[ROM] Honey Ice
  • 113 Antworten
prinz3nroll3
auf tabletroms gibts ein "neues" Rom
klingt alles sehr gut teste es gerade.
aero schrieb:
Update 3.2.5x2:
*Online*
-Fixes wifi drivers for now
-Added Agenda widget
-Added nice new live wallpaper
-Includes update 3.2.5x
-Fixed most of the market problems:
*Updated market to 3.3.11*
*Changed fingerprint to Motorola Xoom HC 3.2, in theorie you should see more apps*
-sms enabled.
*120dpi version only! Tomorrow FAT will be released and also 140dpi and 160dpi*
*Flash on top of 3.2.5 or 3.2.5x*
Update 3.2.5x:
*Online*
-Fixed a bug in the framework
-Added 160dpi support
*install through method 2*
*you must have 3.2.5 already installed!!!*
Update 3.2.5:
*Online*
-New Wi-fi drivers (thanks to eduardo from modaco)
*it should now support AP mode (WAP)*
*Bluetooth works next to wifi (at the same time)*
-fixed battery drain (see post 3)
-Updated looks, some ICS :p (75% credit for this look update goes to partner, see post 3)
-Other minor fixes
-Added 140 dpi v1 support
*See install method 2 before flashing!*
*For 140 dpi users see method 3 before flashing!*
Update 3.2.4:
-Pulled out 7,2mb of system apps. (changed permissions, resigned and reintergrated them in the update (outside of the systempartition)
-Includes FULL Update 3.2.3
-Systempartion is around the same size as Build 9n (I believe even smaller)
-Fixed a small bug in the framework
-Fixed camera missing (for some users)
-Fixed SystemUI.apk FC's sometimes
-140 dpi auto for V2 (so I now officialy support it!)
-Created a base version (all future DIET updates will be based on this update, it will make the upload time smaller and the file size)
-Replaced font with Robotica from ICS
Changelog before 3.2.4:
Multiupload.com - upload your files to multiple file hosting sites!
hier der link zum thread:
http://tabletroms.com/forums/vega-rom-development/3084-[rom]-honey-ice.html
Reaktionen: Rotorman und QuesT
Hallo, ich habe das Rom nun seit einem Tag drauf und bin begeistert.
Läuft genauso gut wie vegacomb und die fcs beim Browser sind seltener bis ganz weg.
Allerdings war es etwas Arbeit zu installieren da es 9n voraussetzt.
Meines erachtens das beste hc Rom.
Der Browser und gmail app sind wohl auch neuer.
Danke für die Info.
Läuft echt super drauf.
Hört sich ja interessant an :
Ist es auch in deutsch ?
Und geht der hdmi Ausgang ?
1) das meiste ist in deutsch, Browser ist in englisch aber die autkorrektur funktioniert
2) hdmi nicht getestet aber wenn der unter vegacomb geht sollte der auch mit dem Rom laufen.
Kann es echt empfehlen!
Kann es echt empfehlen![/QUOTE]
der hdmi Ausgang funktioniert unter vegacomb leider ( noch ) nicht- könntst du es dennoch mal testen ?
Danke!
areo schrieb:
Update 3.2.6:
*Development started (again :p)*
-Compiling new kernel:
*HDMI up to 720p*
*Gyroscope fixed*
*wifi drivers working correctly*
*clocked at 1.0GHz*
*a lot more*
-Supercharger v6 correct settings created. This script is really perfect now, looks like my tablet is on steroids, big speed improvement, no browser fc yet on all website listed as fc. Will test more but really good)
-More stuff
-Credits comes when this update is out of beta!!!
Steht doch alles im Thread... aber der Threadersteller (hier) hätte ja mal nen komplettes Quote vom Thread einfügen können ;)
P.S. die 3.2.6 gibt es noch nicht zum Downloaden !!! Steht zwar im Thread... aber sage es lieber nochmal dazu :D
MfG
UKSheep
LINK ZUM THREAD: [ROM] Honey Ice
sorry war mir nicht sicher,
was gepostet werden darf und was nicht.
Habe mal den ersten Beitrag abgeändert.
Habe die aktuelle Version seit gestern auf meinem Tag und es läuft wirklich 1a,
Hatte bis jetzt keine Fehler.
