zu Vegacomb.
Hm hab kein Problem mit dem Wifi.
Ich hab die 2.1er mit dem 3G Fix wo der Assistent nicht ausgeführt werden soll, eingespielt, geht so weit, jedoch neigt der Touchscreen noch immer zu Auszucker.
Zoomen geht gar nicht, Es ist dann so, dass auf der waagrechten Linie im 1. Sechstel auf der Höhe von deinem Druckpunkt ein 2. bzw Dritter Druckpunkt angezeigt wird.
Dies kann man in den Dev Optionen anzeigen.
Wenn das ist, dann spinnt die Kiste wie Sau.
Jedoch ist es nicht mehr so oft, wie bei den vorigen Versionen, Neukalibirieren hält meist einen halben Tag.
Der Rest ist Top.
also ich bin zufrieden mit der 2.1. was mich noch stoert ist, dass er sich immer ausschaltet am Netz. kennt jemand das problem?
Was schaltet sich aus? Das ganze Tablet?
ja leider... aber warum kann ich Dir nicht sagen. Das war bei den vorherigen Versionen auch so.
WLAN findet er auch sehr schlecht, mit dem Advanced wifi lock free läuft es ein wenig besser. Aber auch noch nicht optimal...
Wie gesagt wenn ich ihn am Netz anschließe und einen halben bis ganzen Tag nicht benutze, muss ich ganz neu starten. Der schaltet sich Quasi von alleine aus.
sonst läuft alles gut bis sehr gut.
ich habe die POV Tastatur und eine Maus direkt am USB Hub mit 32 GB Micro Sd Speicher laufen. Ist wie ein Netbook :thumbsup:
Hi zusammen!
Wer Probleme mit dem ersten Start hat und beim Unlockscreen hängt folgender Tip: Dies tritt auf wenn das Telefonmodul zwar eingebaut, aber nicht aktiviert ist. Eine SIM-Karte bei der der PIN deaktiviert wurde in den SIM-Slot und man kann das Tablet ganz einfach einrichten. Läuft gut, mit WLAN (mit Advanced Wifi um das Abschalten zu verhindern), 3G (derzeit Alditalk-Karte), GPS ebenfalls. Wichtig hierbei: Tools die GPS an und ausschalten können führten bei mir zu einem kompletten Neustart des Tablet... habe bei mir GPS dauerhaft an, gibt dann keine Probleme, wird eh nur genutzt wenn eine App dies verlangt.
Ach ja, GPS ging erst als ich die SIM-Karte im Gerät hatte.
Link2SD funktioniert ebenfalls, jedoch kann es bei App2SD zu FC beim Launcher nach dem booten kommen. Hier kann man sich behelfen indem man die App mit link2sd verschiebt und nicht mit app2sd. Habe eine 2 GB große Partition mit Ext2 auf meiner SD-Karte angelegt. Sollte erst mal für 2-3 Apps reichen :)
Touchpad reagiert eigentlich ganz ok. DeepSleep-Probleme hatte ich noch nicht, ausser daß das Tablet nicht beim ersten Druck auf den Powerknopf aufwachte, sondern erst beim 2. mal.
Alles in allem bin ich damit mehr als zufrieden.
Vielleicht helfen die Tips ja dem einen oder anderen.
LG
Markus
Hallo an Alle,
die Beta3 ist raus, alles weitere im Original-Thread (Link auf der ersten Seite)
Michael
Reaktionen: DeAndi
mig schrieb:
Hallo an Alle,
Michael
Ich danke dir dafür :)
Habe in der lt. Zeit, öfter mal ein Freeze gehabt, mal schauen ob das mit der Beta dann der Vergangenheit angehört :)
remmi-z
Orbbman
O
Z
tommesN