LBE Security Guard geht nicht. Totaler Fail für von daher :D
Was ist denn das überhaupt mit dieser Kompatibilität? Find das nervig... Wenn das bei Windows so wäre würd jeder durchdrehen.
Geh wieder zur guten Version von hier über :D
habe die neuste Version drauf, aber bekomme keine Wlan Verbindung hin.
Hat jemand auch Probleme damit ?
habe nur Probleme bei hidden ssid.
Ansonsten top rom- hdmi geht, market etc. auch :)
@Warrick
Sry eben erst gesehen das es nur bei hidden SSID ist...
Sent from my GT-I9100 using Tapatalk
Warum finde ich keine Bilder zu diesen ROM? Wäre mal Interessant wenn da einer paar hoch laden würde.
Danke Peter
Reaktionen: marcel982002
Es ist "nur" ein Update für VegaComb... es ist zu 95% gleich ;)
Also wozu Bilder?
Reaktionen: Wurmclemens
Danke welche Version müsste ich da nehmen? Habe 9n drauf. Ablauf...auf SD und mit Recovery drüber bügeln?
URL: http://tabletroms.com/forums/vega-rom-development/3084-%5Brom%5D-honey-ice.html
Flash instructions:
Read the procedure first then look at the checklist! And very very important: Follow the procedure to the letter!!!
Checklist needed to flash HoneyIce 3.2.7: -VegaComb 9n or Update 3 or HoneyIce: 3.2.4 DIET, 3.2.5 DIET or 3.2.5x DIET or 3.2.6! -You DO NOT HAVE 3.2.5x2 installed! -HoneyIce 3.2.7b.zip or HoneyIce 3.2.7a.zip -The SuperCharger V6 script -The Market symlink script -Time to read the Flash Procedure and follow it to the letter! -Check the buglist
Flash Procedure: Video coming soon! -Look at the Checklist and make sure you have everything on your sdcard! -Make sure you have a working wi-fi connection on your current VegaComb/HoneyIce version! -Boot into CWM -Flash 3.2.7b.zip or 3.2.7a.zip -Reboot out of CWM -Sign into the Android Market -Accept the Android Market Agreement. -Go to MarketFix (grant superuser acces) and click on the button. -Go to Scriptmanager (if pop-up about new widget tap do not ask again and then tap on cancel) -Tap the button next to the (multitask button, left bottom corner). -Then tap more and then tap Advanced Options, then tap config. -Tap browse as root. -Press back button once! -Flip Tablet vertical and wait, then grand superuser acces. -Go back to scriptmanager -Go to V6_SuperCharger_for_Android-update8.sh -Tap Run as Root (NOT RUN AT BOOT!!!!) -Tap Run -Type 1 and enter (wait) -Type 9 and enter (wait) -Type 11 and enter (wait) -Type 17 and enter (now tap in the left top corner on close) -Go to /data (on vega so NOT on sdcard) -Select 99Supercharger.sh -Tap Run as Root AND Run at Boot -Tap Save -Reboot -Go into Scriptmanager, find the Market symlink(sdcard).sh script. Tap on it, then tap on script, tap run at boot and run as root. Tap on save! -Reboot -Grand Superuser acces when asked! (if not asked no problems) -Calibrate Battery -Enjoy
Public Beta 2 of HoneyIce 3.2.7 version known bugs:
-When Adobe Flash installed, browser FC! Use Maxthon or Dolphin for Tab instead. -On first boot, two markets are seen, press on the one on the Desktop (it says not installed), reboot, the correct market is now shown. -BT and wifi @ the same time is buggy. -Kernelbug: it needs a working wi-fi connection before booting into CWM!
***This update may be used by all devs for future Vega updates but please give me the credits for it!***
Danke Installation war ja einfach. Habe A genommen läuft soweit Stabil..was mich wundert das auf der Computer-Bild Seite kein Flash geht!? Auf keinem Browser nur bei mir so!?
Gruß Peter
hast du flash installiert? bei mir gehts wunderbar mit vegacomb 9
Ja habe ich Version 11.1 ist drauf und auch nochmal Installiert. OK kann es sein das es erst ohne Probleme geht wenn die Seit Vollständig geladen ist!? Da scheint es zu gehen.
Was ist der Unterschied zwischen Honey Ice A und B? Hatte ja VegaComb N drauf ok wenn ich A oder muss ich B nehmen?
